This use-case is not supported. Dynamically linking/unlinking the sink may trigger memory leak. Would suggest use nvmultistreamtiler plugin.
For this use-case, a possible solution is to use udpsink. You can have 4 udp streams with individual port number. And dynamically destroy/launch the pipeline to switch between the streams:
Something that I don’t understand is that even without switching cameras ( taking out the function of switching ) so that only one camera is displayed during all the process, the problem appears. I don’t see where the memory leak appears if there is no switching.
Do you mean that having no sink for the other cameras can create a sort of memory leak that would not exist if they were linked to fakesink ? And so, when i’m switching camera, to link everytime the previous camera to fakesink
Linking each camera to fakesink is for testing purpose. To avoid switching between the cameras. Since dynamic unlinking/linking is not supported.
For a real use-case, would suggest link to udpsink. And you can construct the pipeline with udpsrc to decode the stream and display. And can switch to decode another stream.
