Hi all!
I encoded a series of pictures as a raw x265 bitstream, named “output.hevc”. When I use NvDecoder (provided in the samples), I can decode the video just fine.
However, when I place “output.hevc” in a container, named “output.mp4”, it doesn’t decode anything.
Provided sample used: AppDecD3D, from Video SDK 8.1.
Things I’ve checked:
- I used the provided FFmpegDemuxer.h and demuxed the first two frames of both files. The data that has been read is similar for both files, although not entirely the same.
- Tested on two separate systems (Win 10, i7 4770K, GTX 1050Ti and Win 10, i7 8770, GTX 1080).
- While running in a debugger, FFmpegDemux reports that codec AV_CODEC_ID_HEVC has been detected, and passes cudaVideoCodec_HEVC to the NvDecoder.
- Obviously, I verified that both files play just fine using VLC and ffplay
- FFmpeg DLLs are provided in the samples, so I just used those (avcodec-57.dll, avformat-57.dll, ...)
I have included a .zip file with my videos,and the results of av_read_frame() for frames 0 and 1 for both files. It can be found at this url: https://www.dropbox.com/s/b0k54mme2s2xmu1/NVDEC_x265ContainerIssue.zip?dl=0
