I’m trying to record a single mkv video from two UVC cameras attached to the Jetson Orin NX using the nvidia gstreamer plugins. The acquisition and encoding of individual streams works perfectly with v4l2src, but as soon as I try to mux two different cameras into one container, I get unexpected dependency issues. Also nvv4l2camerasrc does not support the input format of my UVC cameras.
gst-launch-1.0 -e \
v4l2src device=/dev/video1 ! \
queue ! nvvidconv ! nvv4l2h264enc ! h264parse ! queue ! mux.video_0 \
v4l2src device=/dev/video3 ! \
queue ! nvvidconv ! nvv4l2h264enc ! h264parse ! queue ! mux.video_1 \
matroskamux name=mux ! filesink location=output.mkv
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
gst-launch-1.0: symbol lookup error: /usr/lib/aarch64-linux-gnu/nvidia/libnvargus.so: undefined symbol: jpeg_destroy_compress
However these pipelines work individually
gst-launch-1.0 -e \
v4l2src device=/dev/video{1,3} ! \
queue name=videoqueue1 ! nvvidconv ! nvv4l2h264enc ! h264parse ! queue ! matroskamux name=mux ! filesink location=output.mkv
If I use nvv4l2camerasrc the acquisition works, but none of my UVC camera sources support YUYV, so the video does not contain any valid data …
gst-launch-1.0 -e \
nvv4l2camerasrc device=/dev/video1 ! \
queue name=videoqueue1 ! nvvidconv ! nvv4l2h264enc ! h264parse ! queue ! mux.video_0 \
nvv4l2camerasrc device=/dev/video3 ! \
queue name=videoqueue2 ! nvvidconv ! nvv4l2h264enc ! h264parse ! queue ! mux.video_1 \
NvMMLiteOpen : Block : BlockType = 4
===== NvVideo: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
Pipeline is live and does not need PREROLL ...
Redistribute latency...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
H264: Profile = 66 Level = 0
NVMEDIA: Need to set EMC bandwidth : 846000
NvVideo: bBlitMode is set to TRUE
^Chandling interrupt.
Interrupt: Stopping pipeline ...
EOS on shutdown enabled -- Forcing EOS on the pipeline
Waiting for EOS...
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:01.850706139
Setting pipeline to NULL ...
Freeing pipeline ...
… and the nvidia source only supports UYVY …
Factory Details:
Rank primary (256)
Long-name NvV4l2CameraSrc
Klass Video/Capture
Description Nvidia V4l2 Camera Source
Author Ashwin Deshpande <ashwind@nvidia.com>
Plugin Details:
Name nvv4l2camerasrc
Description Nvidia v4l2 Source Component
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvv4l2camerasrc.so
Version 1.14.5
License Proprietary
Source module nvv4l2camerasrc
Binary package NvV4l2CameraSrc
Origin URL http://nvidia.com/
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstBaseSrc
+----GstNvV4l2CameraSrc
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
video/x-raw(memory:NVMM)
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
format: { (string)UYVY }
interlace-mode: { (string)progressive, (string)interlaced }
framerate: [ 0/1, 2147483647/1 ]
and my cameras only support different encodings at source …
v4l2-ctl -d /dev/video1 --all
Format Video Capture:
Width/Height : 640/512
Pixel Format : 'NV12' (Y/CbCr 4:2:0)
Field : None
Bytes per Line : 640
Size Image : 491520
Colorspace : Default
Transfer Function : Default (maps to Rec. 709)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :
and
v4l2-ctl -d /dev/video3 --all
Width/Height : 640/480
Pixel Format : 'YUYV' (YUYV 4:2:2)
Field : None
Bytes per Line : 1280
Size Image : 614400
Colorspace : sRGB
Transfer Function : Rec. 709
YCbCr/HSV Encoding: ITU-R 601
Flags :
We are using the following Jetpack on a Jetson Orin NX 8GB
cat /etc/nv_tegra_release
# R36 (release), REVISION: 4.0, GCID: 37537400, BOARD: generic, EABI: aarch64, DATE: Fri Sep 13 04:36:44 UTC 2024
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
uname -a
Linux labforge-orinnx 5.15.148-tegra #125 SMP PREEMPT Tue Nov 19 09:23:11 EST 2024 aarch64 aarch64 aarch64 GNU/Linux
How can I acquire two streams into a single container in the same process? I need to synchronize other sensor inputs with the video-feed, so I’d rather not have to worry about synchronizing two independent gstreamer processes. This eventually has to go into a Python deepstream application.
It is also unclear to me why libargus has to get involved when streaming from UVC cameras? It also seems to have all the dependencies installed
ldd /usr/lib/aarch64-linux-gnu/nvidia/libnvargus.so
linux-vdso.so.1 (0x0000ffffa4b98000)
libEGL.so.1 => /lib/aarch64-linux-gnu/libEGL.so.1 (0x0000ffffa49b0000)
libnvvic.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvvic.so (0x0000ffffa4980000)
libnvscf.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvscf.so (0x0000ffffa41f0000)
libnvcamerautils.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvcamerautils.so (0x0000ffffa41b0000)
libnvrm_mem.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_mem.so (0x0000ffffa4190000)
libnvrm_sync.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_sync.so (0x0000ffffa4170000)
libnvrm_host1x.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_host1x.so (0x0000ffffa4140000)
libnvrm_surface.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_surface.so (0x0000ffffa4100000)
libnvos.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvos.so (0x0000ffffa40d0000)
libnvbufsurface.so.1.0.0 => /usr/lib/aarch64-linux-gnu/nvidia/libnvbufsurface.so.1.0.0 (0x0000ffffa4000000)
libnvcameratools.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvcameratools.so (0x0000ffffa3f60000)
libnvjpeg.so => /usr/local/cuda/targets/aarch64-linux/lib/libnvjpeg.so (0x0000ffffa3b70000)
libstdc++.so.6 => /lib/aarch64-linux-gnu/libstdc++.so.6 (0x0000ffffa3940000)
libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x0000ffffa38a0000)
libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000ffffa36f0000)
/lib/ld-linux-aarch64.so.1 (0x0000ffffa4b5f000)
libGLdispatch.so.0 => /lib/aarch64-linux-gnu/libGLdispatch.so.0 (0x0000ffffa3560000)
libnvrm_stream.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_stream.so (0x0000ffffa3540000)
libnvsocsys.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvsocsys.so (0x0000ffffa3520000)
libnvcolorutil.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvcolorutil.so (0x0000ffffa34f0000)
libnvmedia_isp_ext.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvmedia_isp_ext.so (0x0000ffffa34b0000)
libnvisppg.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvisppg.so (0x0000ffffa33a0000)
libcuda.so.1 => /usr/lib/aarch64-linux-gnu/nvidia/libcuda.so.1 (0x0000ffffa0b30000)
libnvcamlog.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvcamlog.so (0x0000ffffa0b10000)
libnvfnetstoredefog.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvfnetstoredefog.so (0x0000ffffa0ac0000)
libnvfnet.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvfnet.so (0x0000ffffa0a00000)
libnvfnetstorehdfx.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvfnetstorehdfx.so (0x0000ffffa09d0000)
libnvrm_chip.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_chip.so (0x0000ffffa09b0000)
libnvodm_imager.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvodm_imager.so (0x0000ffffa0450000)
libnvcapture.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvcapture.so (0x0000ffffa03e0000)
libGLESv2.so.2 => /lib/aarch64-linux-gnu/libGLESv2.so.2 (0x0000ffffa03a0000)
libnvmm_utils.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvmm_utils.so (0x0000ffffa0370000)
libnvtvmr.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvtvmr.so (0x0000ffffa0270000)
libnvphs.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvphs.so (0x0000ffffa0240000)
libnvfusacap.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvfusacap.so (0x0000ffffa01f0000)
libgcc_s.so.1 => /lib/aarch64-linux-gnu/libgcc_s.so.1 (0x0000ffffa01c0000)
libnvsciipc.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvsciipc.so (0x0000ffffa0180000)
libnvbuf_fdmap.so.1.0.0 => /usr/lib/aarch64-linux-gnu/nvidia/libnvbuf_fdmap.so.1.0.0 (0x0000ffffa0160000)
libnvrm_gpu.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvrm_gpu.so (0x0000ffffa00e0000)
libnvcam_imageencoder.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvcam_imageencoder.so (0x0000ffffa00b0000)
librt.so.1 => /lib/aarch64-linux-gnu/librt.so.1 (0x0000ffffa0090000)
libpthread.so.0 => /lib/aarch64-linux-gnu/libpthread.so.0 (0x0000ffffa0070000)
libdl.so.2 => /lib/aarch64-linux-gnu/libdl.so.2 (0x0000ffffa0050000)
libnvisp.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvisp.so (0x0000ffff9ff60000)
libexpat.so.1 => /lib/aarch64-linux-gnu/libexpat.so.1 (0x0000ffff9ff20000)
libnvcamv4l2.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvcamv4l2.so (0x0000ffff9fef0000)
libnvtegrahv.so => /usr/lib/aarch64-linux-gnu/nvidia/libnvtegrahv.so (0x0000ffff9fed0000)
including the needed dependencies for the Jpeg library
ldd /usr/local/cuda/targets/aarch64-linux/lib/libnvjpeg.so
linux-vdso.so.1 (0x0000ffff9acf2000)
librt.so.1 => /lib/aarch64-linux-gnu/librt.so.1 (0x0000ffff9a880000)
libpthread.so.0 => /lib/aarch64-linux-gnu/libpthread.so.0 (0x0000ffff9a860000)
libdl.so.2 => /lib/aarch64-linux-gnu/libdl.so.2 (0x0000ffff9a840000)
libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x0000ffff9a7a0000)
libgcc_s.so.1 => /lib/aarch64-linux-gnu/libgcc_s.so.1 (0x0000ffff9a770000)
libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000ffff9a5c0000)
/lib/ld-linux-aarch64.so.1 (0x0000ffff9acb9000)
