So my 1080Ti is stuck in the P0 state, it drops down to P8 state once I disconnect my second monitor, and only use one. I can’t figure out how to get it to drop down with the two monitors connected. I am on the proprietary nvidia drivers. Using wayland on KDE Plasma.
They are 2560x1440@144 and 3440x1440@144
Thoughts?
Linux Kernel:
6.15.9-arch1-1
Driver ver:
575.64.05
Keeping the ultrawide at 144hz, and dropping the secondary monitor to 24hz seemed to have lowered the GPU to P8. I can’t tell if the driver is designed to push to P0 in a dual monitor high refresh scenario? Can’t be that taxing to need P0? The GPU load on nvtop is quite literally 0%.
