I have a linking problem with nvcc on Linux. I have 2 source files, main.c and sum.c. In main.c I call sum_cuda(…) . sum_cuda is properly defined in sum.h and sum.c with host decoration. Both source compile file with “nvcc -c”. On the lining phase nvcc -o main.o -o sum.o -lcudart gives an “unresolved external” in main.c for <sum_cuda>. When I do a “nm main.o” “nm sum.o” I can clearly see that the symbol for “sum_cuda” generated is not the same. In main.o, it is unresolved with " U sum_cuda" and in sum.o it is defined as “T _Z8sum_cudaPfS_S_i”. It is as if the host wasn’t recognized and/or ignored when compiling main.c. This is with cuda dev kit 11.2 ----- You have everything below to reproduce the problem.
sum.h ----->
__host__ void sum_cuda
float * ab, // OUT: a * b
float * a, // IN: a array
float * b, // IN: b array
int n // IN: n size of a, b, a*b
<------ sum.h ends
main.c ---->
#include <stdio.h>
#include <cuda_runtime.h>
#include “sum.h”
int main( int argc, char * argv[\ ] )
float a[10];
float b[10];
float res[10];
sum_cuda( res, a, b, 10 );
<------ sum.h ends
sum.cu ----------->
#include “sum.h”
__global__ void Sum_Kernel( float *ab, float *a, float *b, unsigned int n )
int i = threadIdx.x + blockIdx.x * blockDim.x;
if( i < n )
ab[i] = a[i]+b[i];
float *ab, // OUT: a * b
float *a, // IN: a array
float b, // IN: b array
int n // IN: n size of a, b, ab
const int threadsPerBlock = 256;
const int blocksPerGrid = 10;
Sum_Kernel<<< blocksPerGrid, threadsPerBlock >>>( ab, a, b, n );
<--------- sum.cu ends
------> Instructions to compile
nvcc -c main.c -I…/XAI_dl -I/usr/local/cuda/include
nvcc -c sum.cu -I…/XAI_dl -I/usr/local/cuda/include
nvcc main.o sum.o -lcudart -lc -L/usr/local/cuda/lib64
<--------- Instructions to compile ends.
Compiler version---->
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2020 NVIDIA Corporation
Built on Mon_Nov_30_19:08:53_PST_2020
Cuda compilation tools, release 11.2, V11.2.67
Build cuda_11.2.r11.2/compiler.29373293_0
<----Compiler version ends.
