You put the wrong place… The pin is on J50 in below picture… not J41…
Dump the uart log and it will tell what is going on.
Check if your TX/RX/GND pin are correctly connected.
Also try other console tool other than minicom. For example, picocom.
0003
How about you flash your nano with normal jetpack/sdkmanager again and let it boot into system?
If nano is able to boot into system, then uart 100% will have log printed. If it does not, it means the connection or minicom setting is wrong…
i use the commend :dmesg --follow
What is your command to use minicom? Have you tried picocom?
not ,i haven’t use picocom,do you have the Tutorial for picocom>…
实在是抱歉,你们上海这边有维护站点么??实在不行我把board寄给你们,帮忙修复一下。
There is no such service here. Your problem is more like t he cp210x driver is not compatible with your host.
Try to use other kind of usb-ttl cable.
