I just got a vGPU Workstation license for a M10 card, but I’m not seeing either CUDA or OpenCL being enabled. I’m using the profile GRID M10-4Q, and VMWare ESXi 7.0. Do I need to make a change in vcenter or the VM?
I have it set as Shared Direct in vcenter
You need to use a 8Q profile. CUDA is not working on smaller profiles with Maxwell generation.
Ah ha, thank you, that worked.
