HBN 3.3.0 silently drops decapsulated VXLAN frames from non-HBN Linux VTEP peer despite EVPN routes being learned — is this supported?
Question: Is HBN 3.3.0 expected to interoperate with a standard Linux kernel VXLAN + FRR EVPN peer? If yes, what am I missing in the config? If no, is there any documentation stating this limitation?
Setup
  • DPU: 2× BlueField-3
  • HBN version: 3.3.0 (DOCA 3.3, Ubuntu 22.04 BFB)
  • Peer: One standard x86 Linux node running:
    • Kernel VXLAN (netlink, nolearning, EVPN mode)
    • VLAN-aware bridge (vlan_filtering 1)
    • FRR 8.5.3 with bgpd, zebra, staticd
    • Peer is NOT running HBN, just plain Linux
  • All three nodes on the same underlay /24, iBGP AS 65001 full mesh
  • L2 VNI 10002 mapped to VLAN 102 on all three peers
What works
  1. DPU ↔ DPU L2 VNI 10002 traffic — fully functional, hardware-accelerated
  2. BGP EVPN sessions Established between all three peers (2 DPUs + 1 Linux peer)
  3. EVPN Type-2 and Type-3 routes exchanged correctly. From FRR on the Linux peer:
$ sudo vtysh -c "show bgp l2vpn evpn summary"
Neighbor        V   AS   MsgRcvd  MsgSent   State/PfxRcd
<DPU1>          4 65001  ...      ...       Established/4
<DPU2>          4 65001  ...      ...       Established/0
  1. Linux peer’s kernel FDB is correctly populated by FRR from EVPN:
$ bridge fdb show dev vxlan102 | grep extern
<MAC-behind-DPU1> vlan 102 extern_learn master br0
<MAC-behind-DPU1> dst <DPU1-underlay-IP> self extern_learn
  1. Linux peer’s ARP cache is populated by EVPN Type-2 (ARP suppression):
$ ip neigh show dev vlan102
<endpoint-IP> lladdr <MAC-behind-DPU1> extern_learn NOARP proto zebra
What fails
Ping from Linux peer’s SVI to an endpoint behind DPU1 fails 100%.
Wire capture on Linux peer’s underlay — packet is properly encapsulated unicast (thanks to EVPN Type-2 giving MAC→VTEP mapping):
IP <linux-peer>.59873 > <DPU1>.4789: VXLAN, flags [I] (0x08), vni 10002
    IP <linux-peer-svi> > <endpoint-behind-dpu1>: ICMP echo request
Inside HBN container — tcpdump on p0_if and br_default:
p0_if      P    IP <linux-peer>.59873 > <DPU1>.4789: VXLAN vni 10002, ICMP ...
br_default In   IP <linux-peer>.59873 > <DPU1>.4789: VXLAN vni 10002, ICMP ...
Packet arrives at the uplink AND enters the kernel bridge.
Inside HBN container — tcpdump on pf0hpf_if:
(no output — 0 packets)
The decapsulated frame never reaches the host PF representor. It is silently dropped somewhere between br_defaultand pf0hpf_if.
For comparison, DPU1 → local host via pf0hpf_if works normally:
$ tcpdump -i pf0hpf_if -nn arp
ARP Request who-has <endpoint-IP> tell <HBN-SVI-IP>
ARP Reply <endpoint-IP> is-at <MAC-behind-DPU1>
So the pf0hpf_if path is not broken — only traffic decapsulated from the non-HBN VTEP is dropped.
HBN config (relevant excerpts)
nv set bridge domain br_default type vlan-aware
nv set bridge domain br_default vlan 102 vni 10002
nv set interface p0_if bridge domain br_default
nv set interface pf0hpf_if bridge domain br_default access 102
nv set nve vxlan enable on
nv set nve vxlan mac-learning off
nv set nve vxlan source address <DPU1-underlay-IP>
nv set nve vxlan arp-nd-suppress off
nv set evpn enable on
nv set router bgp enable on
nv set router bgp autonomous-system 65001
nv set vrf default router bgp peer-group fabric remote-as 65001
nv set vrf default router bgp peer-group fabric address-family l2vpn-evpn enable on
nv set vrf default router bgp neighbor <DPU2-underlay-IP> peer-group fabric
nv set vrf default router bgp neighbor <linux-peer-underlay-IP> peer-group fabric
Diagnostic evidence
HBN bridge fdb show shows the Linux peer as a static HER destination:
00:00:00:00:00:00 dev vxlan48 dst <linux-peer> src_vni 10002 self permanent
HBN software-tables/17 (nl2docad ASIC bridge table) contains the Linux peer’s SVI MAC:
"dst mac":"<linux-peer-svi-mac>"
So the MAC IS programmed into the ASIC bridge table. But the packet still doesn’t egress pf0hpf_if.
vxlan48 bridge port flags look normal:
71: vxlan48 ... master br_default state forwarding
    learning on flood on mcast_flood on bcast_flood on
    neigh_suppress off
nl2doca daemon is running:
$ supervisorctl status nl2doca
nl2doca   RUNNING   pid <PID>, uptime <T>
Things tried (none worked)
  1. supervisorctl restart nl2doca
  2. Static FDB entry bridge fdb add <linux-peer-svi-mac> dev vxlan48 dst <linux-peer> src_vni 10002 self permanent
  3. Stopping nl2doca entirely (to force software forwarding) — still no packet on pf0hpf_if
  4. Full teardown and rebuild of VLAN 102 config on HBN
  5. Toggling arp-nd-suppress, mac-learning, bridge port flags
  6. Verified peer firewall is not blocking (no drops on inbound path)
  7. Verified no MTU mismatch (all interfaces MTU 9216)
Release notes review
I read the HBN 3.4.0 release notes carefully. None of the following bugs match my symptom:
  • 3865633 (open) — describes drops of host-generated UDP:4789 WITHOUT valid VXLAN encap. My packets ARE properly encapsulated and originate from an external peer.
  • 4214631 (fixed in 3.0.0) — host-side originated 4789 drops in L3-EVPN. Wrong direction.
  • 4264397 (fixed in 3.0.0) — IPv6 NA-with-unicast-MAC not punted. Different protocol (I’m using IPv4).
  • 2821785 (open) — hardware MAC learning limitation. But that’s just a performance note, not a silent drop.
  • 4991261 (3.4.0 known) — stale VNI after L3 VRF change. Not applicable, my VNI is stable.
I could not find any statement in the HBN documentation about whether non-HBN Linux VTEPs are supported peers.
Questions
  1. Is HBN 3.3.0 expected to accept and forward VXLAN traffic from a non-HBN (plain Linux kernel + FRR) VTEP peer?
  2. If yes — what am I missing in the HBN or FRR config?
  3. If no — is this documented anywhere I should have found?
  4. Would upgrading to HBN 3.4.0 change this behavior? (No 3.4.0 bug fix in the release notes seems to target this scenario.)
  5. Is there any punt-path debug I can enable on nl2docad to see WHY the decapsulated frame is being dropped between br_default and pf0hpf_if?
Thanks in advance for any insight. Happy to share full sos reports, pcaps, and hbn-support archives with anyone from the engineering team who wants to look at this.
Update — additional testing with OVS-DOCA + switchdev + DPDK (NVIDIA-native peer)
To rule out the possibility that this is a kernel-VXLAN-specific issue, I rebuilt the Linux peer using a fully NVIDIA-native stack:
  • ConnectX-6 Dx PF in switchdev mode (devlink dev eswitch set pci/... mode switchdev)
  • openvswitch-doca 2.8.0 (0091_24.07_based_3.3.0) with datapath_type=netdev
  • MLNX_DPDK 22.11.2407.1.0 with DOCA 2.8.0082 initialized (hw-offload=true, doca-init=true)
  • OVS bridge with:
    • VF representors (_pf0vf0..3)
    • PF as trunk port carrying VLANs 1600, 2000, 102
    • Internal ports for mgmt / underlay / tenant SVI
    • VXLAN tunnel port (type=vxlan, key=10002, local_ip=<peer-underlay>, remote_ip=flow)
OVS reports offloaded flows correctly (offloaded packets: 41.02% (130237/317514)) and the DPDK PMD is running on a pinned core.
Same failure mode reproduces
Ping from the tenant SVI to the endpoint behind DPU1 still fails 100%. Wire captures on the peer’s underlay confirm VXLAN packets leave the peer.
But critically — on HBN’s p0_if (inside container), tcpdump -i p0_if -nn -e -c 10 vlan 102 sees:
  • No VLAN 102 traffic from our peer at all
  • Only ambient VLAN 3952-3957 broadcasts from other tenants
  • BGP TCP on VLAN 2000 (underlay) works fine
The switchdev-mode peer’s traffic reaches the same fate as the kernel-VXLAN peer’s traffic.
New evidence — MAC mobility FDB corruption on HBN
The most interesting finding. Inside HBN container:
$ bridge fdb show | grep <peer-svi-mac>
<peer-svi-mac> dev vxlan48 vlan 102 extern_learn master br_default
<peer-svi-mac> dev vxlan48 dst <DPU2-underlay> src_vni 10002 self extern_learn
$ bridge fdb show | grep <endpoint-mac-behind-DPU1>
<endpoint-mac> dev vxlan48 vlan 102 extern_learn master br_default
<endpoint-mac> dev vxlan48 dst <DPU2-underlay> src_vni 10002 self extern_learn
Two things wrong here:
  1. The Linux peer’s SVI MAC is learned as being behind DPU2 via VXLAN — but DPU2 doesn’t own that MAC. The peer is a direct EVPN neighbor of BOTH DPUs. DPU1 has cached DPU2’s re-advertisement of the same MAC instead of its own directly-received route from the peer.
  2. **DPU1’s OWN local endpoint MAC (behind pf0hpf_if) is also learned as being behind DPU2 via VXLAN.**This is fundamentally wrong — the endpoint is physically attached to DPU1 via the host PF representor. HBN’s data-plane FDB has been poisoned by DPU2’s EVPN re-advertisement.
When our peer sends VLAN 102 traffic destined to that endpoint MAC:
  • DPU1’s uplink receives it
  • DPU1’s FDB says “that MAC lives via VXLAN to DPU2”
  • DPU1 attempts to re-encapsulate/forward to DPU2 (or drops)
  • Traffic never reaches the local pf0hpf_if → endpoint dies
Additional tests to rule out MAC-related issues
  • Manually set our internal port’s MAC to match the previously-working bond MAC (e8:eb:d3:fd:d1:2cknown to work when the peer used a kernel VLAN sub-interface on a bond) — no improvement
  • Verified switchdev mode is fully engageddpif/show reports netdev@ovs-netdev, PMD threads active, VF representors bound
  • DPU→peer ping also fails — HBN cannot ping the peer’s SVI either, so this is bidirectional
  • BGP EVPN sessions remain Established throughout all tests, prefixes flowing
What now works, what doesn’t (recap after all testing)
Scenario Result
DPU ↔ DPU L2 VNI 10002 Works (baseline)
Peer via kernel VXLAN + kernel bridge + FRR HBN drops decapsulated frames
Peer via native VLAN 102 through TOR trunk (kernel bond VLAN sub-interface, old MAC) Previously worked
Peer via native VLAN 102 through TOR trunk (OVS internal port, new MAC) HBN drops
Peer via OVS-DOCA + DPDK + switchdev + VXLAN Same drops, plus MAC mobility corruption visible
Any direction (peer→DPU or DPU→peer) once peer switched to switchdev Fails
Additional questions
Extending the original questions with what we’ve learned:
  1. Does HBN’s data-plane FDB have a mechanism to prefer directly-received EVPN Type-2 routes over re-advertisements from other VTEPs? The fact that a locally-attached endpoint’s MAC gets overwritten to point at a remote VTEP looks like a fundamental issue.
  2. Is there a documented interop matrix listing which “kinds” of VTEP peers HBN accepts? So far every non-HBN peer implementation we’ve tried (kernel VXLAN, OVS-DPDK-DOCA in switchdev) reproduces the same drops.
  3. Are there specific extended communities or EVPN attributes that HBN’s FDB installation logic requires from a Type-2 advertisement? Our peer advertises RT:65001:10002 ET:8. DPU-to-DPU advertisements carry the same. No Router MAC is advertised in either direction (this is L2 EVPN, not symmetric IRB).
  4. How can we clear a “corrupt” FDB entry on HBN without a full pod restart? supervisorctl restart nl2doca and bridge fdb del do not seem to persist correct state — DPU2’s EVPN re-advertisement immediately re-poisons the entry.
Happy to share full hbn-support archives, sos reports, and pcaps of the failing scenarios with anyone from the engineering team.
Hi @abhay.bhati,
Thank you for posting your query on NVIDIA Community.
Based on the published HBN documentation, HBN supports VXLAN with an EVPN control plane for intra-subnet bridging (L2) services, and the supported underlay options called out there are IPv4 or BGP unnumbered. The primary public reference for supported combinations is the DOCA 3.3.0 General Support page, which covers supported platforms and NIC firmware versions, supported host OS/kernel combinations, and validated BlueField-3 cables and modules.
Given your scenario, we would recommend you to first verify that the complete environment is within the published support matrix end to end, including HBN/DOCA/BFB version, host OS and kernel, NIC firmware and driver stack, cable/transceiver, and connected switch software.
For reference, please review:
HBN supports establishing BGP peering between the host and HBN, and that the host can use a standard BGP protocol stack for that peering.
If your deployment is fully aligned with the supported matrix above and the behavior remains unchanged, any deeper investigation would require a valid support entitlement.
If there an active entitlement/support contract in place, please do not hesitate to open a support ticket by logging into the ESP Portal and submitting a new case, we can review the logs and perform further troubleshooting.
For contracts, please reach out to Networking-Contracts@nvidia.com
Thanks,
NVEX Networking Technical Support Team
