Hi Guodong,
Looking at the sysinfo-snapshot provided, none of our modules are loaded.
IE:
lsmod | egrep -i “ib|mlx*”
ib_ucm 22642 0
ib_ipoib 159750 0
ib_cm 52470 3 ib_ucm,rdma_cm,ib_ipoib
ib_uverbs 71505 2 rdma_ucm,ib_ucm
ib_umad 22283 6
mlx4_en 134317 0
mlx4_ib 193439 0
mlx4_core 353345 2 mlx4_en,mlx4_ib
mlx5_ib 188935 0
ib_core 250100 10 rdma_ucm,ib_ucm,rdma_cm,iw_cm,ib_ipoib,ib_cm,ib_uverbs,ib_umad,mlx4_ib,mlx5_ib
ipv6 361510 69 bridge,ip6t_REJECT,rdma_cm,ib_ipoib,ib_core
mlx5_core 547647 1 mlx5_ib
mlx_compat 17075 14 rdma_ucm,ib_ucm,rdma_cm,iw_cm,ib_ipoib,ib_cm,ib_uverbs,ib_umad,mlx4_en,mlx4_ib,mlx4_core,mlx5_ib,ib_core,mlx5_core
ptp 18580 3 mlx4_en,mlx5_core,igb
libahci 32073 1 ahci
libsas 84132 1 isci
scsi_transport_sas 40863 2 isci,libsas
The syslog file reports odd messages on the drivers version upon loading then fail to load:
May 13 11:30:56 dynamicc4 openibd[908]: Loading Mellanox MLX4 HCA driver:#033[60G[#033[1;31mFAILED#033[0;39m]
May 13 11:30:56 dynamicc4 openibd[908]: Loading Mellanox MLX4_IB HCA driver:#033[60G[#033[1;31mFAILED#033[0;39m]
May 13 11:30:56 dynamicc4 openibd[908]: Loading Mellanox MLX4_EN HCA driver:#033[60G[#033[1;31mFAILED#033[0;39m]
May 13 11:30:56 dynamicc4 openibd[908]: Loading Mellanox MLX5 HCA driver:#033[60G[#033[1;31mFAILED#033[0;39m]
May 13 11:30:56 dynamicc4 openibd[908]: Loading Mellanox MLX5_IB HCA driver:#033[60G[#033[1;31mFAILED#033[0;39m]
Can you validate the modules versions:
IE:
modinfo mlx4_core | grep -i version
version: 4.0-2.0.0
srcversion: 8D664781D9FEAD80E98F82E
vermagic: 3.10.105-1.el6.elrepo.x86_64 SMP mod_unload modversions
Also, can you compare the srcversion between the modinfo and the actual modules, they should be the same:
IE:
cat /sys/module/mlx4_core/srcversion
I would also suggest to verify the content of your initramfs image (lsinitrd), check modules and versions of our MLX drivers.
Make sure all Inbox drivers have been removed.
Sophie.
