• Hardware Platform (Jetson / GPU) => Xavier NX • DeepStream Version => DeepStream 6.0 • JetPack Version (valid for Jetson only) => JetPack 4.6 • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I’m testing Deepstream SDK on Xavier NX
It has a issue about image quality as below
The red box, I’ve manually drawn.
If the camera image is showing with other SW, It is fine.
I think input stream is good condition.
So, It looks the issue has happened on ‘decodebin’ in DeepStream.
We can get only H.264 stream from IP Camera.
Is there any solution we can get better image on DeepStream?
