I’m trying to use camera’s frames for appsink and filesink.
here is the current code working well.
pipeline
gst-launch-1.0 -v pylonsrc camera=0 fps=30 imageformat=ycbcr422_8 gamma=1.10001 gain=9.2 exposure=11000
! queue ! nvvidconv ! 'video/x-raw(memory:NVMM)'
! queue ! nvivafilter customer-lib-name=./lib-gst-custom-opencv_cudaprocess0.so cuda-process=true
! queue ! 'video/x-raw(memory:NVMM), format=RGBA'
! queue ! nvegltransform ! nveglglessink
pipeline in program
"pylonsrc camera=0 fps=30 imageformat=ycbcr422_8 gamma=1.10001 gain=9.2 exposure=11000 "
"! queue ! nvvidconv "
"! video/x-raw(memory:NVMM) "
"! queue ! nvivafilter customer-lib-name=../cu/lib-gst-custom-opencv_cudaprocess0.so cuda-process=true "
"! queue ! video/x-raw(memory:NVMM), format=RGBA "
"! video/x-raw "
"! queue ! appsink name=sink sync=false ";
However if I add tee method to record original camera’s frames at the same time, it doesn’t work well with error bellow.
error
WARNING: erroneous pipeline: could not link t to queue1, t can't handle caps video/x-raw, format=(string)I420
pipeline
! tee name=t ! 'video/x-raw, format=(string)I420'
! queue ! 'video/x-raw, format=(string)I420' ! omxh265enc ! matroskamux filesink location =test.mp4 t.
I was searching and trying with modifications, but still doesn’t work. maybe I didn’t understand its usage well.
Could you guys have any advises?
Thank you.
