The images from the rpts steam are not clear
• Hardware Platform (Jetson / GPU) Jetson xavier
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1-b147
• TensorRT Version 8.5
I want to know what can explain why in my rtps stream the images I receive are not clear as you can below
to narrow down this issue, please check the follows:
  1. if sinking to mp4 file, dose the mp4 file play well?
  2. dose it play well on the machine which runs deepstream app?
  1. Yes, the sink is mp4 file and it runs well .
  2. It plays well on the jetson board that runs the app , I just has this issue on my other computer via ffplay
it seemed to be the network issue, you can caputre the network packets to check on the other computer.
how can i do that ?
noticing there are decoding failed on the screenshot, the mosaic should be caused by packet loss.
if using linux, you can use tshark; if using windows, you can use wireshark. please check if there are many packets loss.
