My current pipeline is:
v4l2src device=/dev/video0 ! videoscale ! videorate ! video/x-raw, format=YUY2, width=640, height=480, framerate=1/1 ! videoconvert ! pngenc ! appsink emit-signals=True drop=True sync=False pulsesrc device=alsa_input.usb-MACROSILICON_USB_Video-02.analog-stereo blocksize=4096 ! audioconvert ! wavenc ! appsink emit-signals=True drop=True sync=False throttle-time=1000000000
This is working on my Jetson nano normally but when I try it inside a simple docker container it gives me the following errer:
GLib.Error: gst_parse_error: no element "pulsesrc" (1)
Now after some research I added the following lines into my docker build file:
RUN apt-get install -y \
gstreamer-1.0 \
gstreamer1.0-dev \
python3-gi \
python-gst-1.0 \
libgirepository1.0-dev \
libcairo2-dev \
gir1.2-gstreamer-1.0 \
libgstreamer1.0-0 \
gstreamer1.0-plugins-base \
gstreamer1.0-plugins-good \
gstreamer1.0-libav \
gstreamer1.0-doc \
gstreamer1.0-tools \
gstreamer1.0-x \
gstreamer1.0-alsa \
gstreamer1.0-gl \
gstreamer1.0-gtk3 \
gstreamer1.0-qt5 \
gstreamer1.0-pulseaudio```
This solved the pulsesrc error but another one was generated:
ERROR: from element /GstPipeline:pipeline0/GstPulseSrc:pulsesrc0: Failed to connect: Connection refused
So I decided to change my docker run command to:
nvidia-docker run --user $(id -u):$(id -g) --network="host" --restart=always --privileged=True -v /tmp/argus_socket:/tmp/argus_socket -it main-container:latest```
Now I am getting the following errors:
Error: Can't initialize nvrm channel
Couldn't create ddkvic Session: Cannot allocate memory
nvbuf_utils: Could not create Default NvBufferSession
Setting pipeline to PAUSED ...
Home directory not accessible: Permission denied
ERROR: Pipeline doesn't want to pause.
Additional debug info:
pulsesrc.c(1015): gst_pulsesrc_open (): /GstPipeline:pipeline0/GstPulseSrc:pulsesrc0
Setting pipeline to NULL ...
Freeing pipeline ...
Any help is appreciated, thank you !
Edit 1: My whoami command output is:
whoami: cannot find name for user ID 1000
