How do I get Optical Flow metadata from a pad_bufer_probe method?
• Issue Type( questions, new requirements, bugs) Question
I am implementing a padbuferprobe method similar to the one in deepstream_user_metadata_app. This can be seen below.
static GstPadProbeReturn
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
  GstBuffer *buf = (GstBuffer *) info->data;
  NvDsMetaList * l_frame = NULL;
  NvDsMetaList * l_user_meta = NULL;
  NvDsUserMeta *user_meta = NULL;
  gchar *user_meta_data = NULL;
  int i = 0;
  NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
  for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
    NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
    /* Validate user meta */
    for (l_user_meta = frame_meta->frame_user_meta_list; l_user_meta != NULL;
        l_user_meta = l_user_meta->next) {
      user_meta = (NvDsUserMeta *) (l_user_meta->data);
      user_meta_data = (gchar *)user_meta->user_meta_data;
      if(user_meta->base_meta.meta_type == NVDS_USER_FRAME_META_EXAMPLE)
        g_print("\n************ Retrieving user_meta_data array of 16 on osd sink pad\n");
        for(i = 0; i < USER_ARRAY_SIZE; i++) {
          g_print("user_meta_data [%d] = %d\n", i, user_meta_data[i]);
        g_print("\n");
    frame_number++;
  return GST_PAD_PROBE_OK;
In my program this buffer probe is attached to the src of nvof plugin so the NVDSOpticalFlowMeta should be attached. How to I get this metadata and print it. For example how would I get the optical flow vector at each 4x4 block for a specific frame?
To start I changed this line.
to this
if(user_meta->base_meta.meta_type == NVDS_OPTICAL_FLOW_META)
I can confirm this if statement returns true but I don’t know how to gather the optical flow metadata from the user_meta. From what I can tell, the nvdsmeta.h doesn’t include NvDsOpticalFlowMeta so I don’t know how it relates to the other metadata structures. This also leads me to another question. Would I need to add an include statement at the beggining of my app like this to include the nvdsopticalflowmeta structure?
#include "nvds_opticalflow_meta.h"
Additional Information The app that I’m working on is a modification of the deepstream-nvof-test.c. My modified pipeline looks something like this .
uridecodebin -> nvstreammux -> nvof *-> tee -> queue2 -> nvofvisual -> tiler -> transform -> sink
                                         \_> queue1 -> nvmsgconv -> nvmsgbroker
Once again the probe is attached to the src of the nvof plugin denoted by *
Any help or input would be much appreciated.
some inferences:
Do you have any examples for C code?
Also would I have to add this include statement at the beginning of the test app?
Also for clarification, in this code you shared,
m.def("get_optical_flow_vectors",
      [](void *data) {
what parameter is passed into (void *data) when that method is called? Is it from user meta? Is it from Frame meta? Or would it be from frame_user_meta_list? I am still confused on where exactly I get the *data from.
no C version. it is a sample to parse that data, please refer to deepstream_python_apps/deepstream-opticalflow.py at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
The get optical flow vectors method call leaves me with one more question. I now understand how to get the data and how to add it to an array. I still am wondering how the DATA[i] array has stored values. So I understand for a 1280x720 video I would have 320 columns and 180 rows. This means I would have 57,600 blocks with motion vectors. I’m wondering whether the stored motion vectors for each block traverse the row first or the column first.
For a simpler example, lets imagine that I had a video that was 16x12 pixels which would then have 4 columns and 3 rows. Is the data stored with blocks being stored row first as shown in Example A below?
exampleA
Or would the data be stored with blocks traversing a column first as Example B below?
exampleB
This would be helpful to know so that I will understand exactly where in the video, the flow vectors are coming from. Without knowing this the data would be useless.
it is example A, data is saved by rows.
Ok, thank you for the responses. This has been helpful in gaining a better understanding of probing optical flow metadata.
