Help! Why is the GPU acceleration ratio so small compared to the CPU in Jetson Orin Nano 8G?
In the following simple example program, the CPU time is 42ms and the GPU time is 17ms, which is only 2.4 times faster. The same code takes 38ms on the CPU and 5ms on the GPU on my laptop (CPU: R7-5800H, GPU: 2060), which is almost 8 times faster. Why is that?
nvcc -V
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Sun_Oct_23_22:16:07_PDT_2022
Cuda compilation tools, release 11.4, V11.4.315
Build cuda_11.4.r11.4/compiler.31964100_0
Code:
#include <omp.h>
#include <chrono>
#include <iostream>
#include <vector>
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#define TICK(x) auto bench_##x = std::chrono::steady_clock::now()
#define TOCK(x)        \
    auto x = std::chrono::duration_cast<std::chrono::duration<double>>(std::chrono::steady_clock::now() - bench_##x) \
                 .count();        \
    std::cout << #x ": " << x << "s" << std::endl
template <typename T>
__global__ void vector_add_gpu(T *a, T *b, T *c, int n) {
    int tid = blockIdx.x * blockDim.x + threadIdx.x;
    const int t_n = gridDim.x * blockDim.x;
    while (tid < n) {
        c[tid] = a[tid] * b[tid] + c[tid];
        tid += t_n;
void TestVectorAddGPU() {
    int n = 1 << 25;
    T *a = new T[n];
    T *b = new T[n];
    T *c1 = new T[n];
    for (int i = 0; i < n; ++i)
        a[i] = (double)i / n;
        b[i] = 1 + (double)i / n;
        c1[i] = 2 + (double)i / n;
    T *dev_a, *dev_b, *dev_c;
    cudaMalloc(&dev_a, sizeof(T) * n);
    cudaMemcpy(dev_a, a, sizeof(T) * n, cudaMemcpyHostToDevice);
    cudaMalloc(&dev_b, sizeof(T) * n);
    cudaMemcpy(dev_b, b, sizeof(T) * n, cudaMemcpyHostToDevice);
    cudaMalloc(&dev_c, sizeof(T) * n);
    cudaMemcpy(dev_c, c1, sizeof(T) * n, cudaMemcpyHostToDevice);
    cudaDeviceSynchronize();
    // Time for CPU begins.
    TICK(CPU_Calculate);
#pragma omp parallel for
        c1[i] = a[i] * b[i] + c1[i];
    TOCK(CPU_Calculate);
    // Time for CPU ends.
    // Time for GPU begins.
    TICK(GPU_Calculate);
    vector_add_gpu<<<512, 128>>>(dev_a, dev_b, dev_c, n);
    TOCK(GPU_Calculate);
    // Time for GPU ends.
    // Check for correctness
    T *c2 = new T[n];
    cudaMemcpy(c2, dev_c, sizeof(T) * n, cudaMemcpyDeviceToHost);
        if (fabs(c1[i] - c2[i]) > 1e-6) {
            std::cerr << "error!";
            printf("i: %d, c1: %f c2: %f\n", i, c1[i], c2[i]);
            abort();
    cudaFree(dev_a);
    cudaFree(dev_b);
    cudaFree(dev_c);
    delete[] a;
    delete[] b;
    delete[] c1;
    delete[] c2;
int main() {
    for (int i = 0; i < 10; ++i) {
        TestVectorAddGPU<double>();
    return 0;
I can’t answer, but your code could be set up to be more readable by using the forum “code” formatting. You could either click the “pencil” icon in the lower right of your existing post to start editing, and then highlight the code, followed by clicking the “</>” icon in the middle of the icons on the top, or else you could edit, and place three backquotes above and below the code (ignore that backspace, ‘\’, I have to escape it to let the forum actually show three back quotes…the unshifted key with the tilde ‘~’):
Thanks for your advice. I have changed the code format.
Have you maximized the device performance before the measurement?
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
  • I type “sudo nvpmodel -q”, it shows:
  • NV Power Mode: 10W
    0
Do you run the jetson_clocks script to lock the clock to the maximum?
If no, the default setting is dynamic frequency indicates the clock might be lower when the tasks are not full.
