Jetson-containers run (LLaVA sample project)
Continuing the discussion from Jetson-containers run (LLaVA sample project):
Good day, I’m trying to run the LLaVA sample project but keep getting permission denied on two files/folders:
jetson-containers run --workdir=/opt/text-generation-webui $(autotag text-generation-webui)
python3 download-model.py --output=/data/models/text-generation-webui
TheBloke/llava-v1.5-13B-GPTQ
bash: /root/bin/autotag: Permission denied
bash: /usr/local/bin/jetson-containers: Permission denied
URL: LLaVA - NVIDIA Jetson AI Lab
Tried a few chmod commands, but no luck unfortunately
Thank you
Hi again ,same issue for the dusty-nv project:
root@ubuntu:/media/kopbeen/steek2_0/jetson-containers/dusty-nv# sudo jetson-containers run $(autotag cosmos)
sudo: jetson-containers: command not found
root@ubuntu:/media/kopbeen/steek2_0/jetson-containers/dusty-nv# sudo chown root:root /usr/local/bin/jetson-containers
chown: changing ownership of ‘/usr/local/bin/jetson-containers’: Operation not permitted
root@ubuntu:/media/kopbeen/steek2_0/jetson-containers/dusty-nv# ls -l /usr/local/bin/jetson-containers
**lrwxrwxrwx 1 root root 86 Nov 5 12:06 /usr/local/bin/jetson-containers → /media/kopbeen/steek2_0/jetson-containers/dusty-nv/jetson-containers/jetson-containers
root@ubuntu:/media/kopbeen/steek2_0/jetson-containers/dusty-nv# ls -l /root/bin/autotag
lrwxrwxrwx 1 root root 67 Nov 5 09:07 /root/bin/autotag → /media/kopbeen/steek2_0/jetson-containers/jetson-containers/autotag
More info on the “permission denied”
Tried:
  1. Failed to start docker.service: Unit is masked - General - Docker Community Forums
  2. Unmasking: Google search “Failed to restart docker.service: Unit docker.service is masked.”
root@ubuntu:/media/kopbeen/steek2_0/jetson-containers/dusty-nv# sudo jq ‘. + {“default-runtime”: “nvidia”}’ /etc/docker/daemon.json | sudo tee /etc/docker/daemon.json.tmp && sudo mv /etc/docker/daemon.json.tmp /etc/docker/daemon.json
“default-runtime”: “nvidia”,
“runtimes”: {
“nvidia”: {
“args”: ,
“path”: “nvidia-container-runtime”
root@ubuntu:/media/kopbeen/steek2_0/jetson-containers/dusty-nv# docker ps -q
root@ubuntu:/media/kopbeen/steek2_0/jetson-containers/dusty-nv# jetson-containers run --workdir=/opt/text-generation-webui $(autotag text-generation-webui)
python3 server.py --listen
–model-dir /data/models/text-generation-webui
–model TheBloke_llava-v1.5-13B-GPTQ
–multimodal-pipeline llava-v1.5-13b
–loader autogptq
–disable_exllama
–verbose
Hi pieterc,
I have moved your post to the Jetson projects section of the forum to get you some better visibility.
Cheers,
Aharpster
Thanks a million
Pieter Claassens
Software Engineer
SHOCK Electro-Optic Systems
Cell: +27 83 561 8577
WhatsApp: +27 68 742 8101
Good day, Aharpster.
Can you please share the link where the post is now located ? Still permission denied when trying to launch the container…
bash: /usr/local/bin/autotag: Permission denied
.. tried the sudo chmod -R 777 command on the above mentioned folder/files - but no luck … maybe I am missing something trivial ?
This command: jetson-containers run --workdir=/opt/text-generation-webui $(autotag text-generation-webui)
root@jetson-host:/media/kopbeen/STK_WIN_LIN/test/nvidia/dusty-nv/jetson-containers# jetson-containers run --workdir=/opt/text-generation-webui $(autotag text-generation-webui) python3 server.py --listen --model-dir /data/models/text-generation-webui --model TheBloke_llava-v1.5-13B-GPTQ --multimodal-pipeline llava-v1.5-13b --loader autogptq --disable_exllama --verbose --cap-add LINUX_IMMUTABLE
bash: /usr/local/bin/jetson-containers: Is a directory (yes it is ?)
Could you login with a USER account and install jetson-container with the below command:
git clone https://github.com/dusty-nv/jetson-containers
bash jetson-containers/install.sh
