HDMI output lost after boot phase
I’m having trouble with HDMI output and the Nvidia driver.
When I connect the HDMI during the boot phase, it works.
My hard drive is encrypted with LUKS, and I can type my passpĥrase and see the output on the HDMI screen.
But once I continue the boot, the output goes black, and I Ubuntu doesn’t manage to make it work.
Here is my config info:
prime-select query
nvidia
uname -a
Linux Strix 5.3.0-29-generic #31-Ubuntu SMP Fri Jan 17 17:27:26 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
ubuntu-drivers devices
== /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 ==
modalias : pci:v000010DEd00001F11sv00001043sd00001F8Ebc03sc00i00
vendor   : NVIDIA Corporation
model    : TU106M [GeForce RTX 2060 Mobile]
driver   : nvidia-driver-435 - distro non-free recommended
driver   : nvidia-driver-430 - distro non-free
driver   : xserver-xorg-video-nouveau - distro free builtin
== /sys/devices/pci0000:00/0000:00:14.3 ==
modalias : pci:v00008086d0000A370sv00008086sd00000034bc02sc80i00
vendor   : Intel Corporation
model    : Wireless-AC 9560 [Jefferson Peak]
manual_install: True
driver   : backport-iwlwifi-dkms - distro free
dmesg | grep nvidia
751:[    1.180052] nvidia-gpu 0000:01:00.3: enabling device (0000 -> 0002)
783:[    1.364865] nvidia: loading out-of-tree module taints kernel.
784:[    1.364872] nvidia: module license 'NVIDIA' taints kernel.
793:[    1.378490] nvidia-nvlink: Nvlink Core is being initialized, major device number 238
794:[    1.378790] nvidia 0000:01:00.0: enabling device (0006 -> 0007)
795:[    1.378862] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
796:[    1.423659] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  435.21  Sun Aug 25 08:17:57 CDT 2019
807:[    1.452932] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  435.21  Sun Aug 25 08:07:52 CDT 2019
808:[    1.454167] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
842:[    2.130401] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
899:[    3.769962] nvidia-uvm: Loaded the UVM driver, major device number 236.
987:[    4.812684] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input23
988:[    4.812731] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input24
1000:[   13.021465] audit: type=1400 audit(1581255849.419:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1365 comm="apparmor_parser"
1001:[   13.021467] audit: type=1400 audit(1581255849.419:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1365 comm="apparmor_parser"
xrandr --verbose
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
eDP-1-1 connected primary 1920x1080+0+0 (0x44) normal (normal left inverted right x axis y axis) 344mm x 194mm
	Identifier: 0x42
	Timestamp:  28804
	Subpixel:   unknown
	Gamma:      1.0:1.0:1.0
	Brightness: 1.0
	Clones:
	CRTC:       0
	CRTCs:      0 1 2
	Transform:  1.000000 0.000000 0.000000
	            0.000000 1.000000 0.000000
	            0.000000 0.000000 1.000000
	           filter:
	_MUTTER_PRESENTATION_OUTPUT: 0
	EDID:
		00ffffffffffff0006afed8200000000
		0a1c0104a5221378026a75a456529c27
		0b505400000001010101010101010101
		010101010101ce8f80b6703888403020
		a50058c210000000ce8f80b670382b47
		3020a50058c110000000000000fe0041
		554f0a202020202020202020000000fe
		004231353648414e30382e32200a0017
	PRIME Synchronization: 1
		supported: 0, 1
	scaling mode: Full aspect
		supported: Full, Center, Full aspect
	max bpc: 12
		range: (6, 12)
	Broadcast RGB: Automatic
		supported: Automatic, Full, Limited 16:235
	link-status: Good
		supported: Good, Bad
	CONNECTOR_ID: 86
		supported: 86
	non-desktop: 0
		range: (0, 1)
  1920x1080 (0x44) 368.140MHz -HSync -VSync *current +preferred
        h: width  1920 start 1968 end 2000 total 2102 skew    0 clock 175.14KHz
        v: height 1080 start 1090 end 1095 total 1216           clock 144.03Hz
  1920x1080 (0x45) 368.140MHz -HSync -VSync
        v: height 1080 start 1090 end 1095 total 2915           clock  60.08Hz
  1920x1080 (0x46) 356.375MHz -HSync +VSync DoubleScan
        h: width  1920 start 2080 end 2288 total 2656 skew    0 clock 134.18KHz
        v: height 1080 start 1081 end 1084 total 1118           clock  60.01Hz
  1920x1080 (0x47) 266.500MHz +HSync -VSync DoubleScan
        h: width  1920 start 1944 end 1960 total 2000 skew    0 clock 133.25KHz
        v: height 1080 start 1081 end 1084 total 1111           clock  59.97Hz
  1920x1080 (0x48) 173.000MHz -HSync +VSync
        h: width  1920 start 2048 end 2248 total 2576 skew    0 clock  67.16KHz
        v: height 1080 start 1083 end 1088 total 1120           clock  59.96Hz
  1920x1080 (0x49) 138.500MHz +HSync -VSync
        h: width  1920 start 1968 end 2000 total 2080 skew    0 clock  66.59KHz
        v: height 1080 start 1083 end 1088 total 1111           clock  59.93Hz
  1680x1050 (0x4a) 214.750MHz -HSync +VSync
        h: width  1680 start 1808 end 1984 total 2288 skew    0 clock  93.86KHz
        v: height 1050 start 1053 end 1059 total 1105           clock  84.94Hz
  1680x1050 (0x4b) 187.000MHz -HSync +VSync
        h: width  1680 start 1800 end 1976 total 2272 skew    0 clock  82.31KHz
        v: height 1050 start 1053 end 1059 total 1099           clock  74.89Hz
  1680x1050 (0x4c) 174.000MHz -HSync +VSync
        h: width  1680 start 1800 end 1976 total 2272 skew    0 clock  76.58KHz
        v: height 1050 start 1053 end 1059 total 1096           clock  69.88Hz
  1680x1050 (0x4d) 146.250MHz -HSync +VSync
        h: width  1680 start 1784 end 1960 total 2240 skew    0 clock  65.29KHz
        v: height 1050 start 1053 end 1059 total 1089           clock  59.95Hz
  1680x1050 (0x4e) 119.000MHz +HSync -VSync
        h: width  1680 start 1728 end 1760 total 1840 skew    0 clock  64.67KHz
        v: height 1050 start 1053 end 1059 total 1080           clock  59.88Hz
  1600x1024 (0x4f) 103.125MHz +HSync +VSync
        h: width  1600 start 1600 end 1656 total 1664 skew    0 clock  61.97KHz
        v: height 1024 start 1024 end 1029 total 1030           clock  60.17Hz
  1400x1050 (0x50) 179.260MHz -HSync +VSync
        h: width  1400 start 1504 end 1656 total 1912 skew    0 clock  93.76KHz
        v: height 1050 start 1051 end 1054 total 1103           clock  85.00Hz
  1400x1050 (0x51) 155.800MHz +HSync +VSync
        h: width  1400 start 1464 end 1784 total 1912 skew    0 clock  81.49KHz
        v: height 1050 start 1052 end 1064 total 1090           clock  74.76Hz
  1400x1050 (0x52) 145.060MHz -HSync +VSync
        h: width  1400 start 1496 end 1648 total 1896 skew    0 clock  76.51KHz
        v: height 1050 start 1051 end 1054 total 1093           clock  70.00Hz
  1400x1050 (0x53) 122.000MHz +HSync +VSync
        h: width  1400 start 1488 end 1640 total 1880 skew    0 clock  64.89KHz
        v: height 1050 start 1052 end 1064 total 1082           clock  59.98Hz
  1600x900 (0x54) 246.000MHz -HSync +VSync DoubleScan
        h: width  1600 start 1728 end 1900 total 2200 skew    0 clock 111.82KHz
        v: height  900 start  901 end  904 total  932           clock  59.99Hz
  1600x900 (0x55) 186.500MHz +HSync -VSync DoubleScan
        h: width  1600 start 1624 end 1640 total 1680 skew    0 clock 111.01KHz
        v: height  900 start  901 end  904 total  926           clock  59.94Hz
  1600x900 (0x56) 118.250MHz -HSync +VSync
        h: width  1600 start 1696 end 1856 total 2112 skew    0 clock  55.99KHz
        v: height  900 start  903 end  908 total  934           clock  59.95Hz
  1600x900 (0x57) 97.500MHz +HSync -VSync
        h: width  1600 start 1648 end 1680 total 1760 skew    0 clock  55.40KHz
        v: height  900 start  903 end  908 total  926           clock  59.82Hz
  1280x1024 (0x58) 157.500MHz +HSync +VSync
        h: width  1280 start 1344 end 1504 total 1728 skew    0 clock  91.15KHz
        v: height 1024 start 1025 end 1028 total 1072           clock  85.02Hz
  1280x1024 (0x59) 135.000MHz +HSync +VSync
        h: width  1280 start 1296 end 1440 total 1688 skew    0 clock  79.98KHz
        v: height 1024 start 1025 end 1028 total 1066           clock  75.02Hz
  1280x1024 (0x5a) 108.000MHz +HSync +VSync
        h: width  1280 start 1328 end 1440 total 1688 skew    0 clock  63.98KHz
        v: height 1024 start 1025 end 1028 total 1066           clock  60.02Hz
  1440x900 (0x5b) 106.500MHz -HSync +VSync
        h: width  1440 start 1520 end 1672 total 1904 skew    0 clock  55.93KHz
        v: height  900 start  903 end  909 total  934           clock  59.89Hz
  1400x900 (0x5c) 103.500MHz -HSync +VSync
        h: width  1400 start 1480 end 1624 total 1848 skew    0 clock  56.01KHz
        v: height  900 start  903 end  913 total  934           clock  59.96Hz
  1400x900 (0x5d) 86.500MHz +HSync -VSync
        h: width  1400 start 1448 end 1480 total 1560 skew    0 clock  55.45KHz
        v: height  900 start  903 end  913 total  926           clock  59.88Hz
  1280x960 (0x5e) 148.500MHz +HSync +VSync
        h: width  1280 start 1344 end 1504 total 1728 skew    0 clock  85.94KHz
        v: height  960 start  961 end  964 total 1011           clock  85.00Hz
  1280x960 (0x5f) 108.000MHz +HSync +VSync
        h: width  1280 start 1376 end 1488 total 1800 skew    0 clock  60.00KHz
        v: height  960 start  961 end  964 total 1000           clock  60.00Hz
  1440x810 (0x60) 198.125MHz -HSync +VSync DoubleScan
        h: width  1440 start 1548 end 1704 total 1968 skew    0 clock 100.67KHz
        v: height  810 start  811 end  814 total  839           clock  60.00Hz
  1440x810 (0x61) 151.875MHz +HSync -VSync DoubleScan
        h: width  1440 start 1464 end 1480 total 1520 skew    0 clock  99.92KHz
        v: height  810 start  811 end  814 total  833           clock  59.97Hz
  1368x768 (0x62) 85.250MHz -HSync +VSync
        h: width  1368 start 1440 end 1576 total 1784 skew    0 clock  47.79KHz
        v: height  768 start  771 end  781 total  798           clock  59.88Hz
  1368x768 (0x63) 72.250MHz +HSync -VSync
        h: width  1368 start 1416 end 1448 total 1528 skew    0 clock  47.28KHz
        v: height  768 start  771 end  781 total  790           clock  59.85Hz
  1360x768 (0x64) 84.750MHz -HSync +VSync
        h: width  1360 start 1432 end 1568 total 1776 skew    0 clock  47.72KHz
        v: height  768 start  771 end  781 total  798           clock  59.80Hz
  1360x768 (0x65) 72.000MHz +HSync -VSync
        h: width  1360 start 1408 end 1440 total 1520 skew    0 clock  47.37KHz
        v: height  768 start  771 end  781 total  790           clock  59.96Hz
  1280x800 (0x66) 174.250MHz -HSync +VSync DoubleScan
        h: width  1280 start 1380 end 1516 total 1752 skew    0 clock  99.46KHz
        v: height  800 start  801 end  804 total  829           clock  59.99Hz
  1280x800 (0x67) 134.250MHz +HSync -VSync DoubleScan
        h: width  1280 start 1304 end 1320 total 1360 skew    0 clock  98.71KHz
        v: height  800 start  801 end  804 total  823           clock  59.97Hz
  1280x800 (0x68) 83.500MHz -HSync +VSync
        h: width  1280 start 1352 end 1480 total 1680 skew    0 clock  49.70KHz
        v: height  800 start  803 end  809 total  831           clock  59.81Hz
  1280x800 (0x69) 71.000MHz +HSync -VSync
        h: width  1280 start 1328 end 1360 total 1440 skew    0 clock  49.31KHz
        v: height  800 start  803 end  809 total  823           clock  59.91Hz
  1152x864 (0x6a) 143.470MHz -HSync +VSync
        h: width  1152 start 1232 end 1360 total 1568 skew    0 clock  91.50KHz
        v: height  864 start  865 end  868 total  915           clock 100.00Hz
  1152x864 (0x6b) 121.500MHz +HSync -VSync
        h: width  1152 start 1216 end 1344 total 1568 skew    0 clock  77.49KHz
        v: height  864 start  865 end  868 total  911           clock  85.06Hz
  1152x864 (0x6c) 119.650MHz -HSync +VSync
        h: width  1152 start 1224 end 1352 total 1552 skew    0 clock  77.09KHz
        v: height  864 start  865 end  868 total  907           clock  85.00Hz
  1152x864 (0x6d) 108.000MHz +HSync +VSync
        h: width  1152 start 1216 end 1344 total 1600 skew    0 clock  67.50KHz
        v: height  864 start  865 end  868 total  900           clock  75.00Hz
  1152x864 (0x6e) 104.990MHz -HSync +VSync
        h: width  1152 start 1224 end 1352 total 1552 skew    0 clock  67.65KHz
        v: height  864 start  865 end  868 total  902           clock  75.00Hz
  1152x864 (0x6f) 96.770MHz -HSync +VSync
        h: width  1152 start 1224 end 1344 total 1536 skew    0 clock  63.00KHz
        v: height  864 start  865 end  868 total  900           clock  70.00Hz
  1152x864 (0x70) 81.620MHz -HSync +VSync
        h: width  1152 start 1216 end 1336 total 1520 skew    0 clock  53.70KHz
        v: height  864 start  865 end  868 total  895           clock  60.00Hz
  1280x720 (0x71) 156.125MHz -HSync +VSync DoubleScan
        h: width  1280 start 1376 end 1512 total 1744 skew    0 clock  89.52KHz
        v: height  720 start  721 end  724 total  746           clock  60.00Hz
  1280x720 (0x72) 120.750MHz +HSync -VSync DoubleScan
        h: width  1280 start 1304 end 1320 total 1360 skew    0 clock  88.79KHz
        v: height  720 start  721 end  724 total  740           clock  59.99Hz
  1280x720 (0x73) 74.500MHz -HSync +VSync
        h: width  1280 start 1344 end 1472 total 1664 skew    0 clock  44.77KHz
        v: height  720 start  723 end  728 total  748           clock  59.86Hz
  1280x720 (0x74) 63.750MHz +HSync -VSync
        h: width  1280 start 1328 end 1360 total 1440 skew    0 clock  44.27KHz
        v: height  720 start  723 end  728 total  741           clock  59.74Hz
  1024x768 (0x75) 194.020MHz -HSync +VSync DoubleScan
        h: width  1024 start 1108 end 1220 total 1416 skew    0 clock 137.02KHz
        v: height  768 start  768 end  770 total  806           clock  85.00Hz
  1024x768 (0x76) 170.240MHz -HSync +VSync DoubleScan
        h: width  1024 start 1108 end 1220 total 1416 skew    0 clock 120.23KHz
        v: height  768 start  768 end  770 total  801           clock  75.05Hz
  1024x768 (0x77) 133.475MHz -HSync +VSync DoubleScan
        h: width  1024 start 1100 end 1212 total 1400 skew    0 clock  95.34KHz
        v: height  768 start  768 end  770 total  794           clock  60.04Hz
  1024x768 (0x78) 94.500MHz +HSync +VSync
        h: width  1024 start 1072 end 1168 total 1376 skew    0 clock  68.68KHz
        v: height  768 start  769 end  772 total  808           clock  85.00Hz
  1024x768 (0x79) 78.750MHz +HSync +VSync
        h: width  1024 start 1040 end 1136 total 1312 skew    0 clock  60.02KHz
        v: height  768 start  769 end  772 total  800           clock  75.03Hz
  1024x768 (0x7a) 75.000MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1328 skew    0 clock  56.48KHz
        v: height  768 start  771 end  777 total  806           clock  70.07Hz
  1024x768 (0x7b) 65.000MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1344 skew    0 clock  48.36KHz
        v: height  768 start  771 end  777 total  806           clock  60.00Hz
  1024x768i (0x7c) 44.900MHz +HSync +VSync Interlace
        h: width  1024 start 1032 end 1208 total 1264 skew    0 clock  35.52KHz
        v: height  768 start  768 end  776 total  817           clock  86.96Hz
  960x720 (0x7d) 170.675MHz -HSync +VSync DoubleScan
        h: width   960 start 1036 end 1144 total 1328 skew    0 clock 128.52KHz
        v: height  720 start  720 end  722 total  756           clock  85.00Hz
  960x720 (0x7e) 148.500MHz -HSync +VSync DoubleScan
        h: width   960 start 1032 end 1144 total 1320 skew    0 clock 112.50KHz
        v: height  720 start  720 end  722 total  750           clock  75.00Hz
  960x720 (0x7f) 117.000MHz -HSync +VSync DoubleScan
        h: width   960 start 1024 end 1128 total 1300 skew    0 clock  90.00KHz
        v: height  720 start  720 end  722 total  750           clock  60.00Hz
  928x696 (0x80) 144.000MHz -HSync +VSync DoubleScan
        h: width   928 start  992 end 1104 total 1280 skew    0 clock 112.50KHz
        v: height  696 start  696 end  698 total  750           clock  75.00Hz
  928x696 (0x81) 109.150MHz -HSync +VSync DoubleScan
        h: width   928 start  976 end 1088 total 1264 skew    0 clock  86.35KHz
        v: height  696 start  696 end  698 total  719           clock  60.05Hz
  896x672 (0x82) 130.500MHz -HSync +VSync DoubleScan
        h: width   896 start  944 end 1052 total 1228 skew    0 clock 106.27KHz
        v: height  672 start  672 end  674 total  708           clock  75.05Hz
  896x672 (0x83) 102.400MHz -HSync +VSync DoubleScan
        h: width   896 start  960 end 1060 total 1224 skew    0 clock  83.66KHz
        v: height  672 start  672 end  674 total  697           clock  60.01Hz
  1024x576 (0x84) 98.500MHz -HSync +VSync DoubleScan
        h: width  1024 start 1092 end 1200 total 1376 skew    0 clock  71.58KHz
        v: height  576 start  577 end  580 total  597           clock  59.95Hz
  1024x576 (0x85) 78.375MHz +HSync -VSync DoubleScan
        h: width  1024 start 1048 end 1064 total 1104 skew    0 clock  70.99KHz
        v: height  576 start  577 end  580 total  592           clock  59.96Hz
  1024x576 (0x86) 46.500MHz -HSync +VSync
        h: width  1024 start 1064 end 1160 total 1296 skew    0 clock  35.88KHz
        v: height  576 start  579 end  584 total  599           clock  59.90Hz
  1024x576 (0x87) 42.000MHz +HSync -VSync
        h: width  1024 start 1072 end 1104 total 1184 skew    0 clock  35.47KHz
        v: height  576 start  579 end  584 total  593           clock  59.82Hz
  960x600 (0x88) 96.625MHz -HSync +VSync DoubleScan
        h: width   960 start 1028 end 1128 total 1296 skew    0 clock  74.56KHz
        v: height  600 start  601 end  604 total  622           clock  59.93Hz
  960x600 (0x89) 77.000MHz +HSync -VSync DoubleScan
        h: width   960 start  984 end 1000 total 1040 skew    0 clock  74.04KHz
        v: height  600 start  601 end  604 total  617           clock  60.00Hz
  832x624 (0x8a) 57.284MHz -HSync -VSync
        h: width   832 start  864 end  928 total 1152 skew    0 clock  49.73KHz
        v: height  624 start  625 end  628 total  667           clock  74.55Hz
  960x540 (0x8b) 86.500MHz -HSync +VSync DoubleScan
        h: width   960 start 1024 end 1124 total 1288 skew    0 clock  67.16KHz
        v: height  540 start  541 end  544 total  560           clock  59.96Hz
  960x540 (0x8c) 69.250MHz +HSync -VSync DoubleScan
        h: width   960 start  984 end 1000 total 1040 skew    0 clock  66.59KHz
        v: height  540 start  541 end  544 total  555           clock  59.99Hz
  960x540 (0x8d) 40.750MHz -HSync +VSync
        h: width   960 start  992 end 1088 total 1216 skew    0 clock  33.51KHz
        v: height  540 start  543 end  548 total  562           clock  59.63Hz
  960x540 (0x8e) 37.250MHz +HSync -VSync
        h: width   960 start 1008 end 1040 total 1120 skew    0 clock  33.26KHz
        v: height  540 start  543 end  548 total  556           clock  59.82Hz
  800x600 (0x8f) 114.750MHz +HSync +VSync DoubleScan
        h: width   800 start  832 end  928 total 1080 skew    0 clock 106.25KHz
        v: height  600 start  600 end  602 total  625           clock  85.00Hz
  800x600 (0x90) 101.250MHz +HSync +VSync DoubleScan
        h: width   800 start  832 end  928 total 1080 skew    0 clock  93.75KHz
        v: height  600 start  600 end  602 total  625           clock  75.00Hz
  800x600 (0x91) 94.500MHz +HSync +VSync DoubleScan
        h: width   800 start  832 end  928 total 1080 skew    0 clock  87.50KHz
        v: height  600 start  600 end  602 total  625           clock  70.00Hz
  800x600 (0x92) 87.750MHz +HSync +VSync DoubleScan
        h: width   800 start  832 end  928 total 1080 skew    0 clock  81.25KHz
        v: height  600 start  600 end  602 total  625           clock  65.00Hz
  800x600 (0x93) 81.000MHz +HSync +VSync DoubleScan
        h: width   800 start  832 end  928 total 1080 skew    0 clock  75.00KHz
        v: height  600 start  600 end  602 total  625           clock  60.00Hz
  800x600 (0x94) 56.300MHz +HSync +VSync
        h: width   800 start  832 end  896 total 1048 skew    0 clock  53.72KHz
        v: height  600 start  601 end  604 total  631           clock  85.14Hz
  800x600 (0x95) 50.000MHz +HSync +VSync
        h: width   800 start  856 end  976 total 1040 skew    0 clock  48.08KHz
        v: height  600 start  637 end  643 total  666           clock  72.19Hz
  800x600 (0x96) 49.500MHz +HSync +VSync
        h: width   800 start  816 end  896 total 1056 skew    0 clock  46.88KHz
        v: height  600 start  601 end  604 total  625           clock  75.00Hz
  800x600 (0x97) 40.000MHz +HSync +VSync
        h: width   800 start  840 end  968 total 1056 skew    0 clock  37.88KHz
        v: height  600 start  601 end  605 total  628           clock  60.32Hz
  800x600 (0x98) 36.000MHz +HSync +VSync
        h: width   800 start  824 end  896 total 1024 skew    0 clock  35.16KHz
        v: height  600 start  601 end  603 total  625           clock  56.25Hz
  840x525 (0x99) 107.375MHz -HSync +VSync DoubleScan
        h: width   840 start  904 end  992 total 1144 skew    0 clock  93.86KHz
        v: height  525 start  526 end  529 total  552           clock  85.02Hz
  840x525 (0x9a) 93.500MHz -HSync +VSync DoubleScan
        h: width   840 start  900 end  988 total 1136 skew    0 clock  82.31KHz
        v: height  525 start  526 end  529 total  549           clock  74.96Hz
  840x525 (0x9b) 87.000MHz -HSync +VSync DoubleScan
        h: width   840 start  900 end  988 total 1136 skew    0 clock  76.58KHz
        v: height  525 start  526 end  529 total  548           clock  69.88Hz
  840x525 (0x9c) 73.125MHz -HSync +VSync DoubleScan
        h: width   840 start  892 end  980 total 1120 skew    0 clock  65.29KHz
        v: height  525 start  526 end  529 total  544           clock  60.01Hz
  840x525 (0x9d) 59.500MHz +HSync -VSync DoubleScan
        h: width   840 start  864 end  880 total  920 skew    0 clock  64.67KHz
        v: height  525 start  526 end  529 total  540           clock  59.88Hz
  864x486 (0x9e) 32.500MHz -HSync +VSync
        h: width   864 start  888 end  968 total 1072 skew    0 clock  30.32KHz
        v: height  486 start  489 end  494 total  506           clock  59.92Hz
  864x486 (0x9f) 30.500MHz +HSync -VSync
        h: width   864 start  912 end  944 total 1024 skew    0 clock  29.79KHz
        v: height  486 start  489 end  494 total  500           clock  59.57Hz
  800x512 (0xa0) 51.562MHz +HSync +VSync DoubleScan
        h: width   800 start  800 end  828 total  832 skew    0 clock  61.97KHz
        v: height  512 start  512 end  514 total  515           clock  60.17Hz
  700x525 (0xa1) 89.630MHz -HSync +VSync DoubleScan
        h: width   700 start  752 end  828 total  956 skew    0 clock  93.76KHz
        v: height  525 start  525 end  527 total  551           clock  85.08Hz
  700x525 (0xa2) 77.900MHz +HSync +VSync DoubleScan
        h: width   700 start  732 end  892 total  956 skew    0 clock  81.49KHz
        v: height  525 start  526 end  532 total  545           clock  74.76Hz
  700x525 (0xa3) 72.530MHz -HSync +VSync DoubleScan
        h: width   700 start  748 end  824 total  948 skew    0 clock  76.51KHz
        v: height  525 start  525 end  527 total  546           clock  70.06Hz
  700x525 (0xa4) 61.000MHz +HSync +VSync DoubleScan
        h: width   700 start  744 end  820 total  940 skew    0 clock  64.89KHz
        v: height  525 start  526 end  532 total  541           clock  59.98Hz
  800x450 (0xa5) 59.125MHz -HSync +VSync DoubleScan
        h: width   800 start  848 end  928 total 1056 skew    0 clock  55.99KHz
        v: height  450 start  451 end  454 total  467           clock  59.95Hz
  800x450 (0xa6) 48.750MHz +HSync -VSync DoubleScan
        h: width   800 start  824 end  840 total  880 skew    0 clock  55.40KHz
        v: height  450 start  451 end  454 total  463           clock  59.82Hz
  640x512 (0xa7) 78.750MHz +HSync +VSync DoubleScan
        h: width   640 start  672 end  752 total  864 skew    0 clock  91.15KHz
        v: height  512 start  512 end  514 total  536           clock  85.02Hz
  640x512 (0xa8) 67.500MHz +HSync +VSync DoubleScan
        h: width   640 start  648 end  720 total  844 skew    0 clock  79.98KHz
        v: height  512 start  512 end  514 total  533           clock  75.02Hz
  640x512 (0xa9) 54.000MHz +HSync +VSync DoubleScan
        h: width   640 start  664 end  720 total  844 skew    0 clock  63.98KHz
        v: height  512 start  512 end  514 total  533           clock  60.02Hz
  720x450 (0xaa) 53.250MHz -HSync +VSync DoubleScan
        h: width   720 start  760 end  836 total  952 skew    0 clock  55.93KHz
        v: height  450 start  451 end  454 total  467           clock  59.89Hz
  700x450 (0xab) 51.750MHz -HSync +VSync DoubleScan
        h: width   700 start  740 end  812 total  924 skew    0 clock  56.01KHz
        v: height  450 start  451 end  456 total  467           clock  59.96Hz
  700x450 (0xac) 43.250MHz +HSync -VSync DoubleScan
        h: width   700 start  724 end  740 total  780 skew    0 clock  55.45KHz
        v: height  450 start  451 end  456 total  463           clock  59.88Hz
  640x480 (0xad) 74.250MHz +HSync +VSync DoubleScan
        h: width   640 start  672 end  752 total  864 skew    0 clock  85.94KHz
        v: height  480 start  480 end  482 total  505           clock  85.09Hz
  640x480 (0xae) 54.000MHz +HSync +VSync DoubleScan
        h: width   640 start  688 end  744 total  900 skew    0 clock  60.00KHz
        v: height  480 start  480 end  482 total  500           clock  60.00Hz
  640x480 (0xaf) 36.000MHz -HSync -VSync
        h: width   640 start  696 end  752 total  832 skew    0 clock  43.27KHz
        v: height  480 start  481 end  484 total  509           clock  85.01Hz
  640x480 (0xb0) 31.500MHz -HSync -VSync
        h: width   640 start  664 end  704 total  832 skew    0 clock  37.86KHz
        v: height  480 start  489 end  492 total  520           clock  72.81Hz
  640x480 (0xb1) 31.500MHz -HSync -VSync
        h: width   640 start  656 end  720 total  840 skew    0 clock  37.50KHz
        v: height  480 start  481 end  484 total  500           clock  75.00Hz
  640x480 (0xb2) 25.175MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.47KHz
        v: height  480 start  490 end  492 total  525           clock  59.94Hz
  720x405 (0xb3) 22.500MHz -HSync +VSync
        h: width   720 start  744 end  808 total  896 skew    0 clock  25.11KHz
        v: height  405 start  408 end  413 total  422           clock  59.51Hz
  720x405 (0xb4) 21.750MHz +HSync -VSync
        h: width   720 start  768 end  800 total  880 skew    0 clock  24.72KHz
        v: height  405 start  408 end  413 total  419           clock  58.99Hz
  720x400 (0xb5) 35.500MHz -HSync +VSync
        h: width   720 start  756 end  828 total  936 skew    0 clock  37.93KHz
        v: height  400 start  401 end  404 total  446           clock  85.04Hz
  684x384 (0xb6) 42.625MHz -HSync +VSync DoubleScan
        h: width   684 start  720 end  788 total  892 skew    0 clock  47.79KHz
        v: height  384 start  385 end  390 total  399           clock  59.88Hz
  684x384 (0xb7) 36.125MHz +HSync -VSync DoubleScan
        h: width   684 start  708 end  724 total  764 skew    0 clock  47.28KHz
        v: height  384 start  385 end  390 total  395           clock  59.85Hz
  680x384 (0xb8) 42.375MHz -HSync +VSync DoubleScan
        h: width   680 start  716 end  784 total  888 skew    0 clock  47.72KHz
        v: height  384 start  385 end  390 total  399           clock  59.80Hz
  680x384 (0xb9) 36.000MHz +HSync -VSync DoubleScan
        h: width   680 start  704 end  720 total  760 skew    0 clock  47.37KHz
        v: height  384 start  385 end  390 total  395           clock  59.96Hz
  640x400 (0xba) 41.750MHz -HSync +VSync DoubleScan
        h: width   640 start  676 end  740 total  840 skew    0 clock  49.70KHz
        v: height  400 start  401 end  404 total  415           clock  59.88Hz
  640x400 (0xbb) 35.500MHz +HSync -VSync DoubleScan
        h: width   640 start  664 end  680 total  720 skew    0 clock  49.31KHz
        v: height  400 start  401 end  404 total  411           clock  59.98Hz
  640x400 (0xbc) 31.500MHz -HSync +VSync
        h: width   640 start  672 end  736 total  832 skew    0 clock  37.86KHz
        v: height  400 start  401 end  404 total  445           clock  85.08Hz
  576x432 (0xbd) 71.735MHz -HSync +VSync DoubleScan
        h: width   576 start  616 end  680 total  784 skew    0 clock  91.50KHz
        v: height  432 start  432 end  434 total  457           clock 100.11Hz
  576x432 (0xbe) 60.750MHz +HSync -VSync DoubleScan
        h: width   576 start  608 end  672 total  784 skew    0 clock  77.49KHz
        v: height  432 start  432 end  434 total  455           clock  85.15Hz
  576x432 (0xbf) 59.825MHz -HSync +VSync DoubleScan
        h: width   576 start  612 end  676 total  776 skew    0 clock  77.09KHz
        v: height  432 start  432 end  434 total  453           clock  85.09Hz
  576x432 (0xc0) 54.000MHz +HSync +VSync DoubleScan
        h: width   576 start  608 end  672 total  800 skew    0 clock  67.50KHz
        v: height  432 start  432 end  434 total  450           clock  75.00Hz
  576x432 (0xc1) 52.495MHz -HSync +VSync DoubleScan
        h: width   576 start  612 end  676 total  776 skew    0 clock  67.65KHz
        v: height  432 start  432 end  434 total  451           clock  75.00Hz
  576x432 (0xc2) 48.385MHz -HSync +VSync DoubleScan
        h: width   576 start  612 end  672 total  768 skew    0 clock  63.00KHz
        v: height  432 start  432 end  434 total  450           clock  70.00Hz
  576x432 (0xc3) 40.810MHz -HSync +VSync DoubleScan
        h: width   576 start  608 end  668 total  760 skew    0 clock  53.70KHz
        v: height  432 start  432 end  434 total  447           clock  60.06Hz
  640x360 (0xc4) 37.250MHz -HSync +VSync DoubleScan
        h: width   640 start  672 end  736 total  832 skew    0 clock  44.77KHz
        v: height  360 start  361 end  364 total  374           clock  59.86Hz
  640x360 (0xc5) 31.875MHz +HSync -VSync DoubleScan
        h: width   640 start  664 end  680 total  720 skew    0 clock  44.27KHz
        v: height  360 start  361 end  364 total  370           clock  59.83Hz
  640x360 (0xc6) 18.000MHz -HSync +VSync
        h: width   640 start  664 end  720 total  800 skew    0 clock  22.50KHz
        v: height  360 start  363 end  368 total  376           clock  59.84Hz
  640x360 (0xc7) 17.750MHz +HSync -VSync
        h: width   640 start  688 end  720 total  800 skew    0 clock  22.19KHz
        v: height  360 start  363 end  368 total  374           clock  59.32Hz
  640x350 (0xc8) 31.500MHz +HSync -VSync
        v: height  350 start  382 end  385 total  445           clock  85.08Hz
  512x384 (0xc9) 47.250MHz +HSync +VSync DoubleScan
        h: width   512 start  536 end  584 total  688 skew    0 clock  68.68KHz
        v: height  384 start  384 end  386 total  404           clock  85.00Hz
  512x384 (0xca) 39.375MHz +HSync +VSync DoubleScan
        h: width   512 start  520 end  568 total  656 skew    0 clock  60.02KHz
        v: height  384 start  384 end  386 total  400           clock  75.03Hz
  512x384 (0xcb) 37.500MHz -HSync -VSync DoubleScan
        h: width   512 start  524 end  592 total  664 skew    0 clock  56.48KHz
        v: height  384 start  385 end  388 total  403           clock  70.07Hz
  512x384 (0xcc) 32.500MHz -HSync -VSync DoubleScan
        h: width   512 start  524 end  592 total  672 skew    0 clock  48.36KHz
        v: height  384 start  385 end  388 total  403           clock  60.00Hz
  512x384i (0xcd) 22.450MHz +HSync +VSync Interlace DoubleScan
        h: width   512 start  516 end  604 total  632 skew    0 clock  35.52KHz
        v: height  384 start  384 end  388 total  408           clock  87.06Hz
  512x288 (0xce) 23.250MHz -HSync +VSync DoubleScan
        h: width   512 start  532 end  580 total  648 skew    0 clock  35.88KHz
        v: height  288 start  289 end  292 total  299           clock  60.00Hz
  512x288 (0xcf) 21.000MHz +HSync -VSync DoubleScan
        h: width   512 start  536 end  552 total  592 skew    0 clock  35.47KHz
        v: height  288 start  289 end  292 total  296           clock  59.92Hz
  416x312 (0xd0) 28.642MHz -HSync -VSync DoubleScan
        h: width   416 start  432 end  464 total  576 skew    0 clock  49.73KHz
        v: height  312 start  312 end  314 total  333           clock  74.66Hz
  480x270 (0xd1) 20.375MHz -HSync +VSync DoubleScan
        h: width   480 start  496 end  544 total  608 skew    0 clock  33.51KHz
        v: height  270 start  271 end  274 total  281           clock  59.63Hz
  480x270 (0xd2) 18.625MHz +HSync -VSync DoubleScan
        h: width   480 start  504 end  520 total  560 skew    0 clock  33.26KHz
        v: height  270 start  271 end  274 total  278           clock  59.82Hz
  400x300 (0xd3) 28.150MHz +HSync +VSync DoubleScan
        h: width   400 start  416 end  448 total  524 skew    0 clock  53.72KHz
        v: height  300 start  300 end  302 total  315           clock  85.27Hz
  400x300 (0xd4) 25.000MHz +HSync +VSync DoubleScan
        h: width   400 start  428 end  488 total  520 skew    0 clock  48.08KHz
        v: height  300 start  318 end  321 total  333           clock  72.19Hz
  400x300 (0xd5) 24.750MHz +HSync +VSync DoubleScan
        h: width   400 start  408 end  448 total  528 skew    0 clock  46.88KHz
        v: height  300 start  300 end  302 total  312           clock  75.12Hz
  400x300 (0xd6) 20.000MHz +HSync +VSync DoubleScan
        h: width   400 start  420 end  484 total  528 skew    0 clock  37.88KHz
        v: height  300 start  300 end  302 total  314           clock  60.32Hz
  400x300 (0xd7) 18.000MHz +HSync +VSync DoubleScan
        h: width   400 start  412 end  448 total  512 skew    0 clock  35.16KHz
        v: height  300 start  300 end  301 total  312           clock  56.34Hz
  432x243 (0xd8) 16.250MHz -HSync +VSync DoubleScan
        h: width   432 start  444 end  484 total  536 skew    0 clock  30.32KHz
        v: height  243 start  244 end  247 total  253           clock  59.92Hz
  432x243 (0xd9) 15.250MHz +HSync -VSync DoubleScan
        h: width   432 start  456 end  472 total  512 skew    0 clock  29.79KHz
        v: height  243 start  244 end  247 total  250           clock  59.57Hz
  320x240 (0xda) 18.000MHz -HSync -VSync DoubleScan
        h: width   320 start  348 end  376 total  416 skew    0 clock  43.27KHz
        v: height  240 start  240 end  242 total  254           clock  85.18Hz
  320x240 (0xdb) 15.750MHz -HSync -VSync DoubleScan
        h: width   320 start  332 end  352 total  416 skew    0 clock  37.86KHz
        v: height  240 start  244 end  246 total  260           clock  72.81Hz
  320x240 (0xdc) 15.750MHz -HSync -VSync DoubleScan
        h: width   320 start  328 end  360 total  420 skew    0 clock  37.50KHz
        v: height  240 start  240 end  242 total  250           clock  75.00Hz
  320x240 (0xdd) 12.587MHz -HSync -VSync DoubleScan
        h: width   320 start  328 end  376 total  400 skew    0 clock  31.47KHz
        v: height  240 start  245 end  246 total  262           clock  60.05Hz
  360x202 (0xde) 11.250MHz -HSync +VSync DoubleScan
        h: width   360 start  372 end  404 total  448 skew    0 clock  25.11KHz
        v: height  202 start  204 end  206 total  211           clock  59.51Hz
  360x202 (0xdf) 10.875MHz +HSync -VSync DoubleScan
        h: width   360 start  384 end  400 total  440 skew    0 clock  24.72KHz
        v: height  202 start  204 end  206 total  209           clock  59.13Hz
  360x200 (0xe0) 17.750MHz -HSync +VSync DoubleScan
        h: width   360 start  378 end  414 total  468 skew    0 clock  37.93KHz
        v: height  200 start  200 end  202 total  223           clock  85.04Hz
  320x200 (0xe1) 15.750MHz -HSync +VSync DoubleScan
        h: width   320 start  336 end  368 total  416 skew    0 clock  37.86KHz
        v: height  200 start  200 end  202 total  222           clock  85.27Hz
  320x180 (0xe2)  9.000MHz -HSync +VSync DoubleScan
        h: width   320 start  332 end  360 total  400 skew    0 clock  22.50KHz
        v: height  180 start  181 end  184 total  188           clock  59.84Hz
  320x180 (0xe3)  8.875MHz +HSync -VSync DoubleScan
        h: width   320 start  344 end  360 total  400 skew    0 clock  22.19KHz
        v: height  180 start  181 end  184 total  187           clock  59.32Hz
  320x175 (0xe4) 15.750MHz +HSync -VSync DoubleScan
        v: height  175 start  191 end  192 total  222           clock  85.27Hz
Here is the Nvidia bug report archive:
https://drive.google.com/open?id=1a8CiibWcXUGbDBRZHKNitj5VyaX7t19A
Thank you for your help !
nvidia-bug-report.log.gz (936 KB)
