Hi I am trying the below pipeline which worked fine in previous jetson nano firmware version 32.4.4 with the libnvtvmr.so file patched. NowI get an error when running the pipeleine. I also tried before replacing the file now get the error after replacing the file also.
gst-launch-1.0 -e v4l2src device=/dev/video0 ! tee name=t1 t1. ! queue ! video/x-raw, width=1920, height=1080, framerate=30/1 ! nvvidconv ! queue ! nvv4l2h264enc maxperf-enable=1 bitrate=4000000 profile=4 ! queue ! h264parse ! queue ! mux. pulsesrc device=“alsa_input.usb-VXIS_Inc_ezcap_U3_capture-02.analog-stereo” ! queue ! audio/x-raw,width=16,depth=16,rate=44100,channel=1 ! audioconvert ! voaacenc ! aacparse ! mpegtsmux name=mux ! filesink location=feed1mp1080HW1TS.ts t1. ! queue ! video/x-raw, width=1920, height=1080, framerate=30/1 ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),width=959,height=540,framerate=30/1,format=NV12” ! queue ! nvoverlaysink overlay-x=0 overlay-y=270 overlay-w=959 overlay-h=540 overlay=1 v4l2src device=/dev/video2 io-mode=2 do-timestamp=true ! tee name=t2 t2. ! queue ! image/jpeg,width=1920,height=1080,framerate=30/1 ! videorate ! image/jpeg,width=1920,height=1080,framerate=30/1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! video/x-raw,width=1920,height=1080,framerate=30/1 ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),framerate=30/1,format=NV12” ! nvv4l2h264enc maxperf-enable=1 bitrate=4000000 profile=4 ! queue ! h264parse ! queue ! mpegtsmux ! filesink location=feed2mp1080HW1TS.ts t2. ! queue ! image/jpeg,width=1920,height=1080,framerate=30/1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! video/x-raw,framerate=30/1 ! nvvidconv ! queue ! “video/x-raw(memory:NVMM),framerate=30/1,format=NV12” ! queue ! nvoverlaysink overlay-x=960 overlay-y=270 overlay-w=960 overlay-h=540 overlay=2
Setting pipeline to PAUSED …
Opening in BLOCKING MODE
Caught SIGSEGV
#0 0x0000007f81933d5c in __waitpid (pid=, stat_loc=0x7ffee6ce04, options=) at …/sysdeps/unix/sysv/linux/waitpid.c:30
#1 0x0000007f8196f2e0 in g_on_error_stack_trace ()
#2 0x000000557a4e7c3c in ()
#3 0x0000000000008600 in ()
Spinning. Please run ‘gdb gst-launch-1.0 11893’ to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
