I am trying to capture frames from the viewport, then encode using ffmpeg and streaming to an endpoint.
I can’t find an example of grabbing the render of the camera in the scene. How can I “grab” the camera and find the frames being rendered?
Hi Adam. The omni.kit.viewport.utility
extension has two methods for capturing the viewport:
omni.kit.viewport.utility.capture_viewport_to_buffer()
omni.kit.viewport.utility.capture_viewport_to_file()
I briefly show how to use the file capture function here: Omniverse Developer Q&A - 12/9/2022 - YouTube. You can also look at omni.kit.capture.viewport
for an example of how the Movie Capture window does it.
The viewport’s active camera is rendered. You can change the camera with this snippet: Change the Viewport’s Active Camera — Omniverse Kit documentation
This is great thank you, much appreciated.
