HowTo configure ConnectX-3 MT27500 direct connection w/o switch
Hello!
I have 2 servers equipped with identical card ConnectX-3 MT27500:
inxi -Nx
Resuming in non X mode: glxinfo not found. For package install advice run: inxi --recommends
Network: Card-1: Mellanox MT27500 Family [ConnectX-3] driver: mlx4_core v: 3.4-2.0.0 bus-ID: 0b:00.0
Card-2: Broadcom NetXtreme BCM5719 Gigabit Ethernet PCIe
driver: tg3 v: 3.137 bus-ID: 1b:00.0
Card-3: Broadcom NetXtreme BCM5719 Gigabit Ethernet PCIe
driver: tg3 v: 3.137 bus-ID: 1b:00.1
Card-4: Broadcom NetXtreme BCM5719 Gigabit Ethernet PCIe
driver: tg3 v: 3.137 bus-ID: 1b:00.2
Card-5: Broadcom NetXtreme BCM5719 Gigabit Ethernet PCIe
driver: tg3 v: 3.137 bus-ID: 1b:00.3
Card-6: Mellanox MT27500 Family [ConnectX-3] driver: mlx4_core v: 3.4-2.0.0 bus-ID: 86:00.0
The dual port card is configured in eth and ib mode:
connectx_port_config -s
Port configuration for PCI device: 0000:0b:00.0 is:
ib
ib
Port configuration for PCI device: 0000:86:00.0 is:
eth
eth
The servers are directly connected w/o IB switch.
iblinkinfo does not show the 40Gbps connection:
CA: ld4464 HCA-1:
0x248a070300dc2871 0 1 ==( 4X 10.0 Gbps Initialize/ LinkUp)==> 0 1 “ld4465 HCA-1” ( Could be 14.0625 Gbps)
CA: ld4465 HCA-1:
0x248a070300dc25c1 0 1 ==( 4X 10.0 Gbps Initialize/ LinkUp)==> 0 1 “ld4464 HCA-1” ( Could be 14.0625 Gbps)
Is it feasible to have a direct IB connection with 2 cards?
If yes, what is the required configuration?
How can I utilize 2nd IB port to enhance performance?
THX
Hi!
Q. Is it feasible to have a direct IB connection with 2 cards?
A. Yes.
Q. If yes, what is the required configuration?
A. One of the servers will need to be running OpenSM. The servers should have InifiniBand adapter drivers installed.The adapter ports must be using the IB protocol. Also, the cable must be an Infiniband cable, compatible with the required adapter port speeds. Then, link will come UP, and each port connected to the cable will get a LID address from the Subnet Manager (OpenSM). If you additionally configure IP interfaces on the adapter ports (in the same IP subnet), you’ll be able to PING between servers successfully.
Q. How can I utilize 2nd IB port to enhance performance?
You would need an InfiniBand switch (between each server) to utilize both ports on each adapter.
The OpenSM process will work on port 1 of the server its running on. It will detect (via port 1) all of the other server ports connected to the switch and will assign LID addresses to each port. Then, link will come UP, assuming you use proper InfiniBand cables. If IP addresses are added to each IB interface, you could PING between all IB server ports connected to this switch.
NOTE: Other than a management IP address/mask, InifiniBand switches require no configuration, and any additional configuration - such as changing hostname, changing port speeds, etc., will be optional.
Hi Colin,
thanks for your reply.
However, I didn’t manage to setup an appropriate configuration. Therefore I would like to start from scratch.
As said, there are 2 identical servers with identical NIC.
I have installed InfiniBand subnet manager (OpenSM) on both servers. This service is running in Master state on ld4465, and in Standby state on ld4464; but and I think this is the expected behavior.
ld4465:~ # systemctl status opensmd.service
● opensmd.service - LSB: Manage OpenSM
Loaded: loaded (/etc/init.d/opensmd; bad; vendor preset: disabled)
Active: active (running) since Thu 2017-07-27 17:57:46 CEST; 15h ago
Docs: man:systemd-sysv-generator(8)
Process: 8291 ExecStart=/etc/init.d/opensmd start (code=exited, status=0/SUCCESS)
Tasks: 122 (limit: 512)
CGroup: /system.slice/opensmd.service
└─8370 /usr/sbin/opensm --daemon --pidfile /var/run/opensm.pid
Jul 27 17:57:46 ld4465 opensmd[8291]: /etc/sysconfig/opensm: line 184: port_profile_switch_nodes:…ound
Jul 27 17:57:46 ld4465 opensmd[8291]: /etc/sysconfig/opensm: line 187: syntax error near unexpect…ull’
Jul 27 17:57:46 ld4465 opensmd[8291]: /etc/sysconfig/opensm: line 187: `port_prof_ignore_file (null)’
Jul 27 17:57:46 ld4465 OpenSM[8359]: Loading Cached Option:guid = 0x248a070300dc25c1
Jul 27 17:57:46 ld4465 opensmd[8291]: Starting opensm: done..done
Jul 27 17:57:46 ld4465 OpenSM[8370]: /var/log/opensm.log log file opened
Jul 27 17:57:46 ld4465 systemd[1]: Started LSB: Manage OpenSM.
Jul 27 17:57:46 ld4465 OpenSM[8370]: OpenSM 4.8.1.MLNX20170118.1a8ad26
Jul 27 17:57:46 ld4465 OpenSM[8370]: Entering DISCOVERING state
Jul 27 17:57:46 ld4465 OpenSM[8370]: Entering MASTER state
ld4464:~ # systemctl status -l opensm.service
Active: active (running) since Fri 2017-07-28 10:10:06 CEST; 3s ago
Process: 41211 ExecStop=/etc/init.d/opensmd stop (code=exited, status=0/SUCCESS)
Process: 41260 ExecStart=/etc/init.d/opensmd start (code=exited, status=0/SUCCESS)
└─41311 /usr/sbin/opensm --daemon --pidfile /var/run/opensm.pid
Jul 28 10:10:06 ld4464 opensmd[41260]: /etc/sysconfig/opensm: line 184: port_profile_switch_nodes: command not found
Jul 28 10:10:06 ld4464 opensmd[41260]: /etc/sysconfig/opensm: line 187: syntax error near unexpected token `null’
Jul 28 10:10:06 ld4464 opensmd[41260]: /etc/sysconfig/opensm: line 187: `port_prof_ignore_file (null)’
Jul 28 10:10:06 ld4464 OpenSM[41309]: Loading Cached Option:guid = 0x248a070300dc2871
Jul 28 10:10:06 ld4464 opensmd[41260]: Starting opensm: done..done
Jul 28 10:10:06 ld4464 OpenSM[41311]: /var/log/opensm.log log file opened
Jul 28 10:10:06 ld4464 OpenSM[41311]: OpenSM 4.8.1.MLNX20170118.1a8ad26
Jul 28 10:10:06 ld4464 systemd[1]: Started LSB: Manage OpenSM.
Jul 28 10:10:06 ld4464 OpenSM[41311]: Entering DISCOVERING state
Jul 28 10:10:06 ld4464 OpenSM[41311]: Entering STANDBY state
The relevant lines in /etc/sysconfing/opensm reported with error are:
ROUTING OPTIONS
If TRUE count switches as link subscriptions
port_profile_switch_nodes FALSE
Name of file with port guids to be ignored by port profiling
OK, next I share with you the info of current FW etc. ld4465 for simplicity (everything is identical on ld4464).
ld4465:~ # connectx_port_config -s
ib
eth
ib
eth
ld4465:~ # mstflint -d 0b:00.0 q
Image type: FS2
FW Version: 2.40.5000
FW Release Date: 27.10.2016
Product Version: 02.40.50.00
Rom Info: type=UEFI version=14.11.31
type=PXE version=3.4.746 devid=4099
Device ID: 4099
Description: Node Port1 Port2 Sys image
GUIDs: 248a070300dc25c0 248a070300dc25c1 248a070300dc25c2 248a070300dc25c3
MACs: 248a07dc25c1 248a07dc25c2
VSD:
PSID: IBM1090111019
ld4465:~ # mstflint -d 86:00.0 q
Image type: FS2
Device ID: 4099
GUIDs: 248a070300dc2810 248a070300dc2811 248a070300dc2812 248a070300dc2813
MACs: 248a07dc2811 248a07dc2812
VSD:
PSID: IBM1090111019
In this article https://software.intel.com/en-us/articles/understanding-the-infiniband-subnet-manager I found some info that a second instance of the subnet manager should be active for cards with two ports.
ld4465:~ # opensm -o
Reading Cached Option File: /etc/opensm/opensm.conf
Command Line Arguments:
Run Once
Log File: /var/log/opensm.log
Error from osm_opensm_bind (0x2A)
Perhaps another instance of OpenSM is already running
Exiting SM
So, I would like to understand first the correct configuration for OpenSM, and then continue with the config of IB.
THX
