I have one host with 2 HCA Mellanox card and wanted to experiment if possible to run IB traffic similar to “loopback” test.
I have installed driver stack from DOCA everything looks OK, mst start, ibstat, mlxconfig working so far. Only that, because no cable is plugged, all ports are down now.
I asked grok on whether it is possible to run some 2-node traffic w/o cable plugged in and ports are still in down state, and it sayd something like
configure cards as eth mode (worked so far)
configure LID (using opensm) and this is where I am having issue:
Run perftest as usual (i.e. ib_write -d mlx5_<#> -i 1)
opensm -g (uuid from ibstat).
if i clear the log below and run cmd above, this is the log I am getting:
nonroot@nonroot-SYS-7049GP-TRT:~/extdir/gg/wget$ cat /var/log/opensm.log
Nov 12 10:52:56 886245 [29290740] 0x03 → OpenSM 5.24.0.MLNX20250722.185f9e32
Nov 12 10:52:56 886311 [29290740] 0x80 → OpenSM 5.24.0.MLNX20250722.185f9e32
Nov 12 10:52:56 892091 [29290740] 0x02 → osm_vendor_init: 1000 pending umads specified
Nov 12 10:52:56 892248 [29290740] 0x02 → osm_vendor_init: 1000 pending umads specified
Nov 12 10:52:56 892336 [29290740] 0x02 → osm_vendor_init: 1000 pending umads specified
Nov 12 10:52:56 897600 [29290740] 0x02 → osm_tenant_mgr_init: tenant mgr is disabled
Nov 12 10:52:56 897770 [29290740] 0x80 → Entering DISCOVERING state
Nov 12 10:52:56 897945 [29290740] 0x02 → osm_issu_mgr_init: issu_mgr is initialized
Nov 12 10:52:56 898142 [29290740] 0x02 → osm_vendor_rebind: Mgmt class 0x81 binding to port GUID 0xba599ffffe431320
Nov 12 10:52:56 904975 [29290740] 0x01 → osm_vendor_rebind: ERR 5426: Unable to register class 129 version 1
Nov 12 10:52:56 904992 [29290740] 0x01 → osm_sm_mad_ctrl_bind: ERR 3118: Vendor specific bind failed
Nov 12 10:52:56 904997 [29290740] 0x01 → osm_sm_bind: ERR 2E10: SM MAD Controller bind failed (IB_ERROR) for port guid 0xba599ffffe431320, port index 0
Nov 12 10:52:56 908933 [29290740] 0x02 → osm_tenant_mgr_destroy: osm_tenant_mgr_destroy complete
Nov 12 10:52:56 908960 [29290740] 0x02 → osm_issu_mgr_destroy: osm_issu_mgr_destroy complete
Nov 12 10:52:56 909064 [29290740] 0x80 → Exiting SM
Here is the grok instruction:
ibstat | egrep “mlx|UUID|State|GU”
CA ‘mlx5_0’
Node GUID: 0xb8599f0300431320
System image GUID: 0xb8599f0300431320
State: Down
Port GUID: 0xba599ffffe431320
CA ‘mlx5_1’
Node GUID: 0xb8599f0300431321
State: Down
Port GUID: 0xba599ffffe431321
CA ‘mlx5_2’
Node GUID: 0x0c42a103004a6b00
System image GUID: 0x0c42a103004a6b00
State: Down
Port GUID: 0x0e42a1fffe4a6b00
CA ‘mlx5_3’
Node GUID: 0x0c42a103004a6b01
State: Down
Port GUID: 0x0e42a1fffe4a6b01
