Hi
• Hardware Platform (Jetson / GPU) jetson nx
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.4
• TensorRT Version 7
• Issue Type( questions, new requirements, bugs) questions and bugs
Hi there is blur and shadow when i use ffmpeg to push mp4 video as rtsp and playing in deepstream . The rtsp is ok when i use vlc or gstreamer to play, but in the deepstream-app there will be a lot of blur and shadow , I think it is happen before the nvinfer function ,but i don’t know how to solve it.
There are some videos and pictures below:
I use this ffmpeg command
ffmpeg -re -stream_loop -1 -i C:\xxxxx\a.mp4 -vcodec h264 -acodec aac -strict -2 -s 640x360 -r 25 -f rtsp -rtsp_transport tcp rtsp://xxxx/test1
txt file
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=rtsp
type=4
uri=rtsp://xxxxxx/test1
num-sources=1
gpu-id=0
cudadec-memtype=0
rtsp-reconnect-interval-sec=20
select-rtp-protocol=4
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
qos=0
