Compilation of hdf5-1.8.11 on debian squeeze with v13.6 completes successfully, but
$ make check
fails with:
Testing with new file format: FAILED
HDF5-DIAG: Error detected in HDF5 (1.8.11) thread 0: #000: H5F.c line 1500 in H5Fcreate(): unable to create file
major: File accessibilty
minor: Unable to open file #001: H5F.c line 1303 in H5F_open(): unable to truncate a file which is already open
I just download and built HDF5 1.8.11 with 13.6 but wasn’t able to recreate the error. What configure/environment options did you use? I just set the compilers but didn’t add anything else. Could there be a problem with your system?
Hi Mat,
It must be a problem with this system (AMD bulldozer) system, as ‘make check’ works on another (AMD, not bulldozer) debian ‘squeeze’ system. Will post more later after looking around some more…
