Hardware latency configuration of gpio
hello:
I use r3541 version , use Linux API functions gpiod_set_debounce, When using a 10ms, 1Hz cycle PWM test, blocking GPIO cannot be performed and interrupts will still occur. From the results, use 20ms setting, it seems that it did not play a role in hardware stabilization. The order of executing the relevant code is as follows:
//device tree
input-gpios = <&tegra_main_gpio  IN_1 	GPIO_ACTIVE_HIGH>,
    	              <&tegra_main_gpio  IN_2 	GPIO_ACTIVE_HIGH>;
//Driver code
gdev->input_gpios = devm_gpiod_get_array(dev, "output", GPIOD_OUT_LOW);
gdev->num_inputs = gdev->input_gpios->ndescs;
gpiod_set_debounce(gdev->input_gpios->desc[0], 20000);
gdev->irq_nums = devm_kzalloc(dev, sizeof(int) *  gdev->num_inputs, GFP_KERNEL);
gdev->irq_nums[i] = gpiod_to_irq(gdev->input_gpios->desc[i]);
ret = devm_request_irq(dev, gdev->irq_nums[i], gpio_irq_handler,
                                   IRQF_ONESHOT | IRQF_TRIGGER_RISING, IRQ_NAME, gdev);
I want to confirm if this function is supported by SOC and what is the range of hardware jitter parameter values that can be configured? very thanks.
Hi asfsdgag,
Are you using the devkit or custom board for Orin NX?
May I know what’s your use case? Do you want to reduce the HW latency of GPIO interrupt?
hello:
thank you, I use custom board, It’s another hardware issue that has been resolved.
