I am using “host device” identifiers to compile some code for both the kernel and the host machine. However when I use these functions from the host code I get linker errors, “unresolved symbol”.
See below for the code and my rationale for this setup. I am wondering if this is a bug in the NVCC compiler or some error on my side?
functions.h
#pragma once
extern "C" {
void hello_cuda();
#ifndef __CUDACC__
#define __host__
#define __device__
#endif
class A {
public:
__host__ __device__ int add_cuda(int b);
__host__ __device__ void operator=(float);
bool isequal(int b);
bool add(int c);
private:
int c;
main_cpp.cpp
#include "functions.h"
int main() {
A a;
a.add_cuda(5);
a.isequal(45);
a.add(123);
a = 13.0;
hello_cuda();
return 0;
main_kernel.cu
#include <stdio.h>
#include "main.h"
#include "functions.cpp"
#pragma comment(lib, "cudart.lib")
__global__ void bob() {
A a;
a.add_cuda(14);
a = 13.0;
void hello_cuda() {
printf("Hello world!\n");
bob<<<1, 1>>>();
functions.cpp
#include "main.h"
int A::add_cuda(int b) {return b + 3;}
bool A::add(int b) {return b + 3;}
bool A::isequal(int b) {return b == c;}
void A::operator=(float c) {
for (int i = 0; i < 10; i++)
c += i;
main.cpp is my host file, main_kernel.cu is the kernel. I have some functions in functions.cpp. Functions from here are used both in host and kernel mode (namely add_cuda and operator). I need to include “functions.cpp” in the kernel file because CUDA does not work with externals for device code. Functions.cpp is not compiled, because then I will get multiply defined symbols.
When I link this I get unresolved symbols for add_cuda() and the operator=, the host/device functions. No matter what I do, I cannot get rid of this error. The only “solution” that I have found is to add a dummy function to the kernel file that uses the host/device functions. Then they are exported. Like this:
void dummy() {
A a;
a.add_cuda(123);
a = 13.0;
Is there something that I am doing wrongly or is NVCC simply not exporting host device functions outside the object file that are not called themselves in the same file? Is this a bug?
