Have you decided if/when you will support AV1 10-bit encoding?
Is it on the roadmap?
If it’s the same chip as desktop, then the hardware can handle it.
It is under review and there is no concrete schedule. Could you please share the business opportunity for your use-case? It would be great if you can share more information.
Less a business case and more just wanting the highest quality possible.
Ideally you’d make the Video SDK work on Linux arm64, rather than have these two entirely different APIs to achieve the same thing.
The Video SDK is better documented and way less of a headache than trawling through all these legacy V4l2 samples that appear to have gone through multiple iterations/hacks.
Thanks for your comments, will try to update you once there is concrete schedule.
