How Can I Create a Custom Image to Flash a Jetson Nano?
I want to create a custom “image” for the Jetson Nano that contains all the software I need for my project, as well as removing software I don’t need to preserve space on the SD card. For example, let’s say I want to use the latest version of OpenCV (4.7 as of this writing) and CUDA.
What I’d like to do is prepare an image that contains only the packages I require from apt, the CUDA toolkit, a pre-compiled version of OpenCV for ARM, along with any other software I need. From what I’ve read on the Dev Forums, it seems like I can accomplish this with a custom rootfs. But I’m not sure how exactly how to customize it. Is there a guide I missed? Further, it’s not clear to me how to pre-install a package from apt that I can flash the Nano with.
In conclusion, how can I create a custom flashable image I can safely use on multiple Jetsons without dd?
A possible solution is to develop the rootfs on one Jetson Nano, and then clone the image out. So that you can flash to the other Nanos with the image. Please take a look at
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3261/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/flashing.html#wwpID0E0MQ0HA
Hi @DaneLLL,
Thanks for the reply! I’ll give that a try.
Hi again @DaneLLL,
I tried cloning using this command:
sudo ./flash.sh -r -k APP -G myclone jetson-nano-qspi-sd mmcblk0p1
But it simply hangs at:
[   1.4786 ] tegrarcm --oem platformdetails storage storage_info.bin
[   1.4799 ] Applet version 00.01.0000
[   1.5412 ] 00000003: Could not initialize storage device
[   1.7024 ]
[   1.7054 ] tegradevflash --oem platformdetails storage storage_info.bin
Then I tried to flash using eMMC:
sudo ./flash.sh -r -k APP -G myclone jetson-nano-devkit-emmc mmcblk0p1
But it still just hangs at the same spot. Any thoughts on how to fix this?
For Jetson Nano developer kit with sd card slot, please use this config jetson-nano-devkit.conf
And please let Jetson Nano enter recovery mode before running the command.
Hi @DaneLLL,
Thanks for the quick reply! What command would I run in order to use this configuration file?
Thanks,
Noah
Please let Jetson Nano enter recovery mode and run:
$ sudo ./flash.sh -r -k APP -G myclone jetson-nano-devkit mmcblk0p1
To clone the image out.
Hi @DaneLLL,
I tried that and unfortunately it’s still hanging at
[   1.4737 ] 00000003: Could not initialize storage device
[   1.9679 ]
[   1.9734 ] tegradevflash --oem platformdetails storage storage_info.bin
Screenshot:
The Nano has the Power Select Header jumpered along with the FRC REC pin jumpered to GND.
We have checked and confirmed the above method does not work for Jetson Nano with SD card slot. Please try this method:
How to clone Jetson Nano SD Card? - #19 by mdegans
You can mount the SD card to Ubuntu host and run the command like:
$ sudo ROOTFS_DIR=_PATH_TO_ROOTFS ./jetson-disk-image-creator.sh -o sd-blob.img -b jetson-nano -r 300
Please set ROOTFS_DIR to the mounted SD card.
I’ll add that there are lots of ways to take an SD card you have the way you want it (e.g., updated, set up environment the way you want, added packages, so on) and use dd to save this as a clone. This could then easily be added on other SD cards (it would have the same accounts/passwords, updates, customizations, so on).
Hi @DaneLLL,
Thanks for providing this method. I mounted the microSD card and used this command to create an image from the Nano. I then copied the image into bootloader/system.img
Next, I executed this command:
sudo ./flash.sh -r -k APP jetson-nano-qspi-sd mmcblk0p1
It flashed the APP partition successfully, but the Nano gets stuck at the NVIDIA boot logo when plugged in to a monitor.
Then I tried this:
sudo ./flash.sh -r jetson-nano-qspi-sd  mmcblk0p1
But it still won’t boot past the NVIDIA logo.
I also had a USB to serial connector handy; here is the full log from the console (with no display attached):
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0xc0937
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.178] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.198] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.204] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.210] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.233] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.269] BoardID = 3448, SKU = 0x0
[0000.272] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.276] Nano-SD: checking PT table on QSPI ...
[0000.280] Initialize FailControl
[0000.283] Read PT from (2:0)
[0000.314] PT crc32 and magic check passed.
[0000.318] Using BFS PT to query partitions
[0000.324] Loading Tboot-CPU binary
[0000.352] Verifying TBC in OdmNonSecureSBK mode
[0000.362] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.369] Bootloader downloaded successfully.
[0000.373] Downloaded Tboot-CPU binary to 0xa0000258
[0000.378] MAX77620_GPIO5 configured
[0000.381] CPU power rail is up
[0000.384] CPU clock enabled
[0000.388] Performing RAM repair
[0000.391] Updating A64 Warmreset Address to 0xa00002e9
[0000.396] BoardID = 3448, SKU = 0x0
[0000.399] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.403] Nano-SD: checking PT table on QSPI ...
[0000.407] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.413] Loading NvTbootBootloaderDTB
[0000.480] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.546] Bootloader DTB Load Address: 0x83000000
[0000.551] BoardID = 3448, SKU = 0x0
[0000.554] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.558] Nano-SD: checking PT table on QSPI ...
[0000.562] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.569] Loading NvTbootKernelDTB
[0000.635] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.701] Kernel DTB Load Address: 0x83100000
[0000.705] BoardID = 3448, SKU = 0x0
[0000.709] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.712] Nano-SD: checking PT table on QSPI ...
[0000.717] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.724] Loading cboot binary
[0000.840] Verifying EBT in OdmNonSecureSBK mode
[0000.882] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.889] Bootloader downloaded successfully.
[0000.893] BoardID = 3448, SKU = 0x0
[0000.896] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.900] Nano-SD: checking PT table on QSPI ...
[0000.905] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.911] PT: Partition NCT NOT found !
[0000.915] Warning: Find Partition via PT Failed
[0000.919] Next binary entry address: 0x92c00258
[0000.923] BoardId: 3448
[0000.928] Overriding pmu board id with proc board id
[0000.933] Display board id is not available
[0000.937] BoardID = 3448, SKU = 0x0
[0000.940] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.944] Nano-SD: checking PT table on QSPI ...
[0000.948] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.055] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.109] /bpmp deleted
[0001.111] SC7EntryFw header found loaded at 0xff700000
[0001.299] OVR2 PMIC
[0001.301] Bpmp FW successfully loaded
[0001.304] BoardID = 3448, SKU = 0x0
[0001.308] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.311] Nano-SD: checking PT table on QSPI ...
[0001.316] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.323] WB0 init successfully at 0xff780000
[0001.327] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.332] Set NvDecSticky Bits
[0001.336] GSC2 address ff53fffc value c0edbbcc
[0001.342] GSC MC Settings done
[0001.345] BoardID = 3448, SKU = 0x0
[0001.348] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.352] Nano-SD: checking PT table on QSPI ...
[0001.356] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.363] TOS Image length 53680
[0001.366]  Monitor size 53680
[0001.369]  OS size 0
[0001.384] Secure Os AES-CMAC Verification Success!
[0001.389] TOS image cipher info: plaintext
[0001.393] Loading and Validation of Secure OS Successful
[0001.409] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.413] NvTbootPackSdramParams: start.
[0001.418] NvTbootPackSdramParams: done.
[0001.422] Tegraboot started after 51868 us
[0001.426] Basic modules init took 926091 us
[0001.430] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.436] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.441] Next stage binary read took 102859 us
[0001.445] Carveout took -132463 us
[0001.449] CPU initialization took 508285 us
[0001.453] Total time taken by TegraBoot 1404772 us
[0001.457] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.3(release):b5eeb33f7
NOTICE:  BL31: Built : 12:09:37, Jul 26 2021
ERROR:   Error initializing runtime service trusty_fast
[0001.580] RamCode = 0
[0001.584] LPDDR4 Training: Read DT: Number of tables = 2
[0001.589] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.602] EMC Training Successful
[0001.605] 408000 not found in DVFS table
[0001.611] RamCode = 0
[0001.615] DT Write: emc-table@204000 succeeded
[0001.620] DT Write: emc-table@1600000 succeeded
[0001.625] LPDDR4 Training: Write DT: Number of tables = 2
[0001.672]
[0001.673] Debug Init done
[0001.676] Marked DTB cacheable
[0001.679] Bootloader DTB loaded at 0x83000000
[0001.684] Marked DTB cacheable
[0001.687] Kernel DTB loaded at 0x83100000
[0001.691] DeviceTree Init done
[0001.703] Pinmux applied successfully
[0001.708] gicd_base: 0x50041000
[0001.711] gicc_base: 0x50042000
[0001.714] Interrupts Init done
[0001.718] Using base:0x60005090 & irq:208 for tick-timer
[0001.724] Using base:0x60005098 for delay-timer
[0001.728] platform_init_timer: DONE
[0001.732] Timer(tick) Init done
[0001.735] osc freq = 38400 khz
[0001.739]
[0001.740] Welcome to L4T Cboot
[0001.743]
[0001.744] Cboot Version: 00.00.2018.01-t210-c952b4e6
[0001.749] calling constructors
[0001.752] initializing heap
[0001.755] initializing threads
[0001.758] initializing timers
[0001.761] creating bootstrap completion thread
[0001.765] top of bootstrap2()
[0001.768] CPU: ARM Cortex A57
[0001.771] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.776] initializing platform
[0001.783] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.787] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.792] Macronix QSPI chip present
[0001.795] SPI device register
[0001.798] init boot device
[0001.801] allocating memory for boot device(SPI)
[0001.805] registering boot device
[0001.814] QSPI bdev is already initialized
[0001.818] Enable APE clock
[0001.820] Un-powergate APE partition
[0001.824] of_register: registering tegra_udc to of_hal
[0001.829] of_register: registering inv20628-driver to of_hal
[0001.835] of_register: registering ads1015-driver to of_hal
[0001.840] of_register: registering lp8557-bl-driver to of_hal
[0001.846] of_register: registering bq2419x_charger to of_hal
[0001.852] of_register: registering bq27441_fuel_gauge to of_hal
[0001.863] gpio framework initialized
[0001.866] of_register: registering tca9539_gpio to of_hal
[0001.872] of_register: registering tca9539_gpio to of_hal
[0001.877] of_register: registering i2c_bus_driver to of_hal
[0001.883] of_register: registering i2c_bus_driver to of_hal
[0001.888] of_register: registering i2c_bus_driver to of_hal
[0001.894] pmic framework initialized
[0001.897] of_register: registering max77620_pmic to of_hal
[0001.903] regulator framework initialized
[0001.907] of_register: registering tps65132_bl_driver to of_hal
[0001.912] initializing target
[0001.918] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.926] board ID = D78, board SKU = 0
[0001.930] Skipping Z3!
[0001.935] fixed regulator driver initialized
[0001.952] initializing OF layer
[0001.955] NCK carveout not present
[0001.958] Skipping dts_overrides
[0001.962] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.978] I2C Bus Init done
[0001.981] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.991] I2C Bus Init done
[0001.993] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.004] I2C Bus Init done
[0002.006] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.016] I2C Bus Init done
[0002.019] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.029] I2C Bus Init done
[0002.032] of_children_init: Ops found for compatible string maxim,max77620
[0002.042] max77620_init using irq 118
[0002.047] register 'maxim,max77620' pmic
[0002.051] gpio_driver_register: register 'max77620-gpio' driver
[0002.058] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.068] I2C Bus Init done
[0002.071] NCK carveout not present
[0002.081] Find /i2c@7000c000's alias i2c0
[0002.084] get eeprom at 1-a0, size 256, type 0
[0002.093] Find /i2c@7000c500's alias i2c2
[0002.097] get eeprom at 3-a0, size 256, type 0
[0002.101] get eeprom at 3-ae, size 256, type 0
[0002.106] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.111] I2C slave not started
[0002.114] I2C write failed
[0002.117] Writing offset failed
[0002.120] eeprom_init: EEPROM read failed
[0002.124] pm_ids_update: eeprom init failed
[0002.128] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.158] pm_ids_update: The pm board id is 3448-0000-402
[0002.165] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0002.173] pm_ids_update: pm id update successful
[0002.177] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.207] pm_ids_update: The pm board id is 3449-0000-400
[0002.214] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.222] pm_ids_update: pm id update successful
[0002.252] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.258] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.266] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.271] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.280] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:5b:94:c5
[0002.286] Plugin Manager: Parse ODM data 0x000a4000
[0002.298] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0002.312] Find /i2c@7000c000's alias i2c0
[0002.316] get eeprom at 1-a0, size 256, type 0
[0002.324] Find /i2c@7000c500's alias i2c2
[0002.328] get eeprom at 3-a0, size 256, type 0
[0002.333] get eeprom at 3-ae, size 256, type 0
[0002.337] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.342] I2C slave not started
[0002.345] I2C write failed
[0002.348] Writing offset failed
[0002.351] eeprom_init: EEPROM read failed
[0002.355] pm_ids_update: eeprom init failed
[0002.359] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.389] pm_ids_update: The pm board id is 3448-0000-402
[0002.395] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0002.402] pm_ids_update: pm id update successful
[0002.407] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.437] pm_ids_update: The pm board id is 3449-0000-400
[0002.443] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0002.450] pm_ids_update: pm id update successful
[0002.481] Add serial number:1424621025753 as DT property
[0002.488] Applying platform configs
[0002.494] platform-init is not present. Skipping
[0002.499] calling apps_init()
[0002.504] Couldn't find GPT header
[0002.509] Proceeding to Cold Boot
[0002.512] starting app android_boot_app
[0002.516] Device state: unlocked
[0002.519] display console init
[0002.527] could not find regulator
[0002.551] hdmi cable not connected
[0002.554] is_hdmi_needed: HDMI not connected, returning false
[0002.559] hdmDT entry for leds-pwm not found
i[0002.566]  is not connected
[0002.569] sor0 is not supported
[0002.572] display_console_init: no valid display out_type
[0002.580] subnode volume_up is not found !
[0002.584] subnode back is not found !
[0002.588] subnode volume_down is not found !
[0002.592] subnode menu is not found !
[0002.595] Gpio keyboard init success
[0002.676] found decompressor handler: lz4-legacy
[0002.690] decompressing blob (type 1)...
[0002.756] display_resolution: No display init
[0002.761] Failed to retrieve display resolution
[0002.765] Could not load/initialize BMP blob...ignoring
[0002.841] decompressor handler not found
[0002.845] load_firmware_blob: Firmware blob loaded, entries=2
[0002.851] XUSB blob version 0 size 126464 @ 0x92ca828c
[0002.857] -------> se_aes_verify_sbk_clear: 747
[0002.861] se_aes_verify_sbk_clear: Error
[0002.865] SE operation failed
[0002.868] bl_battery_charging: connected to external power supply
[0002.877] display_console_ioctl: No display init
[0002.881] switch_backlight failed
[0002.888] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.895] MSC Partition not found
[0002.901] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.908] USP partition read failed!
[0002.912] blob_init: blob-partition USP header read failed
[0002.917] android_boot Unable to update recovery partition
[0002.923] kfs_getpartname: name = LNX
[0002.926] Loading kernel from LNX
[0002.936] Found 19 BFS partitions in "spiflash0"
[0003.256] load kernel from storage
[0003.261] decompressor handler not found
[0003.527] Successfully loaded kernel and ramdisk images
[0003.532] board ID = D78, board SKU = 0
[0003.537] sdmmc node status = okay
[0003.540] sdcard instance = 0
[0003.543] sdmmc cd-inverted
[0003.545] sdcard gpio handle 0x5b
[0003.549] sdcard gpio pin 0xc9
[0003.552] sdcard gpio flags 0x0
[0003.555] vmmc-supply 0x9b
[0003.557] cd_gpio_pin = 201
[0003.560] pin_state = 0
[0003.562] Found sdcard
[0003.565] SD-card IS present ...
[0003.568] load_and_boot_kernel: SD card detected OK
[0003.573] display_resolution: No display init
[0003.578] Failed to retrieve display resolution
[0003.582] bmp blob is not loaded and initialized
[0003.587] Failed to display boot-logo
[0003.590] NCK carveout not present
[0003.594] Skipping dts_overrides
[0003.597] NCK carveout not present
[0003.606] Find /i2c@7000c000's alias i2c0
[0003.610] get eeprom at 1-a0, size 256, type 0
[0003.619] Find /i2c@7000c500's alias i2c2
[0003.623] get eeprom at 3-a0, size 256, type 0
[0003.627] get eeprom at 3-ae, size 256, type 0
[0003.631] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.637] I2C slave not started
[0003.640] I2C write failed
[0003.642] Writing offset failed
[0003.645] eeprom_init: EEPROM read failed
[0003.649] pm_ids_update: eeprom init failed
[0003.653] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.684] pm_ids_update: The pm board id is 3448-0000-402
[0003.690] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0003.699] pm_ids_update: pm id update successful
[0003.703] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.733] pm_ids_update: The pm board id is 3449-0000-400
[0003.739] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0003.747] pm_ids_update: pm id update successful
[0003.777] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.783] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.791] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.797] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.805] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:5b:94:c5
[0003.812] Plugin Manager: Parse ODM data 0x000a4000
[0003.823] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0003.832] Add serial number:1424621025753 as DT property
[0003.840] "bpmp" doesn't exist, creating
[0003.845] Updated bpmp info to DTB
[0003.850] Updated initrd info to DTB
[0003.854] "proc-board" doesn't exist, creating
[0003.860] Updated board info to DTB
[0003.863] "pmu-board" doesn't exist, creating
[0003.869] Updated board info to DTB
[0003.872] "display-board" doesn't exist, creating
[0003.878] Updated board info to DTB
[0003.881] "reset" doesn't exist, creating
[0003.886] Updated reset info to DTB
[0003.889] display_console_ioctl: No display init
[0003.894] display_console_ioctl: No display init
[0003.898] display_console_ioctl: No display init
[0003.903] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt
[0003.938] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.943] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0003.956] Updated bootarg info to DTB
[0003.960] Adding uuid 00000001643073070c00000012060280 to DT
[0003.966] Adding eks info 0 to DT
[0003.971] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.977] Updated memory info to DTB
[0003.985] set vdd_core voltage to 1125 mv
[0003.989] setting 'vdd-core' regulator to 1125000 micro volts
[0003.995] Found secure-pmc; disable BPMP
U-Boot 2020.04-g46e4604c78 (Jul 26 2021 - 12:09:42 -0700)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM:  4 GiB
MMC:   sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash... SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  0
tegra_mmc_send_cmd_bounced: MMC Timeout
    Interrupt status        0x00000001
    Interrupt status enable 0xffff003b
    Interrupt signal enable 0xffff0002
    Present status          0x01fb0206
Card did not respond to voltage select!
starting USB...
Bus usb@7d000000: tegrausb: Invalid dr_mode 2 for host mode
probe failed, error -1
Bus xusb@70090000:
Firmware size 126464
Firmware timestamp: 0x5f23e558, Version: 50.26 release
Register HCSParams1: 9000124 NbrPorts: 9
Starting the controller
USB XHCI 1.00
scanning bus xusb@70090000 for devices... 3 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
Warning: eth_rtl8169 using MAC address from ROM
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
Abort
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-48-b0-2d-5b-94-c5
*** ERROR: `serverip' not set
Retrieving file: pxelinux.cfg/00000000
Retrieving file: pxelinux.cfg/default-arm-tegra210-p3450-0000
Config file not found
Tegra210 (P3450-0000) # boot
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded; starting again
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Tegra210 (P3450-0000) # [0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
Unknown command '[0000.125]' - try 'help'
Tegra210 (P3450-0000) # [0000.130] Processing in cold boot mo] A02 Bootrom Patch rev = 1023
Unknown command '[0000.130]' - try 'help'
Tegra210 (P3450-0000) # [0000.138] Power-up reason: pmc por
Unknown command '[0000.138]' - try 'help'
Tegra210 (P3450-0000) # [0000.147] pmic max77620 NVERC : 0x40156] max77620 disabling SD1 Remote Sense
Unknown command '[0000.147]' - try 'help'
Tegra210 (P3450-0000) # [0000.161] Setting DDR voltage to 112tering ramdump check
Unknown command '[0000.161]' - try 'help'
Tegra210 (P3450-0000) # [0000.175] Get RamDumpCarveOut = 0x0
Unknown command '[0000.175]' - try 'help'
Tegra210 (P3450-0000) #  Last reboot was clean, booting normaOs Carveout Base=0x00000000ff800000 Size=0x00800000
Unknown command 'Last' - try 'help'
Tegra210 (P3450-0000) # [0000.198] Lp0 Carveout Base=0x0000000000000ff700000 Size=0x00080000
Unknown command '[0000.198]' - try 'help'
Tegra210 (P3450-0000) # [0000.210] GSC1 Carveout Base=0x00000ff500000 Size=0x00100000
Unknown command '[0000.210]' - try 'help'
Tegra210 (P3450-0000) # [0000.222] GSC4 Carveout Base=0x00000ff300000 Size=0x00100000
Unknown command '[0000.222]' - try 'help'
Tegra210 (P3450-0000) # [0000.233] GSC3 Carveout Base=0x00000000ff280000 Size=0x00080000
Unknown command '[0000.233]' - try 'help'
Tegra210 (P3450-0000) # [0000.256] Platform-DebugCarveout: 0
Unknown command '[0000.256]' - try 'help'
Tegra210 (P3450-0000) # 0.265] Non secure mode, and RB not enipQspiOnlyFlag = 0
Unknown command '0.265]' - try 'help'
Tegra210 (P3450-0000) # [0000.276] Nano-SD: checking PT tableT from (2:0)
Unknown command '[0000.276]' - try 'help'
Tegra210 (P3450-0000) # [0000.314] PT crc32 and magic check pg Tboot-CPU binary
Unknown command '[0000.314]' - try 'help'
Tegra210 (P3450-0000) # [0000.352] Verifying TBC in OdmNonSecaddress is 0xa0000258
Unknown command '[0000.352]' - try 'help'
Tegra210 (P3450-0000) # [0000.369] Bootloader downloaded succ.378] MAX77620_GPIO5 configured
Unknown command '[0000.369]' - try 'help'
Tegra210 (P3450-0000) # [0000.381] CPU power rail is up
Unknown command '[0000.381]' - try 'help'
Tegra210 (P3450-0000) # [0000Updating A64 Warmreset Address tLY: SkipQspiOnlyFlag = 0
Unknown command '[0000Updating' - try 'help'
Tegra210 (P3450-0000) # [0000.403] Nano-SD: checking PT tableinuing ...
Unknown command '[0000.403]' - try 'help'
Tegra210 (P3450-0000) # [0000.413] Loading NvTbootBootloaderD
Unknown command '[0000.413]' - try 'help'
Tegra210 (P3450-0000) # [0000.546] Bootloader DTB Load AddresNLY: SkipQspiOnlyFlag = 0
Unknown command '[0000.546]' - try 'help'
Tegra210 (P3450-0000) # [0000.558] Nano-SD: checking PT tableontinuing ...
Unknown command '[0000.558]' - try 'help'
Tegra210 (P3450-0000) # [0000.569] Loading NvTbootKernelDTB
Unknown command '[0000.569]' - try 'help'
Tegra210 (P3450-0000) # [01] Kernel DTB Load Address: 0x83100spiOnlyFlag = 0
Unknown command '[01]' - try 'help'
Tegra210 (P3450-0000) # [0000.712] Nano-SD: checking PT tablever; Continuing ...
Unknown command '[0000.712]' - try 'help'
Unknown command 'Continuing' - try 'help'
Tegra210 (P3450-0000) # [0000.724] Loading cboot binary
Unknown command '[0000.724]' - try 'help'
Tegra210 (P3450-0000) # [00000x92c00258
Unknown command '[00000x92c00258' - try 'help'
Tegra210 (P3450-0000) # [0000.889] Bootloader.896] QSPI-ONLY:0000.905] NvTbootFailControlDoFailover: No failover; Continuing ...
Unknown command '[0000.889]' - try 'help'
Tegra210 (P3450-0000) # [0000.911] PT: Partition NCT NOT founardId: 3448
Unknown command '[0000.911]' - try 'help'
Tegra210 (P3450-0000) # [0000.928] Overriding pmu board id wi937] BoardID = 3448, SKU = 0x0
Unknown command '[0000.928]' - try 'help'
Tegra210 (P3450-0000) # [0000.940] QSPI-ONLY: SkipQspiOnlyFlavTbootFailControlDoFailover: No failover; Continuing ...
Unknown command '[0000.940]' - try 'help'
Tegra210 (P3450-0000) # [0001.055] Verifying SC7EntryFw in OdVR2 PMIC
Unknown command '[0001.055]' - try 'help'
Tegra210 (P3450-0000) # [0001.301] Bpmp FW successfully loadeiOnlyFlag = 0
Unknown command '[0001.301]' - try 'help'
Tegra210 (P3450-0000) # [0001.311] Nano-SD: checking PT tableontinuing ...
Unknown command '[0001.311]' - try 'help'
Tegra210 (P3450-0000) # [0001.323] WB0 init successfully at 0001.332] Set NvDecSticky Bits
Unknown command '[0001.323]' - try 'help'
Tegra210 (P3450-0000) # [0001.336] GSC2 address ff53fffc valu, SKU = 0x0
Unknown command '[0001.336]' - try 'help'
Tegra210 (P3450-0000) # [0001.348] QSPI-ONLY: SkipQspiOnlyFlavTbootFailControlDoFailover: No failover; Continuing ...
Unknown command '[0001.348]' - try 'help'
Tegra210 (P3450-0000) # [0001.363] TOS Image length 53680
Unknown command '[0001.363]' - try 'help'
Tegra210 (P3450-0000) # [00TOS image cipher info: plaintext
Unknown command '[00TOS' - try 'help'
Tegra210 (P3450-0000) # [SC7 Entry Firmware - 0xff700000, 0x4PackSdramParams: done.
Unknown command '[SC7' - try 'help'
Tegra210 (P3450-0000) # [0001.422] Tegraboot started after 51 Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
Unknown command '[0001.422]' - try 'help'
Tegra210 (P3450-0000) # [0001.436] Sec Bootdevice Write Time us
Unknown command '[0001.436]' - try 'help'
Tegra210 (P3450-0000) # [0001.445] Carveout took -132463 us
Unknown command '[0001.445]' - try 'help'
Tegra210 (P3450-0000) # [ken by TegraBoot 1404772 us
Unknown command '[ken' - try 'help'
Tegra210 (P3450-0000) # [0001.4se):b5eeb33f7
Unknown command '[0001.4se):b5eeb33f7' - try 'help'
Tegra210 (P3450-0000) # NOTICE:  BL31: i4 Training: Read DT: 000)
Unknown command 'NOTICE:' - try 'help'
Tegra210 (P3450-0000) # [0001.602] EMC Training Successful
Unknown command '[0001.602]' - try 'help'
Tegra210 (P3450-0000) # [0001.615] DT Write: emc-table@2040005] LPDDR4 Training: Write DT: Number of tables = 2
Unknown command '[0001.615]' - try 'help'
Tegra210 (P3450-0000) # [0001.672]
Unknown command '[0001.672]' - try 'help'
Tegra210 (P3450-0000) # [0001.673] Debug Init donex83000000
Unknown command '[0001.673]' - try 'help'
Unknown command '[00000' - try 'help'
Tegra210 (P3450-0000) # [0001.691] DeviceTree Init don41000
Unknown command '[0001.691]' - try 'help'
Tegra210 (P3450-0000) # [[0001.718] Using base:0x60005090 & ier
syntax error
Tegra210 (P3450-0000) # [0001.728] platform_init_timer: DONE
Unknown command '[0001.728]' - try 'help'
Tegra210 (P3450-0000) # 735] osc freq = 38400 khz
Unknown command '735]' - try 'help'
Tegra210 (P3450-0000) # [0001.739]
Unknown command '[0001.739]' - try 'help'
Tegra210 (P3450-0000) #  00.00.2018.01-t210-c952b4p
Unknown command '00.00.2018.01-t210-c952b4p' - try 'help'
Tegra210 (P3450-0000) # [0001.755ating bootstrap completion tMIDR: 0x411FD071, MPIDR: 0x80000000
Unknown command '[0001.755ating' - try 'help'
Tegra210 (P3450-0000) # [0001.776] initializing platform
Unknown command '[0001.776]' - try 'help'
Tegra210 (P3450-0000) # [000ID-CFI len = 194 bytes
Unknown command '[000ID-CFI' - try 'help'
Tegra210 (P3450-0000) # [0001.792]] init boot device
Unknown command '[0001.792]]' - try 'help'
Tegra210 (P3450-0000) # [0001.80t device
Unknown command '[0001.80t' - try 'help'
Tegra210 (P3450-0000) # [0001.814] QSPI bdevergate APE partit29] of_register: registering inv20628-driver to of_hal
Unknown command '[0001.814]' - try 'help'
Tegra210 (P3450-0000) # [0001.835] of_register: registering adriver to of_hal
Unknown command '[0001.835]' - try 'help'
Tegra210 (P3450-0000) # [0001.846] of_register: registering b_fuel_gauge to of_hal
Unknown command '[0001.846]' - try 'help'
Tegra210 (P3450-0000) # [0001.863] gpio framework initialized2] of_register: registering tca9539_gpio to of_hal
Unknown command '[0001.863]' - try 'help'
Tegra210 (P3450-0000) # [0001.877] of_register: registering idriver to of_hal
Unknown command '[0001.877]' - try 'help'
Tegra210 (P3450-0000) # [0001.888] of_register: registering i897] of_register: registering max77620_pmic to of_hal
Unknown command '[0001.888]' - try 'help'
Tegra210 (P3450-0000) # [0001.903] regulator framework initial
Unknown command '[0001.903]' - try 'help'
Tegra210 (P3450-0000) # [0001.912] initializing target
Unknown command '[0001.912]' - try 'help'
Tegra210 (P3450-0000) # [0001..926] board ID = D78, board SKUalized
Unknown command '[0001..926]' - try 'help'
Tegra210 (P3450-0000) # [0001.952] initializing OF layer
Unknown command '[0001.952]' - try 'help'
Tegra210 (P3450-0000) # [00001.962] of_children_init: Ops fou done
Unknown command '[00001.962]' - try 'help'
Tegra210 (P3450-0000) # [0001.981] of_children_init: Ops founone
Unknown command '[0001.981]' - try 'help'
Tegra210 (P3450-0000) # [0001.993] of_children_init: Ops foundone
Unknown command '[0001.993]' - try 'help'
Tegra210 (P3450-0000) # [0002.006] of_children_init: Ops foundone
Unknown command '[0002.006]' - try 'help'
Tegra210 (P3450-0000) # [0002.019] of_children_init: Ops foundone
Unknown command '[0002.019]' - try 'help'
Tegra210 (P3450-0000) # [0002.032] of_children_init: Ops foung irq 118
Unknown command '[0002.032]' - try 'help'
Tegra210 (P3450-0000) # [0002.047] register 'maxim,max77620' r
Unknown command '[0002.047]' - try 'help'
Tegra210 (P3450-0000) # [0002.058] of_children_init: Ops foundone
Unknown command '[0002.058]' - try 'help'
Tegra210 (P3450-0000) # [0002.071] NCK carveout not present
Unknown command '[0002.071]' - try 'help'
Tegra210 (P3450-0000) # [-a0, size 256, type 0
Unknown command '[-a0,' - try 'help'
Tegra210 (P3450-0000) # [0002.093] Fin, type 0
Unknown command '[0002.093]' - try 'help'
Tegra210 (P3450-0000) # [0002.101] getating 1,a0, size 256, t0002.117] Writing offset failed
Unknown command '[0002.101]' - try 'help'
Tegra210 (P3450-0000) # [0002.120] eeprom_init: EEPROM read f_update: Updating 3,a0, size 256, type 0
Unknown command '[0002.120]' - try 'help'
Tegra210 (P3450-0000) # [0002.158] pm_ids_update: The pm boar-402=/i2c@7000c500:module@0x50
Unknown command '[0002.158]' - try 'help'
Tegra210 (P3450-0000) # [0002.173] pm_ids_update: pm id updat 0
Unknown command '[0002.173]' - try 'help'
Tegra210 (P3450-0000) # [0002.207] pm_ids_update: The pm boar-400=/i2c@7000c500:module@0x57
Unknown command '[0002.207]' - try 'help'
Tegra210 (P3450-0000) # [0002.222] pm_ids_update: pm id updatall 0xff)
Unknown command '[0002.222]' - try 'help'
Tegra210 (P3450-0000) # [0002.258] shim_eeprom_update_mac:267EPROM invalid MAC address (all 0xff)
Unknown command '[0002.258]' - try 'help'
Tegra210 (P3450-0000) # [0002.271] shim_eeprm_update_mac:267:nvidia,ethernet-mac node 48:b0:2d:5b:94:c5
Unknown command '[0002.271]' - try 'help'
Tegra210 (P3450-0000) # [0002.286] Plugin Manager: ParseODM dalycon=uart8250,mmio32,0x70006000
Unknown command '[0002.286]' - try 'help'
Tegra210 (P3450-0000) # [0002.312] Find /i2c@7000c000's aliasd /i2c@7000c500's alias i2c2
Unknown command '[0002.312]' - try 'help'
Tegra210 (P3450-0000) # [0002.328] get eeprom at 3-a0, size 2] pm_ids_update: Updating 1,a0, size 256, type 0
Unknown command '[0002.328]' - try 'help'
Tegra210 (P3450-0000) # [0002.342] I2C slave not started
Unknown command '[0002.342]' - try 'help'
Tegra210 (P3450-0000) # [000prom_init: EEPROM read failed
Unknown command '[000prom_init:' - try 'help'
Tegra210 (P3450-0000) # [00Updating 3,a0, size 256, type 0
Unknown command '[00Updating' - try 'help'
Tegra210 (P3450-0000) # [0ng plugin-manager/ids/3448-0000-402cessful
Unknown command '[0ng' - try 'help'
Tegra210 (P3450-0000) # [0002.407] pm_ids_update: Updating 3, is 3449-0000-400
Unknown command '[0002.407]' - try 'help'
Tegra210 (P3450-0000) # [0002.443] Adding plugin-manager/ids/ id update successful
Unknown command '[0002.443]' - try 'help'
Tegra210 (P3450-0000) # [0002.481] Add serial number:14246210 platform-init is not present. Skipping
Unknown command '[0002.481]' - try 'help'
Tegra210 (P3450-0000) # [0002.499] calling apps_init()
Unknown command '[0002.499]' - try 'help'
Tegra210 (P3450-0000) # [0002.02.512] starting app android_boinit
Unknown command '[0002.02.512]' - try 'help'
Tegra210 (P3450-0000) # [0002.527] could not find regulator
Unknown command '[0002.527]' - try 'help'
Tegra210 (P3450-0000) # [connected, returning false
Unknown command '[connected,' - try 'help'
Tegra210 (P3450-0000) # [0002.5590002.569] sor0 is not suppor580] subnode volume_up is not found !
Unknown command '[0002.5590002.569]' - try 'help'
Tegra210 (P3450-0000) # [0002.584] subnode back is not found ot found !
Unknown command '[0002.584]' - try 'help'
Tegra210 (P3450-0000) # [0002.595] Gpio keyboard init successressing blob (type 1)...
Unknown command '[0002.595]' - try 'help'
Tegra210 (P3450-0000) # [0002.756] display_resolution: No dis] Could not load/initialize BMP blob...ignoring
Unknown command '[0002.756]' - try 'help'
Tegra210 (P3450-0000) # [0002.841] decompressor handler not f[0002.851] XUSB blob version 0 size 126464 @ 0x92ca828c
Unknown command '[0002.841]' - try 'help'
Tegra210 (P3450-0000) # [0002.857] -------> se_aes_verify_sbkration failed
Unknown command '[0002.857]' - try 'help'
Tegra210 (P3450-0000) # [0002.868] bl_battery_charging: conneisplay init
Unknown command '[0002.868]' - try 'help'
Tegra210 (P3450-0000) # [0002.881] switch_backlight failed
Unknown command '[0002.881]' - try 'help'
Tegra210 (P3450-0000) # [0ash0:MSC !
Unknown command '[0ash0:MSC' - try 'help'
Tegra210 (P3450-0000) # [0002.895] MSC Partitionrtition spiflt: blob-partition USP header read failed
Unknown command '[0002.895]' - try 'help'
Tegra210 (P3450-0000) # [0002.917] android_boot Unable to upd926] Loading kernel from LNX
Unknown command '[0002.917]' - try 'help'
Tegra210 (P3450-0000) # [0002.936] Found 19 BFS partitions inssor handler not found
Unknown command '[0002.936]' - try 'help'
Tegra210 (P3450-0000) # [0003.527] Successfully loaded kernel37] sdmmc node status = okay
Unknown command '[0003.527]' - try 'help'
Tegra210 (P3450-0000) # [0003.540] sdcard instance = 0
Unknown command '[0003.540]' - try 'help'
Tegra210 (P3450-0000) # [0003. sdcard gpio pin 0xc9
Unknown command '[0003.' - try 'help'
Tegra210 (P3450-0000) # [0003.552io_pin = 201
Unknown command '[0003.552io_pin' - try 'help'
Tegra210 (P3450-0000) # [0003.560] pin_...
Unknown command '[0003.560]' - try 'help'
Tegra210 (P3450-0000) # [0003.568] load_anlay init
Unknown command '[0003.568]' - try 'help'
Tegra210 (P3450-0000) # [0003.578]aded and initialized
Unknown command '[0003.578]aded' - try 'help'
Tegra210 (P3450-0000) # [0003.594] Skipping dts_overrialias iind /i2c@7000c500's alias i2c2
> [0003.623] get eeprom at 3-a0, size 203.627] get eeprom at 3-ae, size 256, type 0
> [0003.631] pm_ids_update: Updating 1,, size 256, type 0
> [0003.642 Writing offset failed
> [00035] eeprom_init: EEPROM read fail0003.649] pm_ids_update: eeprom init failed
> [0003.653] pm_ids_update: Updating 3,256, type 0
> [0003.690] Adding plugin-manager/ids/0000-402=/i2c@7000c500:module@0x50
> [0003.699] pm_ids_update: pm id updatcessful
> [0003.703] pm_ids_update: Updating 3,e, size 256, type 0
> [0003.733] pm_ids_update: The pm boaris 3449-0000-400
> [0003.739] Adding plugin-manager/ids/9-0000-400=/i2c@7000c500:module@0x57
> [0003.747] pm_ids_update: pm id updatessful
> [0003.777] eeprom_get_mac: EEPROM inv MAC address (all 0xff)
> [0003.783] shim_eeprom_update_mac:267iled to update 0 MAC address in DTB
> [0003.791] eeprom_get_mac: EEPROM invMAC address (all 0xff)
> [0003.797] shim_eeprom_update_mac:267led to update 1 MAC address in DTB
> [0003.805] updating /chosen/nvidia,etet-mac node 48:b0:2d:5b:94:c5
> [0003.812] Plugin Manager: Parse ODM 0x000a4000
> [0003.823] shim_cmdline_install: /choargs: earlycon=uart8250,mmio32,0x70006000
> [0003.832] Add serial number:14246210 as DT property
> [0003.840] "bpmp" doesn't exist, crea3.845] Updated bpmp info to DTB
Unknown command '[0003.594]' - try 'help'
Tegra210 (P3450-0000) # [0003.850] Updated initrd info to DTB3.863] "pmu-board" doesn't exist, creating
Unknown command '[0003.850]' - try 'help'
Tegra210 (P3450-0000) # [0003.878] Updated board info to DTB
Unknown command '[0003.878]' - try 'help'
Tegra210 (P3450-0000) # ated reset info to DTB
Unknown command 'ated' - try 'help'
Tegra210 (P3450-0000) # [0003.889] dis: No display init
Unknown command '[0003.889]' - try 'help'
Tegra210 (P3450-0000) # [0003e: tegraid=21.1.2.0.0 ddr_die=40ne_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt
Unknown command '[0003e:' - try 'help'
Tegra210 (P3450-0000) # [0003.938] DTB cmdline: earlycon=uartle=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
Unknown command '[0003.938]' - try 'help'
Tegra210 (P3450-0000) # [0003.956] Updated bootarg info to DT3.966] Adding eks info 0 to DT
Unknown command '[0003.956]' - try 'help'
Tegra210 (P3450-0000) # [0003.971] WARNING: Failed to pass NS0003985] set vdd_core voltage to 1125 mv
Unknown command '[0003.971]' - try 'help'
Tegra210 (P3450-0000) # [0003.989] setting 'vdd-core' regulat
Unknown command '[0003.989]' - try 'help'
Tegra210 (P3450-0000) # U-Boot 2020.04-g46e4604c78 (Jul 26 2l: 1 sdhci@700b0600: 0
Unknown command 'U-Boot' - try 'help'
Tegra210 (P3450-0000) # Loading Environment from SPI Flash...KiB, total 4 MiB
Unknown command 'Loading' - try 'help'
Tegra210 (P3450-0000) # *** Warning - bad CRC, using default ethernet found.
Unknown command '***' - try 'help'
Tegra210 (P3450-0000) # Hit any key to stop autoboot:  0
Unknown command 'Hit' - try 'help'
Tegra210 (P3450-0000) # tegr   0x00000001
Unknown command 'tegr' - try 'help'
Tegra210 (P3450-0000) #     Interrupt statu  Present status  rting USB...
Unknown command 'Interrupt' - try 'help'
Tegra210 (P3450-0000) # Bus usb@7d000000: tegrausb: Invalid drmware size 126464
Unknown command 'Bus' - try 'help'
Tegra210 (P3450-0000) # Firmware timestamp: 0x5f23e558, Versitarting the controller
Unknown command 'Firmware' - try 'help'
Tegra210 (P3450-0000) # USB XHCI 1.00
Unknown command 'USB' - try 'help'
Tegra210 (P3450-0000) # scanning bus xusb@70090torage devicesice 0: unknown device
Unknown command 'scanning' - try 'help'
Tegra210 (P3450-0000) # Warning: eth_rtl8169 using MAC addreBst 7
Unknown command 'Warning:' - try 'help'
Tegra210 (P3450-0000) # BOOTP broadcast 8
Unknown command 'BOOTP' - try 'help'
Tegra210 (P3450-0000) # BOOTP broadcast 9
Tegra210 (P3450-0000) # Bdcast 13
Unknown command 'Bdcast' - try 'help'
Tegra210 (P3450-0000) # BOOTP bro<INTERRUPT>
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
[0001.422] Tegraboot started after 51853 us
[0001.426] Basic modules init took 926104 us
[0001.445] Carveout took -132464 us
[0001.449] CPU initialization took 508289 us
[0001.453] Total time taken by TegraBoot 1404788 us
[0001.672]
[0001.674] Debug Init done
[0001.704] Pinmux applied successfully
[0001.719] Using base:0x60005090 & irq:208 for tick-timer
[0001.739]
[0001.743]
[0001.913] initializing target
[0001.963] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.994] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.017] I2C Bus Init done
[0002.085] get eeprom at 1-a0, size 256, type 0
[0002.208] pm_ids_update: The pm board id is 3449-0000-400
[0002.325] Find /i2c@7000c500's alias i2c2
[0002.343] I2C slave not started
[0002.346] I2C write failed
[0002.396] Adding plugin-manager/ids/3448-0000-402=/i2c@7000c500:module@0x50
[0002.560] hdDT entry for leds-pwm not found
m[0002.567] i is not connected
[0002.757] display_resolution: No display init
[0002.882] switch_backlight failed
[0002.909] USP partition read failed!
[0002.918] android_boot Unable to update recovery partition
[0002.927] Loading kernel from LNX
[0003.257] load kernel from storage
[0003.262] decompressor handler not found
[0003.546] sdcard gpio handle 0x5b
[0003.558] cd_gpio_pin = 201
[0003.563] Found sdcard
[0003.574] display_resolution: No display init
[0003.591] NCK carveout not present
[0003.632] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.643] Writing offset failed
[0003.646] eeprom_init: EEPROM read failed
[0003.650] pm_ids_update: eeprom init failed
[0003.654] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.740] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0003.778] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.846] Updated bpmp info to DTB
[0003.882] "reset" doesn't exist, creating
[0003.890] display_console_ioctl: No display init
[0003.899] display_console_ioctl: No display init
[0003.957] Updated bootarg info to DTB
[0003.972] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
SoC: tegra210
DRAM:  4 GiB
In:    serial
Out:   serial
Err:   serial
starting USB...
Bus xusb@70090000:
USB XHCI 1.00
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Hi @linuxdev,
I’d rather avoid cloning the card with dd due to the reasons described by @mdegans in this post. But thank you for the information!
Noah
Please try this command:
$ sudo ./flash.sh -r jetson-nano-devkit mmcblk0p1
Hi @DaneLLL,
Thank you again for the method, however, I was able to successfully flash the Nano with Etcher, and then resize the primary partition to the full size of the SD card with gnome-disk. Alternatively, one may be able to specify a blob size with the -s argument passed to create-jetson-nano-sd-card-image.sh. I haven’t tried this myself, but logically speaking it should work.
Here are the steps for those who are interested (I did it using a VM):
  1. Insert microSD card into laptop running Ubuntu 18.04 LTS with SDK Manager installed.
  2. Mount it with mount <path-to-sd-card> /mnt
  3. Run sudo ROOTFS_DIR=/mnt ./jetson-disk-image-creator.sh -o sd-blob.img -b jetson-nano -r 300
  4. Copy sd-blob.img to the host machine.
  5. Install Etcher, format the target microSD card, and flash it to the target card.
Thank you for your help @DaneLLL and @linuxdev!
Yes, account names and passwords would be cloned. So would any network setup which depends on a MAC address. There are ways to account for that, but it takes thinking about it. On the other hand, if you clone from the Jetson, then you have the very same problem. If a clone succeeds, then it is an exact duplicate of what you’d get from dd. I’ll suggest you might want to start a thread on “what needs to be accounted for when turning a clone into a production environment?”. This depends on the release version, but it is a slightly different perspective compared to cloning itself.
Note: If you never complete first boot account setup after a flash, then any clone will also not have that setup, and thus won’t copy account names and passwords. However, it is possible that any network MAC address dependent configuration could still be in place even if you never complete first boot account setup.
