Okay, I got a bit of progress.
I can compile my project in qt now. This is what I am doing. I am grabbing h264 encoded frames from an IP camera, decomposing the encoded buffer by myself to get SPS, PPS and frame buffers. Then I am packing with each of these with starting prefix 0x00,0x00,0x00,0x01 and feeding this to the decoder as NAL units. I am initializing output_plane as
ctx[channel].dec->output_plane.setupPlane(V4L2_MEMORY_MMAP, 10, true, false);
But when all 10 output_plane buffer are en queued and the program starts to dequeue first before putting more frames into the queue, it stucks in
ret = v4l2_ioctl(fd, VIDIOC_DQBUF, &v4l2_buf);
of
int
NvV4l2ElementPlane::dqBuffer(struct v4l2_buffer &v4l2_buf, NvBuffer ** buffer,
NvBuffer ** shared_buffer, uint32_t num_retries)
function.
I tried using or not using
ret = ctx[channel].dec->disableCompleteFrameInputBuffer();
but no luck. It stuck always. difference of using disableCompleteFrameInputBuffer() is the v4l2_ioctl() function succeeds upto 3rd frame (i.e., SPS, PPS, iFrame), without disableCompleteFrameInputBuffer() it stuck after dequeuing only SPS and PPS.
Need help.
BTW, for your info, my program at the moment is only feeding h264 encoded frames into the decoder. There is no code yet to read and use the decoded buffer.
More info:
This is what I get in my qt application output window, if it helps:
NvMMLiteOpen : Block : BlockType = 261
TVMR: NvMMLiteTVMRDecBlockOpen: 7647: NvMMLiteBlockOpen
NvMMLiteBlockCreate : Block : BlockType = 261
TVMR: cbBeginSequence: 1179: BeginSequence 1280x720, bVPR = 0
TVMR: LowCorner Frequency = 0
TVMR: cbBeginSequence: 1529: DecodeBuffers = 6, pnvsi->eCodec = 4, codec = 0
TVMR: cbBeginSequence: 1600: Display Resolution : (1280x720)
TVMR: cbBeginSequence: 1601: Display Aspect Ratio : (1280x720)
TVMR: cbBeginSequence: 1669: ColorFormat : 5
TVMR: cbBeginSequence:1680 ColorSpace = NvColorSpace_YCbCr709
TVMR: cbBeginSequence: 1809: SurfaceLayout = 3
TVMR: cbBeginSequence: 1902: NumOfSurfaces = 13, InteraceStream = 0, InterlaceEnabled = 0, bSecure = 0, MVC = 0 Semiplanar = 1, bReinit = 1, BitDepthForSurface = 8 LumaBitDepth = 8, ChromaBitDepth = 8, ChromaFormat = 5
TVMR: cbBeginSequence: 1904: BeginSequence ColorPrimaries = 1, TransferCharacteristics = 1, MatrixCoefficients = 1
