I am currently only wanting to take your compiler for a test drive.
I am using a 4-way Opteron board with Gentoo Linux (although that shouldn’t really matter as I know my way around Linux very well.)
Issue 1. When I run the install script PGI provides, it does exactly what the instructions say it will, I then include which user the compiler will be licensed to and everything seems to go fine. But when I try and use the compiler, it gives me this error;
pgcc-linux86-64: LICENSE MANAGER PROBLEM: Cannot find license file.
The license files (or license server system network addresses) attempted are
are listed below. Use LM_LICENSE_FILE to use a different license file,
or contact your software provider for a license file.
Feature: pgcc-linux86-64
Filename: ./license.dat
License path: ./license.dat
FLEXnet Licensing error:-1,359. System Error: 2 "No such file or directory"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
Now that would be all fine and dandy if I was using Flex…but I’m not, nor do I wish to at the moment. I was trying to use the PGI-style licensing, and the instructions (much to my dismay) give no indication that ignoring the Flex instructions would cause an issue.
Once installed, you need to set-up your environment as described in section 1.3 of the ‘INSTALL.txt’ file that accompanies your installation (It can also be found here). The short version is that you need to set the PGI and LM_LICENSE_FILE environment variables, see below. Note that this presumes that selected ‘yes’ when asked if you want to create an evaluation license. If for some reason that a license.dat file was not created, please feel free to send a note to trs@pgroup.com and they will send you a temporary license file.
Thanks,
Mat
From INSTALL.txt:
…Assume the license file is in /usr/pgi/license.dat, … Each user should do the following before running the compilers. In csh
The order that you’re supposed to do it in is off in your instructions that come with the download. You may want to give them in that exact order you just did here.
The order is important since I followed this order:
Odd. Order shouldn’t matter unless your using ‘$PGI’ in the LM_LICENSE_FILE path. The commands you executed should work as well. Granted, the specific syntax depends on your shell.
