I try, it work
gst-launch-1.0 rtspsrc location=rtsp://admin:xxxx@10.130.128.xx ! decodebin ! nvvideoconvert ! nvdsosd ! nvegltransform ! nveglglessink
why in python, not work
gst_str = "rtspsrc location=rtsp://admin:xxxx@10.130.128.xx ! decodebin ! nvvideoconvert ! nvdsosd ! nvegltransform ! nveglglessink"
cap = cv2.VideoCapture(gst_str, cv2.CAP_GSTREAMER)
while True:
_, frame = cap.read()
cv2.imshow('RTSP stream', frame)
if cv2.waitKey(1) == 27:
break
error
cv2.error: /build/opencv-XDqSFW/opencv-3.2.0+dfsg/modules/highgui/src/window.cpp:304: error: (-215) size.width>0 && size.height>0 in function imshow
The last plugin has to be appsink. It does not work with nveglglessink. Please refer to this sample:
Doesn't work nvv4l2decoder for decoding RTSP in gstreamer + opencv - #3 by DaneLLL
I try to follow the example
same error
try open rtsp “rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov” ,it work
T-T
So this does not work:
rtspsrc location=rtsp://admin:xxxx@10.130.128.xx ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw,format=BGR ! appsink
Please try gst-launch-1.0 command to make sure URI is valid:
gst-launch-1.0 rtspsrc location=rtsp://admin:xxxx@10.130.128.xx ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw,format=BGR ! fakesink
Hi, DaneLLL
I don’t mean that.
I’m using the sorce “rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov” from the example, but same error
I try run :
gst-launch-1.0 rtspsrc location=rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw,format=BGR ! fakesink
Result: No response at…
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mov
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (request) SETUP stream 1
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
kayccc
7
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
