• Hardware Platform (Jetson / GPU) GPU • DeepStream Version 6.2 • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I am implementing custom_bind by looking at the link below
But what I’m curious about is, when something like List[float] is structured like this, how should the variable that receives the float pointer be passed in Python? Please explain with an example both pybind11 and pyds_deepstream
struct NvDsInferFaceLandmarkMeta {
float *data;
int size;
int num_landmark;
