I just received the license key these days and tried to install the PGI toolset, but failed.
I am a little bit confused about several things here.
I followed the installation guide step by step so I ran the installation script in the file. And when it come into “generate the license for this computer”, I answered “yes”, and provide my account id and password, and the generation failed .
I received the license key via email and has nothing to do with my current account. Is it the reason to fail ?
Except this, the installation went smoothly. I set the environment variable as said in the installation guide.
About the license, I simply create a “license.dat” file under the $PGI and copy the license key that I got.
I could use “pgcc -V” to see the version of the pgcc. However when I compiled some samples provided in the files, it indicate :
“pgcc: Command not found”
I am confused about the license key here and why the command not found ?
Can you help me to make it straight here ?
