Hi Quang,
On r28.1, by running the following command
]gst-launch-1.0 videotestsrc num-buffers=300 ! ‘video/x-raw, width=1920, height=1080, framerate=60/1, format=UYVY’ ! nvvidconv ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, format=I420, framerate=60/1’ ! omxh265enc control-rate=2 bitrate=8000000 preset-level=3 SliceIntraRefreshEnable=true SliceIntraRefreshInterval=30 ! ‘video/x-h265, stream-format=(string)byte-stream’ ! filesink location= b.h265
It generates the bitstream in first I frame and the rest are P frames:
danel@ce-tw-daneliu:~/svn_hevc/svn_HEVCSoftware/trunk/bin$ ./TAppDecoderStatic -b ~/temp/b.h265
HM software: Decoder Version [16.15] (including RExt)[Linux][GCC 4.8.4][64 bit]
POC 0 TId: 0 ( I-SLICE, QP 30 ) [DT 0.049] [L0 ] [L1 ] [:,(unk)]
POC 1 TId: 0 ( P-SLICE, QP 34 ) [DT 0.029] [L0 0 ] [L1 ] [:,(unk)]
POC 2 TId: 0 ( P-SLICE, QP 40 ) [DT 0.027] [L0 1 ] [L1 ] [:,(unk)]
POC 3 TId: 0 ( P-SLICE, QP 51 ) [DT 0.023] [L0 2 ] [L1 ] [:,(unk)]
POC 4 TId: 0 ( P-SLICE, QP 49 ) [DT 0.022] [L0 3 ] [L1 ] [:,(unk)]
POC 5 TId: 0 ( P-SLICE, QP 50 ) [DT 0.020] [L0 4 ] [L1 ] [:,(unk)]
POC 6 TId: 0 ( P-SLICE, QP 48 ) [DT 0.020] [L0 5 ] [L1 ] [:,(unk)]
POC 7 TId: 0 ( P-SLICE, QP 50 ) [DT 0.020] [L0 6 ] [L1 ] [:,(unk)]
POC 8 TId: 0 ( P-SLICE, QP 44 ) [DT 0.020] [L0 7 ] [L1 ] [:,(unk)]
POC 9 TId: 0 ( P-SLICE, QP 50 ) [DT 0.020] [L0 8 ] [L1 ] [:,(unk)]
POC 10 TId: 0 ( P-SLICE, QP 47 ) [DT 0.020] [L0 9 ] [L1 ] [:,(unk)]
POC 11 TId: 0 ( P-SLICE, QP 46 ) [DT 0.021] [L0 10 ] [L1 ] [:,(unk)]
POC 12 TId: 0 ( P-SLICE, QP 50 ) [DT 0.020] [L0 11 ] [L1 ] [:,(unk)]
POC 13 TId: 0 ( P-SLICE, QP 46 ) [DT 0.020] [L0 12 ] [L1 ] [:,(unk)]
POC 14 TId: 0 ( P-SLICE, QP 46 ) [DT 0.022] [L0 13 ] [L1 ] [:,(unk)]
POC 15 TId: 0 ( P-SLICE, QP 49 ) [DT 0.021] [L0 14 ] [L1 ] [:,(unk)]
POC 16 TId: 0 ( P-SLICE, QP 47 ) [DT 0.020] [L0 15 ] [L1 ] [:,(unk)]
POC 17 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 16 ] [L1 ] [:,(unk)]
POC 18 TId: 0 ( P-SLICE, QP 47 ) [DT 0.022] [L0 17 ] [L1 ] [:,(unk)]
POC 19 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 18 ] [L1 ] [:,(unk)]
POC 20 TId: 0 ( P-SLICE, QP 47 ) [DT 0.021] [L0 19 ] [L1 ] [:,(unk)]
POC 21 TId: 0 ( P-SLICE, QP 46 ) [DT 0.021] [L0 20 ] [L1 ] [:,(unk)]
POC 22 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 21 ] [L1 ] [:,(unk)]
POC 23 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 22 ] [L1 ] [:,(unk)]
POC 24 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 23 ] [L1 ] [:,(unk)]
POC 25 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 24 ] [L1 ] [:,(unk)]
POC 26 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 25 ] [L1 ] [:,(unk)]
POC 27 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 26 ] [L1 ] [:,(unk)]
POC 28 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 27 ] [L1 ] [:,(unk)]
POC 29 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 28 ] [L1 ] [:,(unk)]
POC 30 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 29 ] [L1 ] [:,(unk)]
POC 31 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 30 ] [L1 ] [:,(unk)]
POC 32 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 31 ] [L1 ] [:,(unk)]
POC 33 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 32 ] [L1 ] [:,(unk)]
POC 34 TId: 0 ( P-SLICE, QP 46 ) [DT 0.021] [L0 33 ] [L1 ] [:,(unk)]
POC 35 TId: 0 ( P-SLICE, QP 46 ) [DT 0.020] [L0 34 ] [L1 ] [:,(unk)]
POC 36 TId: 0 ( P-SLICE, QP 46 ) [DT 0.020] [L0 35 ] [L1 ] [:,(unk)]
POC 37 TId: 0 ( P-SLICE, QP 46 ) [DT 0.020] [L0 36 ] [L1 ] [:,(unk)]
POC 38 TId: 0 ( P-SLICE, QP 46 ) [DT 0.020] [L0 37 ] [L1 ] [:,(unk)]
POC 39 TId: 0 ( P-SLICE, QP 46 ) [DT 0.020] [L0 38 ] [L1 ] [:,(unk)]
POC 40 TId: 0 ( P-SLICE, QP 46 ) [DT 0.020] [L0 39 ] [L1 ] [:,(unk)]
POC 41 TId: 0 ( P-SLICE, QP 46 ) [DT 0.020] [L0 40 ] [L1 ] [:,(unk)]
POC 42 TId: 0 ( P-SLICE, QP 46 ) [DT 0.021] [L0 41 ] [L1 ] [:,(unk)]
POC 43 TId: 0 ( P-SLICE, QP 46 ) [DT 0.021] [L0 42 ] [L1 ] [:,(unk)]
POC 44 TId: 0 ( P-SLICE, QP 46 ) [DT 0.021] [L0 43 ] [L1 ] [:,(unk)]
POC 45 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 44 ] [L1 ] [:,(unk)]
POC 46 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 45 ] [L1 ] [:,(unk)]
POC 47 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 46 ] [L1 ] [:,(unk)]
POC 48 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 47 ] [L1 ] [:,(unk)]
POC 49 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 48 ] [L1 ] [:,(unk)]
POC 50 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 49 ] [L1 ] [:,(unk)]
POC 51 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 50 ] [L1 ] [:,(unk)]
POC 52 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 51 ] [L1 ] [:,(unk)]
POC 53 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 52 ] [L1 ] [:,(unk)]
POC 54 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 53 ] [L1 ] [:,(unk)]
POC 55 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 54 ] [L1 ] [:,(unk)]
POC 56 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 55 ] [L1 ] [:,(unk)]
POC 57 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 56 ] [L1 ] [:,(unk)]
POC 58 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 57 ] [L1 ] [:,(unk)]
POC 59 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 58 ] [L1 ] [:,(unk)]
POC 60 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 59 ] [L1 ] [:,(unk)]
POC 61 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 60 ] [L1 ] [:,(unk)]
POC 62 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 61 ] [L1 ] [:,(unk)]
POC 63 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 62 ] [L1 ] [:,(unk)]
POC 64 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 63 ] [L1 ] [:,(unk)]
POC 65 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 64 ] [L1 ] [:,(unk)]
POC 66 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 65 ] [L1 ] [:,(unk)]
POC 67 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 66 ] [L1 ] [:,(unk)]
POC 68 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 67 ] [L1 ] [:,(unk)]
POC 69 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 68 ] [L1 ] [:,(unk)]
POC 70 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 69 ] [L1 ] [:,(unk)]
POC 71 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 70 ] [L1 ] [:,(unk)]
POC 72 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 71 ] [L1 ] [:,(unk)]
POC 73 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 72 ] [L1 ] [:,(unk)]
POC 74 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 73 ] [L1 ] [:,(unk)]
POC 75 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 74 ] [L1 ] [:,(unk)]
POC 76 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 75 ] [L1 ] [:,(unk)]
POC 77 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 76 ] [L1 ] [:,(unk)]
POC 78 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 77 ] [L1 ] [:,(unk)]
POC 79 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 78 ] [L1 ] [:,(unk)]
POC 80 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 79 ] [L1 ] [:,(unk)]
POC 81 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 80 ] [L1 ] [:,(unk)]
POC 82 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 81 ] [L1 ] [:,(unk)]
POC 83 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 82 ] [L1 ] [:,(unk)]
POC 84 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 83 ] [L1 ] [:,(unk)]
POC 85 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 84 ] [L1 ] [:,(unk)]
POC 86 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 85 ] [L1 ] [:,(unk)]
POC 87 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 86 ] [L1 ] [:,(unk)]
POC 88 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 87 ] [L1 ] [:,(unk)]
POC 89 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 88 ] [L1 ] [:,(unk)]
POC 90 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 89 ] [L1 ] [:,(unk)]
POC 91 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 90 ] [L1 ] [:,(unk)]
POC 92 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 91 ] [L1 ] [:,(unk)]
POC 93 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 92 ] [L1 ] [:,(unk)]
POC 94 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 93 ] [L1 ] [:,(unk)]
POC 95 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 94 ] [L1 ] [:,(unk)]
POC 96 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 95 ] [L1 ] [:,(unk)]
POC 97 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 96 ] [L1 ] [:,(unk)]
POC 98 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 97 ] [L1 ] [:,(unk)]
POC 99 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 98 ] [L1 ] [:,(unk)]
POC 100 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 99 ] [L1 ] [:,(unk)]
POC 101 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 100 ] [L1 ] [:,(unk)]
POC 102 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 101 ] [L1 ] [:,(unk)]
POC 103 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 102 ] [L1 ] [:,(unk)]
POC 104 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 103 ] [L1 ] [:,(unk)]
POC 105 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 104 ] [L1 ] [:,(unk)]
POC 106 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 105 ] [L1 ] [:,(unk)]
POC 107 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 106 ] [L1 ] [:,(unk)]
POC 108 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 107 ] [L1 ] [:,(unk)]
POC 109 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 108 ] [L1 ] [:,(unk)]
POC 110 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 109 ] [L1 ] [:,(unk)]
POC 111 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 110 ] [L1 ] [:,(unk)]
POC 112 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 111 ] [L1 ] [:,(unk)]
POC 113 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 112 ] [L1 ] [:,(unk)]
POC 114 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 113 ] [L1 ] [:,(unk)]
POC 115 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 114 ] [L1 ] [:,(unk)]
POC 116 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 115 ] [L1 ] [:,(unk)]
POC 117 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 116 ] [L1 ] [:,(unk)]
POC 118 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 117 ] [L1 ] [:,(unk)]
POC 119 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 118 ] [L1 ] [:,(unk)]
POC 120 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 119 ] [L1 ] [:,(unk)]
POC 121 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 120 ] [L1 ] [:,(unk)]
POC 122 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 121 ] [L1 ] [:,(unk)]
POC 123 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 122 ] [L1 ] [:,(unk)]
POC 124 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 123 ] [L1 ] [:,(unk)]
POC 125 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 124 ] [L1 ] [:,(unk)]
POC 126 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 125 ] [L1 ] [:,(unk)]
POC 127 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 126 ] [L1 ] [:,(unk)]
POC 128 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 127 ] [L1 ] [:,(unk)]
POC 129 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 128 ] [L1 ] [:,(unk)]
POC 130 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 129 ] [L1 ] [:,(unk)]
POC 131 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 130 ] [L1 ] [:,(unk)]
POC 132 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 131 ] [L1 ] [:,(unk)]
POC 133 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 132 ] [L1 ] [:,(unk)]
POC 134 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 133 ] [L1 ] [:,(unk)]
POC 135 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 134 ] [L1 ] [:,(unk)]
POC 136 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 135 ] [L1 ] [:,(unk)]
POC 137 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 136 ] [L1 ] [:,(unk)]
POC 138 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 137 ] [L1 ] [:,(unk)]
POC 139 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 138 ] [L1 ] [:,(unk)]
POC 140 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 139 ] [L1 ] [:,(unk)]
POC 141 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 140 ] [L1 ] [:,(unk)]
POC 142 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 141 ] [L1 ] [:,(unk)]
POC 143 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 142 ] [L1 ] [:,(unk)]
POC 144 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 143 ] [L1 ] [:,(unk)]
POC 145 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 144 ] [L1 ] [:,(unk)]
POC 146 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 145 ] [L1 ] [:,(unk)]
POC 147 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 146 ] [L1 ] [:,(unk)]
POC 148 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 147 ] [L1 ] [:,(unk)]
POC 149 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 148 ] [L1 ] [:,(unk)]
POC 150 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 149 ] [L1 ] [:,(unk)]
POC 151 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 150 ] [L1 ] [:,(unk)]
POC 152 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 151 ] [L1 ] [:,(unk)]
POC 153 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 152 ] [L1 ] [:,(unk)]
POC 154 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 153 ] [L1 ] [:,(unk)]
POC 155 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 154 ] [L1 ] [:,(unk)]
POC 156 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 155 ] [L1 ] [:,(unk)]
POC 157 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 156 ] [L1 ] [:,(unk)]
POC 158 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 157 ] [L1 ] [:,(unk)]
POC 159 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 158 ] [L1 ] [:,(unk)]
POC 160 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 159 ] [L1 ] [:,(unk)]
POC 161 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 160 ] [L1 ] [:,(unk)]
POC 162 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 161 ] [L1 ] [:,(unk)]
POC 163 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 162 ] [L1 ] [:,(unk)]
POC 164 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 163 ] [L1 ] [:,(unk)]
POC 165 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 164 ] [L1 ] [:,(unk)]
POC 166 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 165 ] [L1 ] [:,(unk)]
POC 167 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 166 ] [L1 ] [:,(unk)]
POC 168 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 167 ] [L1 ] [:,(unk)]
POC 169 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 168 ] [L1 ] [:,(unk)]
POC 170 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 169 ] [L1 ] [:,(unk)]
POC 171 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 170 ] [L1 ] [:,(unk)]
POC 172 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 171 ] [L1 ] [:,(unk)]
POC 173 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 172 ] [L1 ] [:,(unk)]
POC 174 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 173 ] [L1 ] [:,(unk)]
POC 175 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 174 ] [L1 ] [:,(unk)]
POC 176 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 175 ] [L1 ] [:,(unk)]
POC 177 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 176 ] [L1 ] [:,(unk)]
POC 178 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 177 ] [L1 ] [:,(unk)]
POC 179 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 178 ] [L1 ] [:,(unk)]
POC 180 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 179 ] [L1 ] [:,(unk)]
POC 181 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 180 ] [L1 ] [:,(unk)]
POC 182 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 181 ] [L1 ] [:,(unk)]
POC 183 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 182 ] [L1 ] [:,(unk)]
POC 184 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 183 ] [L1 ] [:,(unk)]
POC 185 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 184 ] [L1 ] [:,(unk)]
POC 186 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 185 ] [L1 ] [:,(unk)]
POC 187 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 186 ] [L1 ] [:,(unk)]
POC 188 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 187 ] [L1 ] [:,(unk)]
POC 189 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 188 ] [L1 ] [:,(unk)]
POC 190 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 189 ] [L1 ] [:,(unk)]
POC 191 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 190 ] [L1 ] [:,(unk)]
POC 192 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 191 ] [L1 ] [:,(unk)]
POC 193 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 192 ] [L1 ] [:,(unk)]
POC 194 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 193 ] [L1 ] [:,(unk)]
POC 195 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 194 ] [L1 ] [:,(unk)]
POC 196 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 195 ] [L1 ] [:,(unk)]
POC 197 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 196 ] [L1 ] [:,(unk)]
POC 198 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 197 ] [L1 ] [:,(unk)]
POC 199 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 198 ] [L1 ] [:,(unk)]
POC 200 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 199 ] [L1 ] [:,(unk)]
POC 201 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 200 ] [L1 ] [:,(unk)]
POC 202 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 201 ] [L1 ] [:,(unk)]
POC 203 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 202 ] [L1 ] [:,(unk)]
POC 204 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 203 ] [L1 ] [:,(unk)]
POC 205 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 204 ] [L1 ] [:,(unk)]
POC 206 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 205 ] [L1 ] [:,(unk)]
POC 207 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 206 ] [L1 ] [:,(unk)]
POC 208 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 207 ] [L1 ] [:,(unk)]
POC 209 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 208 ] [L1 ] [:,(unk)]
POC 210 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 209 ] [L1 ] [:,(unk)]
POC 211 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 210 ] [L1 ] [:,(unk)]
POC 212 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 211 ] [L1 ] [:,(unk)]
POC 213 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 212 ] [L1 ] [:,(unk)]
POC 214 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 213 ] [L1 ] [:,(unk)]
POC 215 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 214 ] [L1 ] [:,(unk)]
POC 216 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 215 ] [L1 ] [:,(unk)]
POC 217 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 216 ] [L1 ] [:,(unk)]
POC 218 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 217 ] [L1 ] [:,(unk)]
POC 219 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 218 ] [L1 ] [:,(unk)]
POC 220 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 219 ] [L1 ] [:,(unk)]
POC 221 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 220 ] [L1 ] [:,(unk)]
POC 222 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 221 ] [L1 ] [:,(unk)]
POC 223 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 222 ] [L1 ] [:,(unk)]
POC 224 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 223 ] [L1 ] [:,(unk)]
POC 225 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 224 ] [L1 ] [:,(unk)]
POC 226 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 225 ] [L1 ] [:,(unk)]
POC 227 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 226 ] [L1 ] [:,(unk)]
POC 228 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 227 ] [L1 ] [:,(unk)]
POC 229 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 228 ] [L1 ] [:,(unk)]
POC 230 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 229 ] [L1 ] [:,(unk)]
POC 231 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 230 ] [L1 ] [:,(unk)]
POC 232 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 231 ] [L1 ] [:,(unk)]
POC 233 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 232 ] [L1 ] [:,(unk)]
POC 234 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 233 ] [L1 ] [:,(unk)]
POC 235 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 234 ] [L1 ] [:,(unk)]
POC 236 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 235 ] [L1 ] [:,(unk)]
POC 237 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 236 ] [L1 ] [:,(unk)]
POC 238 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 237 ] [L1 ] [:,(unk)]
POC 239 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 238 ] [L1 ] [:,(unk)]
POC 240 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 239 ] [L1 ] [:,(unk)]
POC 241 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 240 ] [L1 ] [:,(unk)]
POC 242 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 241 ] [L1 ] [:,(unk)]
POC 243 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 242 ] [L1 ] [:,(unk)]
POC 244 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 243 ] [L1 ] [:,(unk)]
POC 245 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 244 ] [L1 ] [:,(unk)]
POC 246 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 245 ] [L1 ] [:,(unk)]
POC 247 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 246 ] [L1 ] [:,(unk)]
POC 248 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 247 ] [L1 ] [:,(unk)]
POC 249 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 248 ] [L1 ] [:,(unk)]
POC 250 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 249 ] [L1 ] [:,(unk)]
POC 251 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 250 ] [L1 ] [:,(unk)]
POC 252 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 251 ] [L1 ] [:,(unk)]
POC 253 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 252 ] [L1 ] [:,(unk)]
POC 254 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 253 ] [L1 ] [:,(unk)]
POC 255 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 254 ] [L1 ] [:,(unk)]
POC 256 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 255 ] [L1 ] [:,(unk)]
POC 257 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 256 ] [L1 ] [:,(unk)]
POC 258 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 257 ] [L1 ] [:,(unk)]
POC 259 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 258 ] [L1 ] [:,(unk)]
POC 260 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 259 ] [L1 ] [:,(unk)]
POC 261 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 260 ] [L1 ] [:,(unk)]
POC 262 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 261 ] [L1 ] [:,(unk)]
POC 263 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 262 ] [L1 ] [:,(unk)]
POC 264 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 263 ] [L1 ] [:,(unk)]
POC 265 TId: 0 ( P-SLICE, QP 44 ) [DT 0.023] [L0 264 ] [L1 ] [:,(unk)]
POC 266 TId: 0 ( P-SLICE, QP 44 ) [DT 0.022] [L0 265 ] [L1 ] [:,(unk)]
POC 267 TId: 0 ( P-SLICE, QP 44 ) [DT 0.022] [L0 266 ] [L1 ] [:,(unk)]
POC 268 TId: 0 ( P-SLICE, QP 44 ) [DT 0.022] [L0 267 ] [L1 ] [:,(unk)]
POC 269 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 268 ] [L1 ] [:,(unk)]
POC 270 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 269 ] [L1 ] [:,(unk)]
POC 271 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 270 ] [L1 ] [:,(unk)]
POC 272 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 271 ] [L1 ] [:,(unk)]
POC 273 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 272 ] [L1 ] [:,(unk)]
POC 274 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 273 ] [L1 ] [:,(unk)]
POC 275 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 274 ] [L1 ] [:,(unk)]
POC 276 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 275 ] [L1 ] [:,(unk)]
POC 277 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 276 ] [L1 ] [:,(unk)]
POC 278 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 277 ] [L1 ] [:,(unk)]
POC 279 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 278 ] [L1 ] [:,(unk)]
POC 280 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 279 ] [L1 ] [:,(unk)]
POC 281 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 280 ] [L1 ] [:,(unk)]
POC 282 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 281 ] [L1 ] [:,(unk)]
POC 283 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 282 ] [L1 ] [:,(unk)]
POC 284 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 283 ] [L1 ] [:,(unk)]
POC 285 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 284 ] [L1 ] [:,(unk)]
POC 286 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 285 ] [L1 ] [:,(unk)]
POC 287 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 286 ] [L1 ] [:,(unk)]
POC 288 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 287 ] [L1 ] [:,(unk)]
POC 289 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 288 ] [L1 ] [:,(unk)]
POC 290 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 289 ] [L1 ] [:,(unk)]
POC 291 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 290 ] [L1 ] [:,(unk)]
POC 292 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 291 ] [L1 ] [:,(unk)]
POC 293 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 292 ] [L1 ] [:,(unk)]
POC 294 TId: 0 ( P-SLICE, QP 45 ) [DT 0.022] [L0 293 ] [L1 ] [:,(unk)]
POC 295 TId: 0 ( P-SLICE, QP 44 ) [DT 0.022] [L0 294 ] [L1 ] [:,(unk)]
POC 296 TId: 0 ( P-SLICE, QP 44 ) [DT 0.022] [L0 295 ] [L1 ] [:,(unk)]
POC 297 TId: 0 ( P-SLICE, QP 44 ) [DT 0.022] [L0 296 ] [L1 ] [:,(unk)]
POC 298 TId: 0 ( P-SLICE, QP 44 ) [DT 0.022] [L0 297 ] [L1 ] [:,(unk)]
POC 299 TId: 0 ( P-SLICE, QP 45 ) [DT 0.021] [L0 298 ] [L1 ] [:,(unk)]
Total Time: 12.968 sec.
It is not good in udp streaming because there is no I frames afterward, when one frame is not well decoded, the reset cannot be decoded.
We are checking why SliceIntraRefreshInterval=30 does not take effect.
