Hello- I’m stuck and could really use some help getting through this…
I have attempted multiple times to go through Classifying Images with ImageNet, and I keep getting the same error(s).
I followed the instructions and am running from the docker. I have also cloned the github a few times in case something was wrong there, but still, same thing.
I also attempted using the Model Downloader tool as the output suggested, still no success. (I thought I read this was no longer necessary anyways?)
I attempted running with the default googlenet, and attempted also with resnet-18 (see below)
root@xxxx:/jetson-inference/build/aarch64/bin# ./imagenet.py --network=resnet-18 images/jellyfish.jpg images/test/output_jellyfish.jpg
[TRT] downloading model ResNet-18.tar.gz…
cd networks ; wget --quiet --show-progress --progress=bar:force:noscroll --no-check-certificate https://nvidia.box.com/shared/static/gph1qfor89vh498op8cicvwc13zltu3h.gz -O ResNet-18.tar.gz ; tar -xzvf ResNet-18.tar.gz ; rm ResNet-18.tar.gz
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: Error is not recoverable: exiting now
[TRT] downloaded model ResNet-18.tar.gz
imageNet – loading classification network model from:
– prototxt networks/ResNet-18/deploy.prototxt
– model networks/ResNet-18/ResNet-18.caffemodel
– class_labels networks/ilsvrc12_synset_words.txt
– input_blob ‘data’
– output_blob ‘prob’
– batch_size 1
[TRT] TensorRT version 8.5.2
[TRT] loading NVIDIA plugins…
[TRT] Registered plugin creator - ::BatchedNMSDynamic_TRT version 1
[TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[TRT] Registered plugin creator - ::BatchTilePlugin_TRT version 1
[TRT] Registered plugin creator - ::Clip_TRT version 1
[TRT] Registered plugin creator - ::CoordConvAC version 1
[TRT] Registered plugin creator - ::CropAndResizeDynamic version 1
[TRT] Registered plugin creator - ::CropAndResize version 1
[TRT] Registered plugin creator - ::DecodeBbox3DPlugin version 1
[TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[TRT] Registered plugin creator - ::EfficientNMS_Explicit_TF_TRT version 1
[TRT] Registered plugin creator - ::EfficientNMS_Implicit_TF_TRT version 1
[TRT] Registered plugin creator - ::EfficientNMS_ONNX_TRT version 1
[TRT] Registered plugin creator - ::EfficientNMS_TRT version 1
[TRT] Could not register plugin creator - ::FlattenConcat_TRT version 1
[TRT] Registered plugin creator - ::GenerateDetection_TRT version 1
[TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[TRT] Registered plugin creator - ::GridAnchorRect_TRT version 1
[TRT] Registered plugin creator - ::GroupNorm version 1
[TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[TRT] Registered plugin creator - ::InstanceNormalization_TRT version 2
[TRT] Registered plugin creator - ::LayerNorm version 1
[TRT] Registered plugin creator - ::LReLU_TRT version 1
[TRT] Registered plugin creator - ::MultilevelCropAndResize_TRT version 1
[TRT] Registered plugin creator - ::MultilevelProposeROI_TRT version 1
[TRT] Registered plugin creator - ::MultiscaleDeformableAttnPlugin_TRT version 1
[TRT] Registered plugin creator - ::NMSDynamic_TRT version 1
[TRT] Registered plugin creator - ::NMS_TRT version 1
[TRT] Registered plugin creator - ::Normalize_TRT version 1
[TRT] Registered plugin creator - ::PillarScatterPlugin version 1
[TRT] Registered plugin creator - ::PriorBox_TRT version 1
[TRT] Registered plugin creator - ::ProposalDynamic version 1
[TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[TRT] Registered plugin creator - ::Proposal version 1
[TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[TRT] Registered plugin creator - ::Region_TRT version 1
[TRT] Registered plugin creator - ::Reorg_TRT version 1
[TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[TRT] Registered plugin creator - ::ROIAlign_TRT version 1
[TRT] Registered plugin creator - ::RPROI_TRT version 1
[TRT] Registered plugin creator - ::ScatterND version 1
[TRT] Registered plugin creator - ::SeqLen2Spatial version 1
[TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[TRT] Registered plugin creator - ::SplitGeLU version 1
[TRT] Registered plugin creator - ::Split version 1
[TRT] Registered plugin creator - ::VoxelGeneratorPlugin version 1
[TRT] detected model format - caffe (extension ‘.caffemodel’)
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] [MemUsageChange] Init CUDA: CPU +221, GPU +0, now: CPU 253, GPU 6838 (MiB)
[TRT] Trying to load shared library libnvinfer_builder_resource.so.8.5.2
[TRT] Loaded shared library libnvinfer_builder_resource.so.8.5.2
[TRT] [MemUsageChange] Init builder kernel library: CPU +303, GPU +285, now: CPU 578, GPU 7143 (MiB)
[TRT] native precisions detected for GPU: FP32, FP16, INT8
[TRT] selecting fastest native precision for GPU: FP16
[TRT] could not find engine cache .1.1.8502.GPU.FP16.engine
[TRT] cache file invalid, profiling network model on device GPU
error: model file ‘networks/ResNet-18/ResNet-18.caffemodel’ was not found.
if loading a built-in model, maybe it wasn’t downloaded before.
Run the Model Downloader tool again and select it for download:
$ cd <jetson-inference>/tools
$ ./download-models.sh
[TRT] failed to load networks/ResNet-18/ResNet-18.caffemodel
[TRT] imageNet – failed to initialize.
File “./imagenet.py”, line 51, in
net = imageNet(args.network, sys.argv)
Exception: jetson.inference – imageNet failed to load network
