When I installed the pgf yesterday, I was able to run my model by using ‘make’. I did something (to try to solve other problems), and it’s not working anymore. The message is saying
make[1]: pgf90: Command not found
This morning I changed $PATH, and it might have caused the problem. However, I have no idea.
What should I do to make my machine to recognize pgf90/pgf77 that I installed?
If, for example, you
untar the compilers in /tmp/pgi,
and install them in /opt/pgi,
and the license is placed in /opt/pgi/license.dat
A shorthand of the setup and installation.
untar the gunzip’d download into an empty area
like /tmp/pgi
run
/tmp/pgi/install
targetting the final /opt/pgi
set up your configuration.
setenv PGI /opt/pgi
set path=($PGI/linux86/7.0/bin $path) ! for 32-bit by default
set path=($PGI/linux86-64/7.0/bin $path) ! for 64-bit by default
setenv LM_LICENSE_FILE $PGI/license.dat
or in bash
export PGI=/opt/pgi
export PATH=$PGI/linux86/7.0/bin:$PATH ! for 32-bit
export PATH=$PGI/linux86-64/7.0/bin:$PATH ! for 64-bit
export LM_LICENSE_FILE=$PGI/license.dat
