I flashed the Jetson Xavier Orin NX through the SDK mamanger and tried to boot it, but it won’t boot.
I’m attaching the logs.
I made the carrier board from scratch.
orin nx debug full log.txt (46.6 KB)
given that you are using a custom board designed by yourself, did you turn off reading EEPROM on the carrier board?
Jetson AGX Orin Platform Adaptation and Bring-Up — Jetson Linux Developer Guide documentation (nvidia.com)
I can’t make the above EEPROM settings when flashing via SDK Manager, is there any way?
BSP downloaded with SDK Manager is only for NVIDIA’s official DevKit, and you will not be able to flash devices with custom boards using default BSP.
Please download the BSP on our website, make corresponding change to fit the design of your custom board, and flash using our flashing script.
