Gstreamer pipeline with splitmuxsink performance degradation
I’m using GStreamer on my Jetson device with JetPack 4.4.1 to capture video from cameras. When I run the following pipeline:
gst-launch-1.0 -vvv \
    v4l2src do-timestamp=true device=/dev/video1 ! \
    image/jpeg,framerate=60/1,width=1280,height=960 ! \
    videorate ! \
    image/jpeg,framerate=10/1 ! \
    nvv4l2decoder mjpeg=1 ! \
    nvvidconv flip-method=2 ! \
    video/x-raw(memory:NVMM),format=RGBA,width=1280,height=960 ! \
    fakesink name=LEFT_CAMERA_sink sync=true \
everything works well.
However, when I use the following pipeline to record video:
    videorate ! \
    tee name=t_LEFT_CAMERA ! \
    queue ! \
    t_LEFT_CAMERA. ! \
    queue ! \
    nvvidconv ! \
    nvv4l2h265enc ! \
    h265parse ! \
    tee name=t_LEFT_CAMERA_h265 ! \
    queue ! \
    splitmuxsink location="/home/deep/shopic_videos/LEFT_CAMERA_clip_%06d.mp4" \
    max-size-time=5000000000 max-files=1000 async-finalize=true async-handling=true async=false
there is a significant performance drop, with operations on the device slowing down by almost half.
Does anyone have suggestions for optimizing this pipeline or ways to minimize the impact of video recording on overall performance?
Thank you!
Please try the items and see if there is improvement:
  1. Configure sync=0 to fakesink
  2. Run $ sudo jetson_clocks
  3. Enable the properties to nvv4l2h265enc:
  insert-vui          : Insert H.265 VUI(Video Usability Information) in SPS
                        flags: readable, writable
                        Boolean. Default: false
  maxperf-enable      : Enable or Disable Max Performance mode
                        flags: readable, writable, changeable only in NULL or READY state
If there is no further improvement, suggest break down the pipeline to clarify which plugin triggers it.
And you can run sudo tegrastats to check system status.
Thank you very much for your detailed response. I apologize for any confusion, but could you provide a more in-depth explanation on a couple of points?
  • How can I configure sync=0 for a specific module within the pipeline or for the entire pipeline?
  • On my Jetson device, when I run $ sudo jetson_clocks, I don’t see any output. Additionally, when I execute:
    $ sudo jetson_clocks --show
    SOC family:tegra194  Machine:NVIDIA Jetson Xavier NX Developer Kit
    Online CPUs: 0-5
    CPU Cluster Switching: Disabled
    cpu0: Online=1 Governor=schedutil MinFreq=1420800 MaxFreq=1420800 CurrentFreq=1420800 IdleStates:
    C1=0 c6=0
    cpu1: Online=1 Governor=schedutil MinFreq=1420800 MaxFreq=1420800 CurrentFreq=1420800 IdleStates: C1=0 c6=0
    cpu2: Online=1 Governor=schedutil MinFreq=1420800 MaxFreq=1420800 CurrentFreq=1420800 IdleStates: C1=0 c6=0
    cpu3: Online=1 Governor=schedutil MinFreq=1420800 MaxFreq=1420800 CurrentFreq=1420800 IdleStates: C1=0 c6=0
    cpu4: Online=1 Governor=schedutil MinFreq=1420800 MaxFreq=1420800 CurrentFreq=1420800 IdleStates: C1=0 c6=0
    cpu5: Online=1 Governor=schedutil MinFreq=1420800 MaxFreq=1420800 CurrentFreq=1420800 IdleStates: C1=0 c6=0
    GPU MinFreq=1109250000 MaxFreq=1109250000 CurrentFreq=1109250000
    EMC MinFreq=204000000 MaxFreq=1600000000 CurrentFreq=1600000000 FreqOverride=1
    Fan: speed=170
    NV Power Mode: MODE_15W_6CORE
    and also
    $ sudo jetson_clocks --help
    Maximize jetson performance by setting static max frequency to CPU, GPU and EMC clocks.
    Usage:
    jetson_clocks.sh [options]
      options,
      --show             display current settings
      --fan              set PWM fan speed to maximal
      --store [file]     store current settings to a file (default: ${HOME}/l4t_dfs.conf)
      --restore [file]   restore saved settings from a file (default: ${HOME}/l4t_dfs.conf)
      run jetson_clocks.sh without any option to set static max frequency to CPU, GPU and EMC clocks.
I still don’t fully understand how to enable the properties for nvv4l2h265enc.
Additionally, here is the result from inspecting the plugin:
$ gst-inspect-1.0 nvv4l2h265enc
Thank you in advance for your support.
You can enable the properties like:
... ! nvv4l2h265enc maxperf-enable=1 insert-vui=1 ! ...
Thank you for the response. I’ll test it and update you with the results. It may take a couple of days, as I have other tasks to complete.
Yes, I ran the tests and have the results. The flags mentioned here had no effect on my system’s performance. After extensive testing, I found a partial solution: I reduced the bitrate from the default of 4000000 to 1000000.
This change improved the rest of the process, reducing latency significantly, though some latency remains.
If you have any other ideas for improvement, I’d be happy to test and implement them. Thank you!
You may also enable the properties for a try:
  insert-aud          : Insert H.265 Access Unit Delimiter(AUD)
  insert-sps-pps      : Insert H.265 SPS, PPS at every IDR frame
And try smaller IDR interval:
  idrinterval         : Encoding IDR Frame occurance frequency
                        Unsigned Integer. Range: 0 - 4294967295 Default: 256
Thank you for the update.
I will conduct more detailed testing later, as I currently have many other tasks. I will provide an update on the results as soon as the testing is complete.
