I am attempting to develop a driver for the Toshiba TC358743 chip for the Jetson Nano,
I am using JetPack 4.2.2.
I already have a driver for the TC358743 chip which i use on our older platforms (not Nvidia based)
which i know to be working in 2/4 lanes UYVY or BGR2
I have found a TC358840 driver in the JetPack so i have used it as reference,
I have also found what seems like a device tree example in the JetPack in the file:tegra210-camera-imx274-hdmi.dtsi.
I am not sure about the device tree example, is it Ok to use ?
I took the Imx219 dual dtsi and changed it to look like this:
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
host1x {
vi_base: vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
rbpcv2_imx219_vi_in0: endpoint {
port-index = <4>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_imx219_csi_out0>;
csi_base: nvcsi {
num-channels = <1>;
#size-cells = <0>;
csi_chan0: channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
csi_chan0_port0: port@0 {
reg = <0>;
rbpcv2_imx219_csi_in0: endpoint@0 {
port-index = <4>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_imx219_dual_out0>;
csi_chan0_port1: port@1 {
reg = <1>;
rbpcv2_imx219_csi_out0: endpoint@1 {
remote-endpoint = <&rbpcv2_imx219_vi_in0>;
cam_i2cmux {
i2c_0: i2c@0 {
imx219_cam0: rbpcv2_imx219_a@10 {
compatible = "nvidia,tc358840";
/* I2C device address */
reg = <0x0F>;
status = "disabled";
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "3.680";
physical_h = "2.760";
sensor_model = "tc358840";
use_sensor_mode_id = "false";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv2_imx219_dual_out0: endpoint {
port-index = <4>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_imx219_csi_in0>;
tcp: tegra-camera-platform {
compatible = “nvidia, tegra-camera-platform”;
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <2>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <240000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vendor.
Everything loads fine, the device is probed successfully,
I configure the TC358743 and can see that it is detecting the HDMI correctly,
So i am positive that it is outputting the MIPI signal,
When i try to use it using any v4l software (yavta)
I can see:
[ 39.805554] vi 54080000.vi: Calibrate csi port 4
So it does try to calibrate the intended port, we are connected to port 4
When I try to use it I get the following error:
[ 49.398184] Detected Width = 1280
[ 49.401868] Detected Height = 720
[ 49.606837] video4linux video0: frame start syncpt timeout!0
[ 49.612901] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
[ 49.619503] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 49.625935] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 49.631702] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 49.637462] vi 54080000.vi: cil_settingtime was autocalculated
[ 49.643323] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 49.850848] video4linux video0: frame start syncpt timeout!0
[ 49.856888] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
[ 49.863486] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 49.869917] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 49.875529] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 49.881237] vi 54080000.vi: cil_settingtime was autocalculated
[ 49.887078] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 50.094669] video4linux video0: frame start syncpt timeout!0
[ 50.100652] video4linux video0: TEGRA_VI_CSI_ERROR_STATUS 0x00000000
[ 50.107225] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 50.113644] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 50.119339] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 50.125108] vi 54080000.vi: cil_settingtime was autocalculated
[ 50.130972] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
Can you help me figure out what these error mean ?
Are they hardware related ?
Thanks,
Amir
