I am facing problem calling the cublasDtrsm() function from cublas library. The output I am getting is incorrect. For example, I am trying to solve a matrix equation AX=alphaB. I am getting value of X to be the exact same as alpha*B. Could you please point out where I am going wrong? Is my call to cublasSDtrsm() correct?
I am attaching the sample output for matrices A, B and X below. The entire code is also attached.
Printing A:
1 0 0 0 0
0.783099 1 0 0 0
0.911647 0.364784 1 0 0
0.335223 0.95223 0.242887 1 0
0.277775 0.635712 0.804177 0.218257 1
Printing B:
0.840188 0.55397 0.717297 0.156679 0.512932
0.394383 0.477397 0.141603 0.400944 0.839112
0.79844 0.628871 0.606969 0.12979 0.61264
0.197551 0.513401 0.0163006 0.108809 0.296032
0.76823 0.916195 0.137232 0.998925 0.637552
Now calling cublasDtrsm
Printing X:
Here is the entire code:
#include <iostream>
#include <cstdlib>
#include <iomanip>
#include "cublas.h"
#define N (5)
#define IDX2C(i,j,N) (((j)*(N))+(i))
typedef unsigned int uint;
using namespace std;
void print_matrix(double *A, int num) {
for(int i=0; i<num*num; i++) {
cout<<setw(10)<<setprecision(6)<<A[i]<<" ";
if((i+1)%N==0) cout<<endl;
int main(int argc, char *argv[]) {
cublasStatus status;
double *h_A;
double *h_B;
double *d_A = 0;
double *d_B = 0;
double alpha = 1.0;
int n2 = N*N;
int i;
status = cublasInit();
if (status != CUBLAS_STATUS_SUCCESS) {
cerr<<"!!!! CUBLAS initialization error"<<endl;
return EXIT_FAILURE;
h_A = new double[n2];
if (h_A == 0) {
cerr<<"!!!! host memory allocation error (A)"<<endl;
h_B = new double[n2];
if (h_B == 0) {
cerr<<"!!!! host memory allocation error (B)"<<endl;
h_C = new double[n2];
if (h_C == 0) {
// Fill the matrices with test data
for(int i=0; i<N; i++) {
for(int j=0; j<N; j++) {
h_B[IDX2C(i,j,N)] = rand() / (double)RAND_MAX;
if(i<j) {
h_A[IDX2C(i,j,N)] = rand() / (double)RAND_MAX;
else if (i>j) {
h_A[IDX2C(i,j,N)] = 0.0;
else if (i==j) {
h_A[IDX2C(i,j,N)] = 1.0;
else {
cerr<<"!!!! Indexing error while filling matrix data"<<endl;
status = cublasAlloc(n2, sizeof(d_A[0]), (void**)&d_A);
if(status != CUBLAS_STATUS_SUCCESS) {
cerr<<"!!!! device memory allocation error (A)"<<endl;
status = cublasAlloc(n2, sizeof(d_B[0]), (void**)&d_B);
cerr<<"!!!! device memory allocation error (B)"<<endl;
status = cublasSetVector(n2, sizeof(h_A[0]), h_A, 1, d_A, 1);
cerr<<"!!!! device access error (write A)"<<endl;
status = cublasSetVector(n2, sizeof(h_B[0]), h_B, 1, d_B, 1);
cerr<<"!!!! device access error (write B)"<<endl;
cout<<"Printing A: "<<endl;
print_matrix(h_A,N);
cout<<"Printing B: "<<endl;
print_matrix(h_B,N);
cout<<"Now calling cublasDtrsm"<<endl;
//Clear last error
cublasGetError();
cublasDtrsm('l', 'l', 'n', 'n', N, N, alpha, d_A, N, d_B, N);
status = cublasGetError();
cerr<<"!!!! kernel execution error"<<endl;
double *h_C = new double[n2];
status = cublasGetVector(n2, sizeof(h_B[0]), d_B, 1, h_C, 1);
cerr<<"!!!! devide access error (read B)"<<endl;
cout<<"Printing X: "<<endl;
print_matrix(h_C,N);
return 0;
