How do I replace data in a pipeline in DeepStream?
RTX3060
• DeepStream Version
DeepStream Version: 6.2
• TensorRT Version
TensorRT Version 8.5
525.85.12
The output frame of my detection network is not rendered directly on the image, but on a black image with a size of 200×400, how can I replace the image data in the deepstream pipeline.
  1. what is the media pipeline? what are the model’s inputs and outputs? here is a sample to modify image data :Deepstream sample code snippet - #3 by bcao
  1. why is it a black image? the detection models usually give a bonding boxes, which are some coordinates.
my model infer image.
here is another solution, you might get the coordinates of that green bbox, convert them to new coordinates in the frame, add object meta by nvds_add_obj_meta_to_frame, then deepstream nvosd plugin will draw the bbox.
He was painting the bbox on top of the original image without that black image.
  1. what are the model 's input and output layers?
  2. about the black picture above, How did it come? how did that green bboxs come?
