Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
I am trying to use 10GbE to transfer data between Xavier-a and Xavier-b. I am experiencing serious packet drop even with simply pinging Xavier-b from Xavier-a on this interface. Some facts about the current state:
This interface uses atlantic driver.
The packet drop is visible in this command’s output: ip -s link show enp4s0
The packet drop happens on rx and not tx
In ethtool -S enp4s0 's output it is visible that the packet drop is of type InDroppedDma
I increased the DMA buffer from its default value(2048) to maxismum value(8184) but it didn’t help.
This issue was also happening in driveos 5.1.6 and it still happens in 5.2
Do you have any idea on what can be the reason for this serious packet drop?
Dear @ebrahim4o8qh ,
Could you share the reproducible steps with output logs in DRIVE OS 5.2.0?
Sure. From Xavier-B:
~$ ping 192.168.0.10
PING 192.168.0.10 (192.168.0.10) 56(84) bytes of data.
64 bytes from 192.168.0.10: icmp_seq=1 ttl=64 time=0.544 ms
64 bytes from 192.168.0.10: icmp_seq=2 ttl=64 time=0.200 ms
64 bytes from 192.168.0.10: icmp_seq=3 ttl=64 time=0.179 ms
64 bytes from 192.168.0.10: icmp_seq=4 ttl=64 time=0.182 ms
^C
--- 192.168.0.10 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3076ms
~$ ip -s link show enp3s0
4: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9000 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether 00:04:4b:f6:63:25 brd ff:ff:ff:ff:ff:ff
RX: bytes packets errors dropped overrun mcast
512 6 0 54 0 48
TX: bytes packets errors dropped carrier collsns
3932 54 0 0 0 0
~$ ethtool -S enp3s0
NIC statistics:
InPackets: 54
InUCast: 6
InMCast: 48
InBCast: 0
InErrors: 0
OutPackets: 54
OutUCast: 5
OutMCast: 48
OutBCast: 1
InUCastOctets: 536
OutUCastOctets: 472
InMCastOctets: 3648
OutMCastOctets: 3648
InBCastOctets: 0
OutBCastOctets: 64
InOctets: 4184
OutOctets: 4184
InPacketsDma: 6
OutPacketsDma: 54
InOctetsDma: 512
OutOctetsDma: 3932
InDroppedDma: 54
Queue[0] InPackets: 2
Queue[0] OutPackets: 47
Queue[0] Restarts: 0
Queue[0] InJumboPackets: 0
Queue[0] InLroPackets: 0
Queue[0] InErrors: 0
Queue[1] InPackets: 0
Queue[1] OutPackets: 1
Queue[1] Restarts: 0
Queue[1] InJumboPackets: 0
Queue[1] InLroPackets: 0
Queue[1] InErrors: 0
Queue[2] InPackets: 0
Queue[2] OutPackets: 0
Queue[2] Restarts: 0
Queue[2] InJumboPackets: 0
Queue[2] InLroPackets: 0
Queue[2] InErrors: 0
Queue[3] InPackets: 4
Queue[3] OutPackets: 6
Queue[3] Restarts: 0
Queue[3] InJumboPackets: 0
Queue[3] InLroPackets: 0
Queue[3] InErrors: 0
Could you share ifconfig logs on both Tegra A and Tegra B?
ifconfig -a’s output?
Xavier A:
~$ ifconfig -a
can0: flags=193<UP,RUNNING,NOARP> mtu 16
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 108
can1: flags=193<UP,RUNNING,NOARP> mtu 16
device interrupt 109
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
inet6 fe80::42:bfff:fe30:e9ac prefixlen 64 scopeid 0x20<link>
ether 02:42:bf:30:e9:ac txqueuelen 0 (Ethernet)
TX packets 43 bytes 3866 (3.8 KB)
dummy0: flags=130<BROADCAST,NOARP> mtu 1500
ether 7e:8d:9e:ad:21:49 txqueuelen 1000 (Ethernet)
enP4p1s0: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether 00:04:4b:f6:63:26 txqueuelen 1000 (Ethernet)
enp4s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 9000
inet 192.168.0.10 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::204:4bff:fef6:6324 prefixlen 64 scopeid 0x20<link>
ether 00:04:4b:f6:63:24 txqueuelen 1000 (Ethernet)
RX packets 6 bytes 512 (512.0 B)
RX errors 0 dropped 151 overruns 0 frame 0
TX packets 151 bytes 10722 (10.7 KB)
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.71.10 netmask 255.255.255.0 broadcast 192.168.71.255
inet6 fe80::204:4bff:fef6:6321 prefixlen 64 scopeid 0x20<link>
ether 00:04:4b:f6:63:21 txqueuelen 1000 (Ethernet)
RX packets 41912069 bytes 12796513866 (12.7 GB)
TX packets 63000599 bytes 513925254625405 (513.9 TB)
eth0.200: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.42.0.28 netmask 255.255.255.0 broadcast 10.42.0.255
RX packets 581405 bytes 27790250 (27.7 MB)
TX packets 118352 bytes 6870284 (6.8 MB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 115171356 bytes 11107830160 (11.1 GB)
TX packets 115171356 bytes 11107830160 (11.1 GB)
vcan0: flags=193<UP,RUNNING,NOARP> mtu 72
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 1000 (UNSPEC)
Xavier B:
~$ ifconfig -a
device interrupt 106
device interrupt 107
ether 02:42:b0:f3:f4:9e txqueuelen 0 (Ethernet)
ether 4e:5b:dc:8b:54:5f txqueuelen 1000 (Ethernet)
ether 00:04:4b:f6:63:27 txqueuelen 1000 (Ethernet)
enp3s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 9000
inet 192.168.0.11 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::204:4bff:fef6:6325 prefixlen 64 scopeid 0x20<link>
ether 00:04:4b:f6:63:25 txqueuelen 1000 (Ethernet)
RX errors 0 dropped 150 overruns 0 frame 0
TX packets 150 bytes 10652 (10.6 KB)
inet 192.168.71.11 netmask 255.255.255.0 broadcast 192.168.71.255
inet6 fe80::204:4bff:fef6:6322 prefixlen 64 scopeid 0x20<link>
ether 00:04:4b:f6:63:22 txqueuelen 1000 (Ethernet)
RX packets 9272154 bytes 9729939064 (9.7 GB)
TX packets 2281049 bytes 620704765691211 (620.7 TB)
inet 10.42.0.29 netmask 255.255.255.0 broadcast 10.42.0.255
RX packets 581005 bytes 27773998 (27.7 MB)
TX packets 117812 bytes 6841854 (6.8 MB)
RX packets 3111396 bytes 786338941 (786.3 MB)
TX packets 3111396 bytes 786338941 (786.3 MB)
Could you share the pics of ethernet connection? Also, please confirm if the version is DRIVE OS 5.2.0 Linux.
Yes it is DRIVE OS 5.2.0 Linux. I’ve also seen the same issue on DRIVE OS 5.1.6 Linux
The pic of Ethernet connection:
So board is not connected to internet? I see lan wire connecting two ports.
It is also connected to internet but these two ports are used to connect them to each other. Is it reproducible on your side?
VickNV
August 4, 2021, 9:09pm
11
Hi @ebrahim4o8qh ,
May I know why you increased the mtu setting?
I also observed InDroppedDma and will check internally.
nvidia@tegra-ubuntu:~$ ethtool -S enp3s0
NIC statistics:
InPackets: 2504
InUCast: 20
InMCast: 1752
InBCast: 732
InErrors: 0
OutPackets: 22
OutUCast: 0
OutMCast: 20
OutBCast: 2
InUCastOctets: 1886
OutUCastOctets: 0
InMCastOctets: 425202
OutMCastOctets: 1716
InBCastOctets: 103490
OutBCastOctets: 638
InOctets: 530578
OutOctets: 2354
InPacketsDma: 753
OutPacketsDma: 22
InOctetsDma: 102596
OutOctetsDma: 2266
InDroppedDma : 22
Queue[0] InPackets: 739
Queue[0] OutPackets: 3
Queue[1] OutPackets: 0
Queue[2] OutPackets: 8
Queue[3] InPackets: 14
Queue[3] OutPackets: 11
Hi @VickNV ,
Thanks for the follow-ups. This MTU size is probably left from old configurations we had, but I also tried 1500 and it didn’t solve the issue. On your side, no packet drop happens when MTU is 1500?
VickNV
August 5, 2021, 1:33pm
14
Yes, I saw the packet drop issue on 1500 MTU too.
Hi @VickNV
Could you find out the reason?
VickNV
August 31, 2021, 1:09pm
17
Thanks for reminding us. We will check with the internal team.
May I know if this is blocking your development?
Thanks for the follow up. We are not blocked by this. but this can have some big performance gain for us which is important to us
VickNV
September 7, 2021, 4:05pm
19
May I know how you tell this impacts the performance seriously? Thanks.
I mean we are using another interface for 2 types of traffic. we could separate it into 2 different interfaces this way, if it was working without drop. Unfortunately I can’t go into more details
VickNV
September 7, 2021, 8:21pm
21
According to our testing, this issue doesn’t cause serious performance dropping.
So before it’s fixed, you can still use the interface.
We have serious packet drop on that interface, even with ping command on that interface. How can we use it?
VickNV
September 7, 2021, 9:38pm
23
I remember in idle I observed some increase in the drop count every few seconds.
Is your observation the same? Why do you think it’s serious? Thanks.
