Hi again, trying to run:
Title: hello_ai_world_nvidia
Command/Errors:
root@ubuntu:/media/kopbeen/steek2_0/hello_ai_world_nvidia/llava# jetson-containers run --workdir=/opt/text-generation-webui $(autotag text-generation-webui) python3 download-model.py --output=/data/models/text-generation-webui TheBloke/llava-v1.5-13B-GPTQ
bash: /usr/local/bin/autotag: Permission denied
bash: /usr/local/bin/jetson-containers: Permission denied
Tried:
sudo chown -R root:root /usr/local/bin/jetson-containers
sudo chown -R root:root /usr/local/bin/autotag
chmod +x /usr/local/bin/jetson-containers
Hi @pieterc ,
I move this post to Jetson AGX Xavier, since most of your Jetson activity seems to happen there.
May I kindly ask you to try and stay in the correct categories for your requests?
The Jetson-inference - docker issues post is also not in the correct category but should rather be in a Jetson specific category.
By trying to keep it in context the chances are that much higher that you will receive help. Also, if people have looked at your issues they might have prior knowledge. Posting in vastly different categories means whoever looks at it needs to start from scratch.
Thank you Markus, will do in future. Apologies.
Pieter Claassens
Software Engineer
SHOCK Electro-Optic Systems
Cell: +27 83 561 8577
WhatsApp: +27 68 742 8101
Hello @pieterc ,
Have you tried running jetson-containers with sudo ?
sudo jetson-containers run ...
best regards,
Andrew
We fix real NVIDIA Jetson issues: Board bringup, driver development, CUDA errors, flashing failures, containers, and performance bottlenecks. Hands-on engineering support for teams shipping hardware.
Est. reading time: 4 minutes
Just want to double-check.
Do you want to run the jetson-container command within a container or natively?
pieterc
November 5, 2025, 11:16am
8
Tried more chmod commands: (fail)
root@ubuntu:/media/kopbeen/steek2_0/jetson-containers/jetson-containers# sudo chmod -R 777 /root/bin/autotag
root@ubuntu:/media/kopbeen/steek2_0/jetson-containers/jetson-containers# sudo chmod -R 777 /usr/local/bin/jetson-containers
pieterc
November 5, 2025, 11:37am
9
also failing / no effect:
root@ubuntu:/media/kopbeen/steek2_0/jetson-containers/jetson-containers# chmod -R a+rX /usr/local/bin/jetson-containers
root@ubuntu:/media/kopbeen/steek2_0/jetson-containers/jetson-containers# chmod -R a+rX /root/bin/autotag
pieterc
November 5, 2025, 11:39am
10
Trying sudo :
root@ubuntu:/media/kopbeen/steek2_0/jetson-containers/jetson-containers# sudo jetson-containers run --workdir=/opt/text-generation-webui $(autotag text-generation-webui) python3 server.py --listen --model-dir /data/models/text-generation-webui --model TheBloke_llava-v1.5-13B-GPTQ --multimodal-pipeline llava-v1.5-13b --loader autogptq --disable_exllama --verbose
bash: /root/bin/autotag: Permission denied
sudo: jetson-containers: command not found
pieterc
November 5, 2025, 11:52am
11
root@ubuntu:/usr/local/bin# echo “hello” > hello.txt
root@ubuntu:/usr/local/bin# ls
autotag cython hello.txt
pieterc
November 5, 2025, 11:53am
12
root@ubuntu:/usr/local/bin# cd /root/bin
root@ubuntu:~/bin# echo “hello” > hello.txt
root@ubuntu:~/bin# ls
autotag hello.txt
root@ubuntu:~/bin# pwd
/root/bin
Do you log in to the device with root?
If yes, will you use another username after?
In general, you can clone jetson-container with the following commands:
git clone https://github.com/dusty-nv/jetson-containers
bash jetson-containers/install.sh
(Please select a folder with write permission.)
Then the jetson-containers run should work as expected.
