With both CUDA 7.5 or CUDA 8.0, the deviceQuery is failing.
$ ./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 38
-> no CUDA-capable device is detected
Result = FAIL
#1 Results With CUDA 7.5: (a couple of months ago)
installed CUDA 7.5 and CUDNN 5.x
deviceQuery did not work
uninstalled CUDA 7.5 using uninstall perl script
#2 Results with CUDA 8.: (one month ago)
installed CUDA 8 (From Nvidia site, with local dmg installer)
installed Cudnn libs as required
deviceQuery did not work !!
uninstalled CUDA using the uninstall perl script
#3 Re-installed CUDA 7.5: (last week)
Using dmg: cuda_7.5.27_mac.dmg (local, not network)
again deviceQuery failed as before
I’ve now spent roughly two months (off and on) trying to figure out how to get deviceQuery to report correct status – but no dice.
[My understanding is that once deviceQuery reports correct GPU info… TensorFlow will be able to recognize and use the GPU.
I’ll of course use the GPU capable TensorFlow library]
Can anybody help?? Anybody seen this problem? I’m not sure what I’m missing.
Thanks!!
AtulA
---------- Driver ----------
CUDA Driver Version: 7.5.27
GPU Driver Version: 10.10.14 310.42.25f02
Model Name: MacBook Pro
Model Identifier: MacBookPro11,3
Processor Name: Intel Core i7
Processor Speed: 2.3 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 6 MB
Memory: 16 GB
Boot ROM Version: MBP112.0138.B17
SMC Version (system): 2.19f12
Does this mean CUDA driver is installed correctly, or not?
The driver: (from Apple > System Preferences > CUDA): CUDA Driver Version: 8.0.57
my results:
./deviceQuery
Result = FAIL
IN brief – because deviceQuery does not recognize the GPU, TensorFlow gives an error.
For the life of me, I can’t find where this error is coming from: "libcuda reported version is: 310.42.25; kernel reported version is: Invalid argument: expected %d.%d or %d.%d.%d form for driver version; got “”
What does this mean (from Apple > System Preference > CUDA)
<b>GPU Driver Version: 10.10.14 310.42.25f02</b>
Is there a way to upgrade this NVIDIA Display driver from 310.42.2f02 to something new?
How? and where would I get the update from?
(This is for Mac OS X 10.11.6]
I am having the same problem , but with a gtx 770 . Very frustrating. I hope someone (Apple, nvidia) can shed some light on this problem. thanks for the post. fti here are my details below.
Version: 8.0.90
Obtained from: Identified Developer
Last Modified: 2/14/18, 12:46 PM
Kind: Intel
64-Bit (Intel): Yes
Signed by: Developer ID Application: NVIDIA Corporation (6KR3T733EC), Developer ID Certification Authority, Apple Root CA
Private: No
CUDA Driver Version: 8.0.90
