My system’s UI (with RTX 3090) lags horribly when under any heavy CUDA computation even when a fraction of the total VRAM is being used. The Volatile GPU-Util is 100% however I am unclear as to how does that relate to the sluggishness. The system becomes pretty unusable as everything (mouse cursors, windows) lags terribly.
My system specifications are as follows -
System:
Kernel: 5.10.52-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
root=UUID=ea7605c0-b50c-450a-9352-4eb157326167 rw processor.max_cstate=5
rcu_nocbs=0-11 quiet splash iommt=pt quiet apparmor=1 security=apparmor
resume=UUID=e2bf2cd5-6f9a-461f-aece-916853371e98 udev.log_priority=3
pcie_aspm=off idle=nomwait
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Distro: Manjaro Linux base: Arch Linux
Machine:
Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING EDGE WIFI (MS-7C37)
v: 1.0 serial: <filter> UEFI: American Megatrends LLC. v: 1.D0
date: 01/25/2021
Battery:
Message: No system battery data found. Is one present?
Memory:
RAM: total: 31.34 GiB used: 10.77 GiB (34.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges required.
CPU:
Info: 8-Core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache:
L2: 4 MiB bogomips: 121654
Speed: 3600 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
1: 3600 2: 2873 3: 2880 4: 2876 5: 2870 6: 2872 7: 2878 8: 2879 9: 2880
10: 2874 11: 2880 12: 2879 13: 2880 14: 2881 15: 3584 16: 2974
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy
constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: NVIDIA GA102 [GeForce RTX 3090] driver: nvidia v: 470.57.02
alternate: nouveau,nvidia_drm bus-ID: 2d:00.0 chip-ID: 10de:2204
class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: nvidia note: n/a (using device driver) unloaded: nvidia
display-ID: :0 screens: 1
Screen-1: 0 s-res: 5460x2880 s-dpi: 144 s-size: 963x508mm (37.9x20.0")
s-diag: 1089mm (42.9")
Monitor-1: HDMI-0 res: 1620x2880 hz: 60
Monitor-2: DP-0 res: 3840x2160 hz: 60 dpi: 163 size: 600x340mm (23.6x13.4")
diag: 690mm (27.2")
OpenGL: renderer: NVIDIA GeForce RTX 3090/PCIe/SSE2
v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Audio:
Device-1: NVIDIA GA102 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 2d:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.10.52-1-MANJARO running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 14.2 running: yes
Sound Server-4: PipeWire v: 0.3.32 running: yes
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel port: d000
bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp39s0 state: down mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel port: d000 bus-ID: 29:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp41s0 state: up mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
IP v6: <filter> type: noprefixroute scope: link
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
WAN IP: <filter>
Bluetooth:
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4:2 chip-ID: 8087:0aa7 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: up address: see --recommends
Logical:
Message: No logical block device data found.
RAID:
Message: No RAID data found.
Drives:
Local Storage: total: 2.27 TiB used: 736.59 GiB (31.6%)
SMART Message: Unable to run smartctl. Root privileges required.
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 111110WD temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST32000644NS
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: KA06 scheme: GPT
Message: No optical or floppy data found.
Partition:
ID-1: / raw-size: 430.99 GiB size: 423.22 GiB (98.20%)
used: 147.87 GiB (34.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: ea7605c0-b50c-450a-9352-4eb157326167
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 3.8 MiB (1.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 9566-45E4
ID-3: /mnt/sda1 raw-size: 1.82 TiB size: 1.79 TiB (98.38%)
used: 588.71 GiB (32.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: ec318b9e-67f0-4bfe-a13d-1e7ec0a62e57
Swap:
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 34.48 GiB used: 512 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: e2bf2cd5-6f9a-461f-aece-916853371e98
Unmounted:
Message: No unmounted partitions found.
USB:
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-4:2 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c37 class-ID: 0300 serial: <filter>
Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0608 class-ID: 0900
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-7: 5-3:26 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 5-3.1:27 info: Logitech M105 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 5-3.2:28 info: Razer USA BlackWidow Elite type: Keyboard,Mouse
driver: razerkbd,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 1532:0228 class-ID: 0300
Hub-8: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Sensors:
System Temperatures: cpu: 45.2 C mobo: 37.0 C gpu: nvidia temp: 42 C
Fan Speeds (RPM): fan-1: 1638 fan-2: 798 fan-3: 1114 fan-4: 1040 fan-5: 1073
fan-6: 1022 fan-7: 0 gpu: nvidia fan: 0%
Info:
Processes: 385 Uptime: 5d 17h 45m wakeups: 0 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages:
pacman: 1540 lib: 382 flatpak: 0 Shell: Zsh v: 5.8 running-in: yakuake
inxi: 3.3.06
Results of nvidia-smi when running a CUDA heavy code (and super sluggish UI)
| NVIDIA-SMI 470.57.02 Driver Version: 470.57.02 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:2D:00.0 On | N/A |
|100% 49C P0 255W / 350W | 6041MiB / 24234MiB | 100% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 831702 G /usr/lib/Xorg 571MiB |
| 0 N/A N/A 834035 G /usr/lib/firefox/firefox 275MiB |
| 0 N/A N/A 834125 G /usr/lib/firefox/firefox 4MiB |
| 0 N/A N/A 1139272 G /usr/lib/firefox/firefox 4MiB |
| 0 N/A N/A 1373772 G /usr/bin/kwin_x11 9MiB |
| 0 N/A N/A 1776538 G /usr/lib/firefox/firefox 4MiB |
| 0 N/A N/A 2053977 G ...AAAAAAAAA= --shared-files 183MiB |
| 0 N/A N/A 2111313 G /usr/lib/firefox/firefox 4MiB |
| 0 N/A N/A 2213402 G /usr/lib/firefox/firefox 4MiB |
| 0 N/A N/A 2224251 C nsfminer 4797MiB |
| 0 N/A N/A 2225088 G /usr/bin/plasmashell 149MiB |
| 0 N/A N/A 2225678 G ...ellRnoDYD.13.slave-socket 4MiB |
What is the probable cause of this extreme lag? How can I fix this?
