Hardware-decoding of MJPEG
I am trying to process MJPEG streams with gstreamer. Doing it in software it works:
gst-launch-1.0 videotestsrc ! jpegenc ! jpegdec ! autovideosink
Unfortunately, it leaks memory. When we saw the same under h264, we fixed it with hardware decoding. The following attempts just display the first frame and freeze:
gst-launch-1.0 videotestsrc ! jpegenc ! nvjpegdec ! autovideosink
gst-launch-1.0 videotestsrc ! nvjpegenc ! nvjpegdec ! videoconvert ! autovideosink
gst-launch-1.0 videotestsrc ! nvjpegenc ! jpegparse ! nvjpegdec ! videoconvert ! autovideosink
The same happens with nvv4l2decoder
gst-launch-1.0 videotestsrc ! jpegenc ! nvv4l2decoder  ! nvvidconv ! videoconvert ! autovideosink
gst-launch-1.0 videotestsrc ! jpegenc ! jpegparse ! nvv4l2decoder ! nvvidconv ! videoconvert ! autovideosink
There are no error messages, and the hardware decoders turn on, but the pipeline is frozen. I have checked the capabilities with gst-inspect, and they should match.
Any ideas?
Jetson Orin Nano dev kit:
GStreamer 1.16.3
L4J: 35.4.1
Jetpack: 5.1.2
Also tried, following the advice from Honey_Patouceul](Gstreamer pipeline for MJPEG RTSP stream):
Stuck on first frame:
gst-launch-1.0 videotestsrc ! jpegenc ! jpegparse ! nvjpegdec ! 'video/x-raw(memory:NVMM),format=I420' ! nvvidconv ! autovideosink
gst-launch-1.0 videotestsrc ! nvjpegenc ! jpegparse ! nvjpegdec ! 'video/x-raw(memory:NVMM),format=I420' ! nvvidconv ! autovideosink
gst-launch-1.0 videotestsrc ! nvjpegenc ! jpegparse ! nvjpegdec ! 'video/x-raw(memory:NVMM),format=I420' ! nvvidconv ! videoconvert !  autovideosink
Data stream error:
gst-launch-1.0 videotestsrc ! nvjpegenc ! nvv4l2decoder mjpeg=1 ! nvvidconv ! video/x-raw,format=BGRx ! videoconvert ! video/x-raw,format=BGR ! autovideosink
gst-launch-1.0 videotestsrc ! nvjpegenc ! jpegparse ! nvjpegdec ! 'video/x-raw(memory:NVMM),format=I420' ! nvvidconv ! video/x-raw,format=BGRx ! videoconvert ! video/x-raw,format=BGR ! autovideosink
Erroneous pipeline:
gst-launch-1.0 videotestsrc ! jpegenc ! jpegparse ! nvvidconv ! video/x-raw,format=BGRx ! videoconvert ! video/x-raw,format=BGR ! autovideosink
gst-launch-1.0 videotestsrc ! jpegenc ! nvvidconv ! video/x-raw,format=BGRx ! videoconvert ! video/x-raw,format=BGR ! autovideosink
gst-launch-1.0 videotestsrc ! nvjpegenc ! jpegparse ! nvvidconv ! video/x-raw,format=BGRx ! videoconvert ! video/x-raw,format=BGR ! autovideosink
gst-launch-1.0 videotestsrc ! nvjpegenc ! nvvidconv ! video/x-raw,format=BGRx ! videoconvert ! video/x-raw,format=BGR ! autovideosink
Orin Nano does not have hardware encoder, so please not to use nvjpegenc.
And there is a known issue about MJPEG decoding on Jetpack 5.1.2. Please use Jetpack 5.1.3.
Same behaviour after upgrading.
I have gotten some help off the forums:
gst-launch-1.0 videotestsrc ! nvjpegenc ! nvv4l2decoder mjpeg=1 ! nvvidconv ! autovideosink
This works under both 5.1.2 and .3, despite using nvjpegenc, and with better perfromance than raw jpegenc, although they are both interchangeable.
Please try nvjpegdec plugin in Jetpack 5.1.3. We have some fix in the plugin.
Can you share an example pipeline using nvpegdec? The ones I posted earlier are stuck.
Please try the command:
$ DISPLAY=:0 gst-launch-1.0 videotestsrc is-live=1 ! jpegenc ! queue ! jpegparse ! nvjpegdec mjpegdecode=1 ! video/x-raw ! xvimagesink sync=0
Same problem, the first frame is displayed, but nothing else, although both HW decoders turn on.
Does it work on your end?
We noticed MJPEG decoding through nvjpegdec in gstreamer, or NvJpegDecoder in jetson_multiemdia_api, still does not work well on Jetpack 5.1.3. Will check further and update.
Please apply this:
NvJPEGDecoder generates the same output if called twice with different input buffer - #7 by DaneLLL
And try the command:
This one works, but it is glitchy (it flickers on an off). Also, when stress-testing at FHD, I get 11 fps, but the nvv4l2decoder-based pipeline gets 18, without flicker.
If the source JPEG files are not compressed from YUV420, we would suggest use nvv4l2decoder mjpeg=1
