I’m trying to debug a problem on my Xavier and I’m not quite sure where to start.
I have the e-consystems four camera system for Xavier. All of my cameras work great. But with my current video recording pipeline, recording just seems to stop sometimes after only a handful of seconds. I start my script and four video files are created. The video files grow in size for a bit, and then they just stop growing. There’s no change in output in the script and verbose mode didn’t provide anything helpful. I’ve tried a bunch of different combinations with the multiqueue buffer options but nothing helped. Sometimes longer recordings work fine, but often it just stops as described.
Here is my script. Please let me know if it looks okay? How could I debug this? Thanks!
sudo nvpmodel -m 0
sudo jetson_clocks
# WIDTH=1280
# HEIGHT=720
# EXPOSURE=105
# BITRATE=40000000
# WIDTH=4192
# HEIGHT=3120
# EXPOSURE=205
# BITRATE=40000000
WIDTH=3840
HEIGHT=2160
EXPOSURE=6
BITRATE=80000000
for i in 0 1 2 3
do
v4l2-ctl -d $i --set-ctrl=frame_sync=1
#v4l2-ctl -d $i --set-ctrl=auto_exposure=0
#v4l2-ctl -d $i --set-ctrl=auto_exposure=1
v4l2-ctl -d $i --set-ctrl=exposure_time_absolute=$EXPOSURE
done
sleep 2
filename=$(date +"%m_%d_%Y_%H:%M:%S")
gst-launch-1.0 -e \
multiqueue sync-by-running-time=TRUE max-size-bytes=0 max-size-buffers=0 max-size-time=0 name=mqueue \
v4l2src device=/dev/video0 ! "video/x-raw, format=(string)UYVY, width=(int)$WIDTH,height=(int)$HEIGHT" ! mqueue.sink_1 \
v4l2src device=/dev/video1 ! "video/x-raw, format=(string)UYVY, width=(int)$WIDTH,height=(int)$HEIGHT" ! mqueue.sink_2 \
v4l2src device=/dev/video2 ! "video/x-raw, format=(string)UYVY, width=(int)$WIDTH,height=(int)$HEIGHT" ! mqueue.sink_3 \
v4l2src device=/dev/video3 ! "video/x-raw, format=(string)UYVY, width=(int)$WIDTH,height=(int)$HEIGHT" ! mqueue.sink_4 \
mqueue.src_1 ! nvvidconv ! "video/x-raw(memory:NVMM), format=(string)I420, width=(int)$WIDTH,height=(int)$HEIGHT" ! nvv4l2h265enc bitrate=$BITRATE ! h265parse ! qtmux ! filesink location=/media/external/Videos/{$filename}_0.mp4 \
mqueue.src_2 ! nvvidconv ! "video/x-raw(memory:NVMM), format=(string)I420, width=(int)$WIDTH,height=(int)$HEIGHT" ! nvv4l2h265enc bitrate=$BITRATE ! h265parse ! qtmux ! filesink location=/media/external/Videos/{$filename}_1.mp4 \
mqueue.src_3 ! nvvidconv ! "video/x-raw(memory:NVMM), format=(string)I420, width=(int)$WIDTH,height=(int)$HEIGHT" ! nvv4l2h265enc bitrate=$BITRATE ! h265parse ! qtmux ! filesink location=/media/external/Videos/{$filename}_2.mp4 \
mqueue.src_4 ! nvvidconv ! "video/x-raw(memory:NVMM), format=(string)I420, width=(int)$WIDTH,height=(int)$HEIGHT" ! nvv4l2h265enc bitrate=$BITRATE ! h265parse ! qtmux ! filesink location=/media/external/Videos/{$filename}_3.mp4
