HELP ! ! Depth Component opengl interop
Help Please,I created depth image in opengl and want to compare with another image using cuda
here is how I create texture
glGenTextures(1,&texture);
	glBindTexture(GL_TEXTURE_2D,texture);
	glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
    glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
	glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE);
    glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE);
    glTexParameteri(GL_TEXTURE_2D, GL_GENERATE_MIPMAP, GL_TRUE);
	glTexImage2D(GL_TEXTURE_2D, 0, GL_DEPTH_COMPONENT32F, TEXTURE_WIDTH, TEXTURE_HEIGHT, 0, GL_DEPTH_COMPONENT, GL_FLOAT, 0);
	glBindTexture(GL_TEXTURE_2D,0);
I register texture using cudaGraphicsGLRegisterImage()
however it crash when I want to copy my result back from computation, at line
cudaMemcpyToArray(dstArray,0,0,g_dstBuffer,bufferSize,cudaMemcpyDeviceToDevice);
the problem seem to the size of the array as I don’t know the data type of texture, I try random data type,but not successful Please Help !!
here is the full code
#include <cuda_runtime_api.h>
#include <cuda.h>
#include "cutil.h"
#include "cutil_inline_runtime.h"
#include "math_functions.h"
#define __cplusplus
#define __CUDACC__
#include "texture_fetch_functions.h"
#include "cuda_texture_types.h"
#define BLOCK_SIZE 16
float4* g_dstBuffer = NULL;
float4* g_srcBuffer = NULL;
size_t g_BufferSize =0;
texture<float4, cudaTextureType2D, cudaReadModeElementType> texRef;
__global__ void postProcessKernel(float4* dst, float4* src,unsigned int imgWidth, unsigned int imgHeight)
	int x = threadIdx.x + blockIdx.x * blockDim.x;
	int y = threadIdx.y + blockIdx.y * blockDim.y;
	if(x>imgWidth || y >imgHeight) return;
	unsigned int index = y*imgWidth + x;
	float4 tempcolor;
	float4 color = tex2D(texRef,x,y);
	tempcolor = color;
	dst[index] = tempcolor;
	__syncthreads();
	return;
void postProcessCUDA(cudaGraphicsResource_t &dst, cudaGraphicsResource_t &src1, cudaGraphicsResource_t &src2, unsigned int width, unsigned int height)
	cudaGraphicsResource_t resources[3] = {src1,src2,dst};
	 cudaGraphicsMapResources(3,resources) ;
	cudaArray* src1Array;
	cudaArray* src2Array;
	cudaArray* dstArray;
	cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc(4,0,0,0,cudaChannelFormatKindFloat);
	const textureReference* texRefPtr;
	cudaGetTextureReference(&texRefPtr,"texRef");
	 cudaGraphicsSubResourceGetMappedArray (&src1Array,src1,0,0);
	 cudaGraphicsSubResourceGetMappedArray (&src2Array,src2,0,0);
	 cudaGraphicsSubResourceGetMappedArray (&dstArray,dst,0,0);
	cudaBindTextureToArray( texRefPtr,src1Array,&channelDesc);
	size_t bufferSize = width*height*sizeof(float4);
	if(g_BufferSize != bufferSize)
		if(g_dstBuffer !=NULL)
			cudaFree(g_dstBuffer);
		if(g_srcBuffer != NULL)
			cudaFree(g_srcBuffer);
		g_BufferSize = bufferSize;
		cudaMalloc((void**) &g_dstBuffer, g_BufferSize);
		cudaMalloc((void**) &g_srcBuffer,g_BufferSize);
	size_t blocksW = (size_t) ceilf (width /(float) BLOCK_SIZE );
	size_t blocksH = (size_t) ceilf( height / (float) BLOCK_SIZE);
	dim3 gridDim( blocksW,blocksH,1);
	dim3 blockDim(BLOCK_SIZE,BLOCK_SIZE,1);
	//cudaMemcpyFromArray(g_srcBuffer,src1Array,0,0,bufferSize,cudaMemcpyDeviceToDevice);
	postProcessKernel<<<gridDim,blockDim>>>(g_dstBuffer,g_srcBuffer,width,height);
	cudaError_t b;
	cudaUnbindTexture (texRefPtr);
	cudaGraphicsUnmapResources(3,resources);
	return ;
