• Hardware Platform (Jetson / GPU) GPU • DeepStream Version 5.1 • JetPack Version (valid for Jetson only) • TensorRT Version 7.2 • NVIDIA GPU Driver Version (valid for GPU only) 440 • Issue Type( questions, new requirements, bugs) questions
I ues unlink_element_from_streammux_sink_pad() to do this, but it doesn’t always work.
Is there an official method to remove a stream?
The upgrade will change too much of my code. deepstream_sink_bin.c (28.3 KB)
I uploaded deepStream_source_bin.c.
Execute the command:./deepstream-test5-app -c configs/test5_config_file_src_infer.txt
Modified the nvStreammux_eosMonitor_probe_func function and create_multi_source_bin.
Other file changes are only their own business logic and do not involve pipeline
Add the stop_release_source of deepStream_reference_apps /runtime_source_add_delete to deepstream-source_bin will block .
Blocking position is:gst_element_release_request_pad (streammux, sinkpad);
