Have a problem with launching my new GTX 750 Ti on Linux (tried Debian, Ubuntu, Centos, kernel 2.6, 3.0, 4.9).
Picture present, only text mode, X-server does not start.
I’v tried different versions of driver, install from repo and from file, only legacy 304 driver works.
Here are logs from latest version for linux 378.13.
The last idea was incorrect hardware/MB/BIOS, but on Windows all works fine (the same PC).
I would be grateful for any help.
root@debian-kvm:~#dmesg | grep NVRM
[ 13.728874] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 378.13 Tue Feb 7 20:10:06 PST 2017
[ 33.818804] NVRM: RmInitAdapter failed! (0x25:0xffff:1075)
[ 33.818899] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 34.124698] NVRM: failed to copy vbios to system memory.
[ 34.126183] NVRM: RmInitAdapter failed! (0x30:0xffff:654)
[ 34.126209] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 34.530834] NVRM: failed to copy vbios to system memory.
[ 34.534385] NVRM: RmInitAdapter failed! (0x30:0xffff:654)
[ 34.534435] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 34.914847] NVRM: failed to copy vbios to system memory.
[ 34.916390] NVRM: RmInitAdapter failed! (0x30:0xffff:654)
[ 34.916408] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 35.480859] NVRM: failed to copy vbios to system memory.
[ 35.482725] NVRM: RmInitAdapter failed! (0x30:0xffff:654)
[ 35.482747] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 36.010431] NVRM: failed to copy vbios to system memory.
[ 36.011945] NVRM: RmInitAdapter failed! (0x30:0xffff:654)
[ 36.011967] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 36.408806] NVRM: failed to copy vbios to system memory.
[ 36.410844] NVRM: RmInitAdapter failed! (0x30:0xffff:654)
[ 36.410868] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 36.794133] NVRM: failed to copy vbios to system memory.
[ 36.795603] NVRM: RmInitAdapter failed! (0x30:0xffff:654)
[ 36.795619] NVRM: rm_init_adapter failed for device bearing minor number 0
root@debian-kvm:~# lsmod|grep nvidia
nvidia_drm 45056 0
nvidia_modeset 806912 1 nvidia_drm
nvidia 12271616 1 nvidia_modeset
drm_kms_helper 155648 1 nvidia_drm
drm 360448 3 nvidia_drm,drm_kms_helper
root@debian-kvm:~# modinfo nvidia
filename: /lib/modules/4.9.0-1-amd64/kernel/drivers/video/nvidia.ko
alias: char-major-195-*
version: 378.13
supported: external
license: NVIDIA
srcversion: BE3B9C93EC74BAEC2B4BA6A
alias: pci:v000010DEd00000E00sv*sd*bc04sc80i00*
alias: pci:v000010DEd*sv*sd*bc03sc02i00*
alias: pci:v000010DEd*sv*sd*bc03sc00i00*
depends:
vermagic: 4.9.0-1-amd64 SMP mod_unload modversions
parm: NVreg_Mobile:int
parm: NVreg_ResmanDebugLevel:int
parm: NVreg_RmLogonRC:int
parm: NVreg_ModifyDeviceFiles:int
parm: NVreg_DeviceFileUID:int
parm: NVreg_DeviceFileGID:int
parm: NVreg_DeviceFileMode:int
parm: NVreg_UpdateMemoryTypes:int
parm: NVreg_InitializeSystemMemoryAllocations:int
parm: NVreg_UsePageAttributeTable:int
parm: NVreg_MapRegistersEarly:int
parm: NVreg_RegisterForACPIEvents:int
parm: NVreg_CheckPCIConfigSpace:int
parm: NVreg_EnablePCIeGen3:int
parm: NVreg_EnableMSI:int
parm: NVreg_TCEBypassMode:int
parm: NVreg_UseThreadedInterrupts:int
parm: NVreg_MemoryPoolSize:int
parm: NVreg_RegistryDwords:charp
parm: NVreg_RegistryDwordsPerDevice:charp
parm: NVreg_RmMsg:charp
parm: NVreg_AssignGpus:charp
root@debian-kvm:~# cat /proc/driver/nvidia/gpus/0000\:01\:00.0/information
Model: GeForce GTX 750 Ti
IRQ: 35
GPU UUID: GPU-????????-????-????-????-????????????
Video BIOS: ??.??.??.??.??
Bus Type: PCIe
DMA Size: 36 bits
DMA Mask: 0xfffffffff
Bus Location: 0000:01:00.0
Device Minor: 0
root@debian-kvm:~# uname -a
Linux debian-kvm 4.9.0-1-amd64 #1 SMP Debian 4.9.6-3 (2017-01-28) x86_64 GNU/Linux
root@debian-kvm:~# rmmod nouveau
rmmod: ERROR: Module nouveau is not currently loaded
root@debian-kvm:~# nvidia-smi
No devices were found
root@debian-kvm:~#
nvidia-installer.log (26.6 KB)
