Hi,Freeze when starting with 2 GPUs stuck with 2 cards and 1 monitor
I am stuck with my 2 cards and 1 monitor.
Hardware:
PSU 650W
Asus P5W DH Deluxe
Intel PeniumD 3.4GHz
2 GB RAM
GeForce 7600 GS, 256MB
GeForce 8800 Ultra
aic7xxx SCSI card
3HDs, 1 mirrored
Software:
RHEL 4 Update 3 (Linux 2.6.9-34 ELsmp)
NVidia 100.11.19
I have installed
GeForce 7600 GS as primary card connected to a CRT
and 8800 Ultra as “work horse” without display.
I can do runlevel 3, but when I want to start with X
it randomly starts or freezes i.e. no mouse, no kbd, black screen.
There is no difference in the log file though…
Please, can you help me?
#/sbin/lspci | grep VGA
06:00:0 VGA compatible controller: NVidia Corporation: Unknown device 0194 (rev a2)
07:00:0 VGA compatible controller: NVidia Corporation: Unknown device 0392 (rev a1)
$cat xorg.conf
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 1.0 (buildmeister@builder3) Wed Sep 12 14:29:35 PDT 2007
Xorg configuration created by system-config-display
Section “ServerLayout”
Identifier “Default Layout”
Screen 0 “Screen0” 0 0
InputDevice “Mouse0” “CorePointer”
InputDevice “Keyboard0” “CoreKeyboard”
EndSection
Section “Files”
RgbPath “/usr/X11R6/lib/X11/rgb”
FontPath “unix/:7100”
EndSection
Section “Module”
Load “dbe”
Load “extmod”
Load “fbdevhw”
Load “glx”
Load “record”
Load “freetype”
Load “type1”
EndSection
Section “InputDevice”
Identifier “Keyboard0”
Driver “kbd”
Option “XkbModel” “pc105”
Option “XkbLayout” “uk”
EndSection
Identifier “Mouse0”
Driver “mouse”
Option “Protocol” “IMPS/2”
Option “Device” “/dev/input/mice”
Option “ZAxisMapping” “4 5”
Option “Emulate3Buttons” “yes”
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Iiyama”
ModelName “Vision Master Pro 454”
Option “dpms”
EndSection
Section “Device”
Identifier “Videocard0”
Driver “nvidia”
VendorName “NVidia”
BoardName “GeForce 7600 GS”
Option “UseDisplayDevice” “CRT-1”
BusID “PCI:7:0:0”
Screen 0
EndSection
Section “Device”
Identifier “Videocard1”
Driver “nvidia”
VendorName “NVidia”
BoardName “GeForce 8800 Ultra”
Option “UseDisplayDevice” “none”
BusID “PCI:6:0:0”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Videocard0”
Monitor “Monitor0”
DefaultDepth 16
SubSection “Display”
Viewport 0 0
Depth 16
Modes “1024x768” “800x600” “640x480”
EndSubSection
EndSection
$cat /var/log/Xorg.0.log
X Window System Version 6.8.2
Release Date: 9 February 2005
X Protocol Version 11, Revision 0, Release 6.8.2
Build Operating System: Linux 2.6.9-22.18.bz155725.ELsmp i686 [ELF]
Current Operating System: Linux localhost.localdomain 2.6.9-34.ELsmp #1 SMP Fri Feb 24 16:54:53 EST 2006 i686
Build Date: 11 January 2006
Build Host: hs20-bc1-7.build.redhat.com
Before reporting problems, check [url="http://wiki.X.Org"]http://wiki.X.Org[/url]
to make sure that you have the latest version.
Module Loader present
OS Kernel: Linux version 2.6.9-34.ELsmp (bhcompile@hs20-bc1-7.build.redhat.com) (gcc version 3.4.5 20051201 (Red Hat 3.4.5-2)) #1 SMP Fri Feb 24 16:54:53 EST 2006 P
Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: “/var/log/Xorg.0.log”, Time: Tue Nov 13 11:47:07 2007
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
) |–>Screen “Screen0” (0)
() | |–>Monitor “Monitor0”
) | |–>Device “Videocard0”
() |–>Input Device “Mouse0”
) |–>Input Device “Keyboard0”
() FontPath set to “unix/:7100”
) RgbPath set to “/usr/X11R6/lib/X11/rgb”
(==) ModulePath set to “/usr/X11R6/lib/modules”
(WW) Open APM failed (/dev/apm_bios) (No such file or directory)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.7
X.Org XInput driver : 0.4
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: “bitmap”
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor=“X.Org Foundation”
compiled for 6.8.2, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: “pcidata”
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor=“X.Org Foundation”
ABI class: X.Org Video Driver, version 0.7
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,277c card 1043,8178 rev c0 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,277d card 0000,0000 rev c0 class 06,04,00 hdr 01
(II) PCI: 00:03:0: chip 8086,277a card 0000,0000 rev c0 class 06,04,00 hdr 01
(II) PCI: 00:1b:0: chip 8086,27d8 card 1043,81d8 rev 01 class 04,03,00 hdr 00
(II) PCI: 00:1c:0: chip 8086,27d0 card 0000,0000 rev 01 class 06,04,00 hdr 81
(II) PCI: 00:1c:3: chip 8086,27d6 card 0000,0000 rev 01 class 06,04,00 hdr 81
(II) PCI: 00:1c:4: chip 8086,27e0 card 0000,0000 rev 01 class 06,04,00 hdr 81
(II) PCI: 00:1c:5: chip 8086,27e2 card 0000,0000 rev 01 class 06,04,00 hdr 81
(II) PCI: 00:1d:0: chip 8086,27c8 card 1043,8179 rev 01 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,27c9 card 1043,8179 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,27ca card 1043,8179 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:1d:3: chip 8086,27cb card 1043,8179 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,27cc card 1043,8179 rev 01 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev e1 class 06,04,01 hdr 01
(II) PCI: 00:1f:0: chip 8086,27b8 card 1043,8179 rev 01 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,27df card 1043,8179 rev 01 class 01,01,8a hdr 00
(II) PCI: 00:1f:2: chip 8086,27c3 card 1043,2604 rev 01 class 01,04,00 hdr 00
(II) PCI: 00:1f:3: chip 8086,27da card 1043,8179 rev 01 class 0c,05,00 hdr 00
(II) PCI: 01:00:0: chip 9004,5078 card 9004,7850 rev 03 class 01,00,00 hdr 00
(II) PCI: 01:03:0: chip 104c,8023 card 1043,815b rev 00 class 0c,00,10 hdr 00
(II) PCI: 02:00:0: chip 197b,2363 card 1043,81e4 rev 02 class 01,01,85 hdr 00
(II) PCI: 03:00:0: chip 11ab,4362 card 1043,8142 rev 20 class 02,00,00 hdr 00
(II) PCI: 04:00:0: chip 11ab,4362 card 1043,8142 rev 20 class 02,00,00 hdr 00
(II) PCI: 06:00:0: chip 10de,0194 card 1043,8248 rev a2 class 03,00,00 hdr 00
(II) PCI: 07:00:0: chip 10de,0392 card 0000,0000 rev a1 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,7), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 7: bridge is at (0:1:0), (0,7,7), BCTRL: 0x000a (VGA_EN is set)
(II) Bus 7 I/O range:
[0] -1 0 0x0000c000 - 0x0000cfff (0x1000) IX[B]
(II) Bus 7 non-prefetchable memory range:
[0] -1 0 0xfaa00000 - 0xfeafffff (0x4100000) MX[B]
(II) Bus 7 prefetchable memory range:
[0] -1 0 0xcff00000 - 0xefefffff (0x20000000) MX[B]
(II) Bus 6: bridge is at (0:3:0), (0,6,6), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 6 I/O range:
[0] -1 0 0x0000b000 - 0x0000bfff (0x1000) IX[B]
(II) Bus 6 non-prefetchable memory range:
[0] -1 0 0xf4900000 - 0xfa9fffff (0x6100000) MX[B]
(II) Bus 6 prefetchable memory range:
[0] -1 0 0xaff00000 - 0xcfefffff (0x20000000) MX[B]
(II) Bus 5: bridge is at (0:28:0), (0,5,5), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 5 prefetchable memory range:
[0] -1 0 0xafe00000 - 0xafefffff (0x100000) MX[B]
(II) Bus 4: bridge is at (0:28:3), (0,4,4), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 4 I/O range:
[0] -1 0 0x0000a000 - 0x0000afff (0x1000) IX[B]
(II) Bus 4 non-prefetchable memory range:
[0] -1 0 0xf4800000 - 0xf48fffff (0x100000) MX[B]
(II) Bus 3: bridge is at (0:28:4), (0,3,3), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 3 I/O range:
[0] -1 0 0x00009000 - 0x00009fff (0x1000) IX[B]
(II) Bus 3 non-prefetchable memory range:
[0] -1 0 0xf4700000 - 0xf47fffff (0x100000) MX[B]
(II) Bus 2: bridge is at (0:28:5), (0,2,2), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x00008000 - 0x00008fff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xf4600000 - 0xf46fffff (0x100000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:30:0), (0,1,1), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 1 I/O range:
[0] -1 0 0x00007000 - 0x00007fff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xf4500000 - 0xf45fffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI: (6:0:0) nVidia Corporation unknown chipset (0x0194) rev 162, Mem @ 0xf9000000/24, 0xb0000000/28, 0xf6000000/25, I/O @ 0xbc00/7, BIOS @ 0xfa9e0000/17
(–) PCI:*(7:0:0) nVidia Corporation unknown chipset (0x0392) rev 161, Mem @ 0xfd000000/24, 0xd0000000/28, 0xfc000000/24, I/O @ 0xcc00/7, BIOS @ 0xfeae0000/17
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MXB
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xf48fc000 - 0xf48fffff (0x4000) MX[B]
[1] -1 0 0xf47fc000 - 0xf47fffff (0x4000) MX[B]
[2] -1 0 0xf46fe000 - 0xf46fffff (0x2000) MX[B]
[3] -1 0 0xf45f8000 - 0xf45fbfff (0x4000) MX[B]
[4] -1 0 0xf45fe800 - 0xf45fefff (0x800) MX[B]
[5] -1 0 0xf45ff000 - 0xf45fffff (0x1000) MX[B]
[6] -1 0 0xfebfb800 - 0xfebfbbff (0x400) MX[B]
[7] -1 0 0xfebfbc00 - 0xfebfbfff (0x400) MX[B]
[8] -1 0 0xfebfc000 - 0xfebfffff (0x4000) MX[B]
[9] -1 0 0xfeae0000 - 0xfeafffff (0x20000) MXB
[10] -1 0 0xfc000000 - 0xfcffffff (0x1000000) MXB
[11] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MXB
[12] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MXB
[13] -1 0 0xfa9e0000 - 0xfa9fffff (0x20000) MXB
[14] -1 0 0xf6000000 - 0xf7ffffff (0x2000000) MXB
[15] -1 0 0xb0000000 - 0xbfffffff (0x10000000) MXB
[16] -1 0 0xf9000000 - 0xf9ffffff (0x1000000) MXB
[17] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[18] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[19] -1 0 0x00008400 - 0x0000840f (0x10) IX[B]
[20] -1 0 0x00008480 - 0x00008483 (0x4) IX[B]
[21] -1 0 0x00008800 - 0x00008807 (0x8) IX[B]
[22] -1 0 0x00008880 - 0x00008883 (0x4) IX[B]
[23] -1 0 0x00008c00 - 0x00008c07 (0x8) IX[B]
[24] -1 0 0x00000400 - 0x0000041f (0x20) IX[B]
[25] -1 0 0x0000d880 - 0x0000d88f (0x10) IX[B]
[26] -1 0 0x0000dc00 - 0x0000dc03 (0x4) IX[B]
[27] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B]
[28] -1 0 0x0000e080 - 0x0000e083 (0x4) IX[B]
[29] -1 0 0x0000e400 - 0x0000e407 (0x8) IX[B]
[30] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[31] -1 0 0x0000ec00 - 0x0000ec1f (0x20) IX[B]
[32] -1 0 0x0000e880 - 0x0000e89f (0x20) IX[B]
[33] -1 0 0x0000e800 - 0x0000e81f (0x20) IX[B]
[34] -1 0 0x0000e480 - 0x0000e49f (0x20) IX[B]
[35] -1 0 0x0000cc00 - 0x0000cc7f (0x80) IXB
[36] -1 0 0x0000bc00 - 0x0000bc7f (0x80) IXB
(II) Inactive PCI resource ranges:
[0] -1 0 0x00007800 - 0x000078ff (0x100) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) Inactive PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xf48fc000 - 0xf48fffff (0x4000) MX[B]
[6] -1 0 0xf47fc000 - 0xf47fffff (0x4000) MX[B]
[7] -1 0 0xf46fe000 - 0xf46fffff (0x2000) MX[B]
[8] -1 0 0xf45f8000 - 0xf45fbfff (0x4000) MX[B]
[9] -1 0 0xf45fe800 - 0xf45fefff (0x800) MX[B]
[10] -1 0 0xf45ff000 - 0xf45fffff (0x1000) MX[B]
[11] -1 0 0xfebfb800 - 0xfebfbbff (0x400) MX[B]
[12] -1 0 0xfebfbc00 - 0xfebfbfff (0x400) MX[B]
[13] -1 0 0xfebfc000 - 0xfebfffff (0x4000) MX[B]
[14] -1 0 0xfeae0000 - 0xfeafffff (0x20000) MXB
[15] -1 0 0xfc000000 - 0xfcffffff (0x1000000) MXB
[16] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MXB
[17] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MXB
[18] -1 0 0xfa9e0000 - 0xfa9fffff (0x20000) MXB
[19] -1 0 0xf6000000 - 0xf7ffffff (0x2000000) MXB
[20] -1 0 0xb0000000 - 0xbfffffff (0x10000000) MXB
[21] -1 0 0xf9000000 - 0xf9ffffff (0x1000000) MXB
[22] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[23] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[24] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[25] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[26] -1 0 0x00008400 - 0x0000840f (0x10) IX[B]
[27] -1 0 0x00008480 - 0x00008483 (0x4) IX[B]
[28] -1 0 0x00008800 - 0x00008807 (0x8) IX[B]
[29] -1 0 0x00008880 - 0x00008883 (0x4) IX[B]
[30] -1 0 0x00008c00 - 0x00008c07 (0x8) IX[B]
[31] -1 0 0x00000400 - 0x0000041f (0x20) IX[B]
[32] -1 0 0x0000d880 - 0x0000d88f (0x10) IX[B]
[33] -1 0 0x0000dc00 - 0x0000dc03 (0x4) IX[B]
[34] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B]
[35] -1 0 0x0000e080 - 0x0000e083 (0x4) IX[B]
[36] -1 0 0x0000e400 - 0x0000e407 (0x8) IX[B]
[37] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[38] -1 0 0x0000ec00 - 0x0000ec1f (0x20) IX[B]
[39] -1 0 0x0000e880 - 0x0000e89f (0x20) IX[B]
[40] -1 0 0x0000e800 - 0x0000e81f (0x20) IX[B]
[41] -1 0 0x0000e480 - 0x0000e49f (0x20) IX[B]
[42] -1 0 0x0000cc00 - 0x0000cc7f (0x80) IXB
[43] -1 0 0x0000bc00 - 0x0000bc7f (0x80) IXB
[44] -1 0 0x00007800 - 0x000078ff (0x100) IX[B]
(II) LoadModule: “dbe”
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor=“X.Org Foundation”
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.2
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “extmod”
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor=“X.Org Foundation”
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “fbdevhw”
(II) Loading /usr/X11R6/lib/modules/linux/libfbdevhw.a
(II) Module fbdevhw: vendor=“X.Org Foundation”
compiled for 6.8.2, module version = 0.0.2
(II) LoadModule: “glx”
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.so
(II) Module glx: vendor=“NVIDIA Corporation”
compiled for 4.0.2, module version = 1.0.0
ABI class: X.Org Server Extension, version 0.1
(II) NVIDIA GLX Module 100.14.19 Wed Sep 12 14:48:02 PDT 2007
(II) Loading extension GLX
(II) LoadModule: “record”
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor=“X.Org Foundation”
compiled for 6.8.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “freetype”
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.so
(II) Module freetype: vendor=“X.Org Foundation & the After X-TT Project”
compiled for 6.8.2, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: “type1”
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor=“X.Org Foundation”
compiled for 6.8.2, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: “nvidia”
(II) Loading /usr/X11R6/lib/modules/drivers/nvidia_drv.so
(II) Module nvidia: vendor=“NVIDIA Corporation”
Module class: X.Org Video Driver
(II) LoadModule: “mouse”
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor=“X.Org Foundation”
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.4
(II) LoadModule: “kbd”
(II) Loading /usr/X11R6/lib/modules/input/kbd_drv.o
(II) Module kbd: vendor=“X.Org Foundation”
(II) NVIDIA dlloader X Driver 100.14.19 Wed Sep 12 14:14:20 PDT 2007
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 07:00:0
(WW) NVIDIA: No matching Device section for instance (BusID PCI:6:0:0) found
(–) Chipset NVIDIA GPU found
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor=“X.Org Foundation”
ABI class: X.Org ANSI C Emulation, version 0.2
(II) Loading sub module “wfb”
(II) LoadModule: “wfb”
(II) Loading /usr/X11R6/lib/modules/libwfb.so
(II) Module wfb: vendor=“NVIDIA Corporation”
compiled for 4.23.73Vz, module version = 1.0.0
(II) Loading sub module “ramdac”
(II) LoadModule: “ramdac”
(II) Loading /usr/X11R6/lib/modules/libramdac.a
(II) Module ramdac: vendor=“X.Org Foundation”
compiled for 6.8.2, module version = 0.1.0
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[22] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[23] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[24] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[25] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[26] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[27] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[28] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[29] -1 0 0x00008400 - 0x0000840f (0x10) IX[B]
[30] -1 0 0x00008480 - 0x00008483 (0x4) IX[B]
[31] -1 0 0x00008800 - 0x00008807 (0x8) IX[B]
[32] -1 0 0x00008880 - 0x00008883 (0x4) IX[B]
[33] -1 0 0x00008c00 - 0x00008c07 (0x8) IX[B]
[34] -1 0 0x00000400 - 0x0000041f (0x20) IX[B]
[35] -1 0 0x0000d880 - 0x0000d88f (0x10) IX[B]
[36] -1 0 0x0000dc00 - 0x0000dc03 (0x4) IX[B]
[37] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B]
[38] -1 0 0x0000e080 - 0x0000e083 (0x4) IX[B]
[39] -1 0 0x0000e400 - 0x0000e407 (0x8) IX[B]
[40] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[41] -1 0 0x0000ec00 - 0x0000ec1f (0x20) IX[B]
[42] -1 0 0x0000e880 - 0x0000e89f (0x20) IX[B]
[43] -1 0 0x0000e800 - 0x0000e81f (0x20) IX[B]
[44] -1 0 0x0000e480 - 0x0000e49f (0x20) IX[B]
[45] -1 0 0x0000cc00 - 0x0000cc7f (0x80) IXB
[46] -1 0 0x0000bc00 - 0x0000bc7f (0x80) IXB
[47] -1 0 0x00007800 - 0x000078ff (0x100) IX[B]
[48] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[49] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
() NVIDIA(0): Depth 16, (–) framebuffer bpp 16
(==) NVIDIA(0): RGB weight 565
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
) NVIDIA(0): Option “UseDisplayDevice” “CRT-1”
() NVIDIA(0): Enabling RENDER acceleration
(II) NVIDIA(0): NVIDIA GPU GeForce 7600 GS (G73) at PCI:7:0:0 (GPU-0)
(–) NVIDIA(0): Memory: 262144 kBytes
(–) NVIDIA(0): VideoBIOS: 05.73.22.51.00
(II) NVIDIA(0): Detected PCI Express Link width: 8X
(–) NVIDIA(0): Interlaced video modes are supported on this GPU
(–) NVIDIA(0): Connected display device(s) on GeForce 7600 GS at PCI:7:0:0:
(–) NVIDIA(0): Iiyama HM903DADTA (CRT-1)
(–) NVIDIA(0): Iiyama HM903DADTA (CRT-1): 400.0 MHz maximum pixel clock
(II) NVIDIA(0): Assigned Display Device: CRT-1
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0): “1024x768”
(II) NVIDIA(0): “800x600”
(II) NVIDIA(0): “640x480”
(II) NVIDIA(0): Virtual screen size determined to be 1024 x 768
(–) NVIDIA(0): DPI set to (72, 67); computed from “UseEdidDpi” X config
(–) NVIDIA(0): option
(==) NVIDIA(0): Disabling 32-bit ARGB GLX visuals.
(II) do I need RAC? No, I don’t.
(II) resource ranges after preInit:
[0] 0 0 0xfc000000 - 0xfcffffff (0x1000000) MX[B]
[1] 0 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B]
[2] 0 0 0xfd000000 - 0xfdffffff (0x1000000) MX[B]
[3] -1 0 0xffe00000 - 0xffffffff (0x200000) MXB
[4] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[5] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[6] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[7] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[8] -1 0 0xf48fc000 - 0xf48fffff (0x4000) MX[B]
[9] -1 0 0xf47fc000 - 0xf47fffff (0x4000) MX[B]
[10] -1 0 0xf46fe000 - 0xf46fffff (0x2000) MX[B]
[11] -1 0 0xf45f8000 - 0xf45fbfff (0x4000) MX[B]
[12] -1 0 0xf45fe800 - 0xf45fefff (0x800) MX[B]
[13] -1 0 0xf45ff000 - 0xf45fffff (0x1000) MX[B]
[14] -1 0 0xfebfb800 - 0xfebfbbff (0x400) MX[B]
[15] -1 0 0xfebfbc00 - 0xfebfbfff (0x400) MX[B]
[16] -1 0 0xfebfc000 - 0xfebfffff (0x4000) MX[B]
[17] -1 0 0xfeae0000 - 0xfeafffff (0x20000) MXB
[18] -1 0 0xfc000000 - 0xfcffffff (0x1000000) MXB
[19] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MXB
[20] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MXB
[21] -1 0 0xfa9e0000 - 0xfa9fffff (0x20000) MXB
[22] -1 0 0xf6000000 - 0xf7ffffff (0x2000000) MXB
[23] -1 0 0xb0000000 - 0xbfffffff (0x10000000) MXB
[24] -1 0 0xf9000000 - 0xf9ffffff (0x1000000) MXB
[25] 0 0 0x000a0000 - 0x000affff (0x10000) MSB
[26] 0 0 0x000b0000 - 0x000b7fff (0x8000) MSB
[27] 0 0 0x000b8000 - 0x000bffff (0x8000) MSB
[28] 0 0 0x0000cc00 - 0x0000cc7f (0x80) IX[B]
[29] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[30] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[31] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[32] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[33] -1 0 0x00008400 - 0x0000840f (0x10) IX[B]
[34] -1 0 0x00008480 - 0x00008483 (0x4) IX[B]
[35] -1 0 0x00008800 - 0x00008807 (0x8) IX[B]
[36] -1 0 0x00008880 - 0x00008883 (0x4) IX[B]
[37] -1 0 0x00008c00 - 0x00008c07 (0x8) IX[B]
[38] -1 0 0x00000400 - 0x0000041f (0x20) IX[B]
[39] -1 0 0x0000d880 - 0x0000d88f (0x10) IX[B]
[40] -1 0 0x0000dc00 - 0x0000dc03 (0x4) IX[B]
[41] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B]
[42] -1 0 0x0000e080 - 0x0000e083 (0x4) IX[B]
[43] -1 0 0x0000e400 - 0x0000e407 (0x8) IX[B]
[44] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[45] -1 0 0x0000ec00 - 0x0000ec1f (0x20) IX[B]
[46] -1 0 0x0000e880 - 0x0000e89f (0x20) IX[B]
[47] -1 0 0x0000e800 - 0x0000e81f (0x20) IX[B]
[48] -1 0 0x0000e480 - 0x0000e49f (0x20) IX[B]
[49] -1 0 0x0000cc00 - 0x0000cc7f (0x80) IXB
[50] -1 0 0x0000bc00 - 0x0000bc7f (0x80) IXB
[51] -1 0 0x00007800 - 0x000078ff (0x100) IX[B]
[52] 0 0 0x000003b0 - 0x000003bb (0xc) ISB
[53] 0 0 0x000003c0 - 0x000003df (0x20) ISB
(II) NVIDIA(GPU-1): NVIDIA GPU GeForce 8800 Ultra (Unknown) at PCI:6:0:0 (GPU-1)
(–) NVIDIA(GPU-1): Memory: 786432 kBytes
(–) NVIDIA(GPU-1): VideoBIOS: 60.80.18.00.12
(II) NVIDIA(GPU-1): Detected PCI Express Link width: 8X
(–) NVIDIA(GPU-1): Interlaced video modes are supported on this GPU
(–) NVIDIA(GPU-1): Connected display device(s) on GeForce 8800 Ultra at
(–) NVIDIA(GPU-1): PCI:6:0:0:
(II) NVIDIA(0): Initialized GART.
(II) NVIDIA(0): Setting mode “1024x768”
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
) Option “dpms”
() NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) Initializing extension GLX
) Option “Protocol” “IMPS/2”
() Mouse0: Device: “/dev/input/mice”
) Mouse0: Protocol: “IMPS/2”
() Option “CorePointer”
) Mouse0: Core Pointer
() Option “Device” “/dev/input/mice”
) Option “Emulate3Buttons” “yes”
() Mouse0: Emulate3Buttons, Emulate3Timeout: 50
) Option “ZAxisMapping” “4 5”
() Mouse0: ZAxisMapping: buttons 4 and 5
) Mouse0: Buttons: 5
() Option “CoreKeyboard”
) Keyboard0: Core Keyboard
() Option “Protocol” “standard”
) Keyboard0: Protocol: standard
() Option “AutoRepeat” “500 30”
) Option “XkbRules” “xorg”
() Keyboard0: XkbRules: “xorg”
) Option “XkbModel” “pc105”
() Keyboard0: XkbModel: “pc105”
) Option “XkbLayout” “uk”
() Keyboard0: XkbLayout: “uk”
) Option “CustomKeycodes” “off”
(**) Keyboard0: CustomKeycodes disabled
(II) XINPUT: Adding extended input device “Keyboard0” (type: KEYBOARD)
(II) XINPUT: Adding extended input device “Mouse0” (type: MOUSE)
(II) Mouse0: ps2EnableDataReporting: succeeded
Thanks a lot
marher
From your description, it doesn’t sound like you’re using CUDA when you experience this problem. If so, then I’d suggest reading the sticky posts here:
[url=“http://www.nvnews.net/vbulletin/forumdisplay.php?f=14”]http://www.nvnews.net/vbulletin/forumdisplay.php?f=14[/url]
thanks,
Lonni
You are definitely right.
Thanks for this link, I wouldn’t have found it in the huge amount of various infos.
BTW I think I fixed the stability problem with “pci=nommconf” boot param.
Many thanks,
marher
